46RH Lockup Swap #2831340
10/10/20 09:04 PM
10/10/20 09:04 PM
Usa
A39Coronet Offline OP
Usa
I have an opportunity to pick up a cheap 46RH core out of a 95 1500 for my Cuda. I've read several awesome write-ups about the swap, but all had to do with older non lockup units. Just wanted to check and see if anything would be physically different with the swap, mainly converter spacing, that should be mentally noted prior, or if they were the same. I know you have to address the OD and lockup functions, but just wanted to make sure it was a solution and not more problems. Anything else noteworthy?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 46RH Lockup Swap [Re: A39Coronet] #2831343
10/10/20 09:13 PM
10/10/20 09:13 PM
Guitar Jones Offline
External dimensions are all the same but the converters don't interchange. Input shaft and reaction supports are different as well as the valvebody.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 46RH Lockup Swap [Re: Guitar Jones] #2831344
10/10/20 09:24 PM
10/10/20 09:24 PM
Usa
Usa
That's what I figured. I'm assuming the lockup units from Cope or Hughes would be a straight forward install just as any other 727 based trans, you just have the lockup feature available? I need to get on the horn with either of those companies Monday but it's on my mind now and figured I'd ask here first
Re: 46RH Lockup Swap [Re: A39Coronet] #2831348
10/10/20 09:41 PM
10/10/20 09:41 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the 1995 Rh in my 68 Charger, I have a switch for the converter & one for OD on my console, works AWESOME this was when I had a 3.54 gear, has 4.10 now
Re: 46RH Lockup Swap [Re: CSK] #2831412
10/11/20 07:59 AM
10/11/20 07:59 AM
Usa
Usa
That's a pretty decent rpm drop with lockup. Who's converter did you use? I only see a handful of companies advertise off the shelf units but I'm wondering if any of the bigger name companies can make one.
Re: 46RH Lockup Swap [Re: A39Coronet] #2831420
10/11/20 08:30 AM
10/11/20 08:30 AM
Alabama, USA
69DrppTop Offline
69DrppTop  Offline
Alabama, USA
Recently completed a resto on my 71 Cuda which included installation of a 46RH with automatic OD and lockup. Did all the work myself so I know all the details. Willing to share my experiences if you need it.
Re: 46RH Lockup Swap [Re: 69DrppTop] #2831567
10/11/20 03:04 PM
10/11/20 03:04 PM
Usa
Usa
Awesome. For the sake of others I'll ask here instead of PM, who did you go with for the converter, and what are you using for the kickdown? Standard linkage from a donor or ? Much appreciated!
Since mine is also a 71, were the floor mods fairly minimal and straight forward?
Re: 46RH Lockup Swap [Re: A39Coronet] #2831668
10/11/20 06:57 PM
10/11/20 06:57 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Patc,, Transmisioncenter.net built the converter, 4900 stall
Re: 46RH Lockup Swap [Re: CSK] #2897338
03/09/21 11:22 AM
03/09/21 11:22 AM
Killen, Al
dbc105 Offline
dbc105  Offline
Killen, Al
I'm researching for my '68 RR. I've already bought a '95 A518 from a Ram 1500, I'm going to rebuild. I'm planning just the 11