Shocks and sway bar ?? #2831287
10/10/20 07:03 PM
10/10/20 07:03 PM
Fort Collins, CO
justintyme Offline OP
Fort Collins, CO
So I'm going to start on some basic handling upgrades from my 69 Roadrunner. Manual steering car, no front sway bar currently. Im planning on the Firm feel front tubular sway bar, and unfortunately can't afford bilsteins at the same time, but it needs shocks badly. What would you go with for now?? KYB??
Re: Shocks and sway bar ?? [Re: justintyme] #2831292
10/10/20 07:27 PM
10/10/20 07:27 PM
AndyF Offline
AndyF  Offline
I don't know the answer to your dilemma since I don't know all the facts but if I was broke I wouldn't spend money on KYB shocks. I also probably wouldn't put a new Firm Fell tubular bar on the car. If I was broke I'd find a used performance bar or a factory bar and then buy Koni shocks. Last time I checked the Koni shocks were cheaper than the Bilsteins and the Koni shocks are adjustable.
Re: Shocks and sway bar ?? [Re: AndyF] #2831366
10/10/20 10:29 PM
10/10/20 10:29 PM
Fort Collins, CO
Fort Collins, CO
What other details would help? Stock suspension, in good condition but has old shocks up front and sir shocks out back, so anything is likely an improvement. MY car but has been passed on to my oldest son, he got squirrelley accelerating, hit a sign, and now it is in the body shop getting fixed and that ate up a lot of $$. It does tend to sway on hard acceleration, especially if you over correct steering. So I think a sway bar and new shocks should help. 383 4 speed, has aluminum heads etc, not the fastest in the world, but respectable, I realize some supsension updates would benefit, and they may come but not at the moment. I would like to buy one swaybar set up and be done, that will work with future suspension upgrades, so if not Firm Feel then what. My thout was Shocks I can easily upgrade later?
thought the Koni shocks weren't a bolt on in the rear?
Re: Shocks and sway bar ?? [Re: justintyme] #2831371
10/10/20 10:49 PM
10/10/20 10:49 PM
AndyF Offline
AndyF  Offline
Hellwig bar is cheaper than Firm Feel and when you buy from Summit it is free shipping. So you could buy the Koni shocks for the difference. That would take care of the front. Does the car have good tires? Which torsion bars are on it?
https://www.summitracing.com/parts/hel-55903
Re: Shocks and sway bar ?? [Re: AndyF] #2831396
10/11/20 06:32 AM
10/11/20 06:32 AM
Fort Collins, CO
Fort Collins, CO
Thank you for the Hellwig bar info that looks like a great option at the price!
It has good tires in the sense that they have good tread, not a performance handling tire, Old school set up with 15 x7 Cop wheels......Stock torsion bars as well.
Re: Shocks and sway bar ?? [Re: justintyme] #2831397
10/11/20 06:36 AM
10/11/20 06:36 AM
Kirkland, Washington
Pacnorthcuda Offline
Look at Monroe shocks. I have KYB gas-adjusts on my Cuda and I wouldn’t buy them again. Too harsh, especially on the rear. Monroe’s are a value shock that simply work, no they are not Bilstiens, but they don’t cost any near that price.
Re: Shocks and sway bar ?? [Re: Pacnorthcuda] #2831587
10/11/20 03:49 PM
10/11/20 03:49 PM
PA
70Duster Offline
70Duster  Offline
PA
I put the Hellwig Bar and Monroe shocks on the Duster and they are a perfect combination in my opinion. Not too harsh and the bar works great!
Re: Shocks and sway bar ?? [Re: 70Duster] #2831718
10/11/20 09:17 PM
10/11/20 09:17 PM
Fort Collins, CO
Fort Collins, CO
Thanks, the monroe shocks and hellwig bar are probably what I will do for now
Re: Shocks and sway bar ?? [Re: justintyme] #2831805
10/12/20 08:47 AM
10/12/20 08:47 AM
n.c.
geo. Offline
geo.  Offline
n.c.
All Road Runners were factory equipped with a front bar.
If the factory mounting points are still there, I'd look for a stock front bar.
Others may chime in, but I think any '66-'69 B body bar would fit, and help improve response,
Not that a stock bar is "better" than aftermarket, but may "better" fit your budget, and let you see how a stock RR handles.
Re: Shocks and sway bar ?? [Re: justintyme] #2832956
10/15/20 10:26 AM
10/15/20 10:26 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Hi, just want to let you know that I have that 1 3/8 inch Helwig sway bar installed on my big block 69 Coronet with Monro-Matic shocks. It's not a canyon racer by any stretch of the imagination, but the sway bar and shocks work well for driving on the street. The sway bar helps flatten body roll in the corners and the shocks do a good job damping the bumps in the road.
The difference in body roll between the stock sway bar (around 7/8 inch) and the Helwig bar is definitely noticeable, so I would recommend the larger sway bar.
Hope this helps.
Re: Shocks and sway bar ?? [Re: mrob] #2833014
10/15/20 01:00 PM
10/15/20 01:00 PM
moparx Offline
moparx  Offline
thanks for the report ! glad to hear it turned out well for you. up
beer
Re: Shocks and sway bar ?? [Re: justintyme] #2833186
10/15/20 09:55 PM
10/15/20 09:55 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I have yet to find anyone cheaper than these guys - and if you wait for a special weekend like black friday ect the special price is added on!
https://www.sdtrucksprings.com/sway...y?zenid=d6af49b1d7e092f9ad36e8abf0aa46d0
Re: Shocks and sway bar ?? [Re: dangina] #2833721
10/17/20 01:13 AM
10/17/20 01:13 AM
Fort Collins, CO
Fort Collins, CO
Thanks for the help everyone!
Re: Shocks and sway bar ?? [Re: justintyme] #2834243
10/18/20 02:57 PM
10/18/20 02:57 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
While not a performance shock, Monroe Gas-matic or comparable nitrogen charged shocks are significantly better than plain oil shocks and will have enough oomph to control t-bars up to .96 diameter. These can be a decent budget alternative until you decide to move up to better dampers or step up suspension rates.
Re: Shocks and sway bar ?? [Re: justintyme] #2834998
10/20/20 12:13 PM
10/20/20 12:13 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
PST makes a decent kit for not so much. I had one on my old 67 coronet. https://www.ebay.com/itm/1-1-8-Front-Sway-Bar-1962-69-Mopar-B-Body/203088269395?fits=Year%3A1969%7CMake%3ADodge&hash=item2f49011053:g:6nsAAOSwxGBdAA7B
Bilstein kit https://www.ebay.com/itm/1-1-8-Front-Sway-Bar-1962-69-Mopar-B-Body/203088269395?fits=Year%3A1969%7CMake%3ADodge&hash=item2f49011053:g:6nsAAOSwxGBdAA7B I suspect if you have air shocks your rear springs are spent you might want to get a new set. They are about $280/set
Coming soon!!!!
Re: Shocks and sway bar ?? [Re: Pacnorthcuda] #2835162
10/20/20 05:05 PM
10/20/20 05:05 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
I agree. I had KYB in my Police Diplomat. Not a big fan. Replaced them with NOS Mopar Police shocks I happened to come across. And recently when my Power Wagon needed shocks I went with a set of Monroes and I've been very pleased. Didn't break the bank.
Facts are stubborn things.
Re: Shocks and sway bar ?? [Re: TC@HP2] #2901000
03/20/21 09:14 AM
03/20/21 09:14 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
FWIW - I have FirmFeel's tubular sway bar "kit" mounted front and rear of our '65 to flatten the car... ..then I experimented with shocks...
thumbs ... I ended up real happy with basic Monroe-Matics in front, and 'stiffer' Monroe-Gasmatics in the rear.
This gave me smooth transition to oversteer entering turns that I can manage with throttle through the turn - which is exactly what I was looking for.
- Art
PS - I don't track race my Mopars, I just wanted the '65 to have better handling.
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Shocks and sway bar ?? [Re: 67SATisfaction] #2901029
03/20/21 11:21 AM
03/20/21 11:21 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I had the same experience with KYB`s. They were too stiff and harsh for my car. I gave them away and replaced them with Monroes.
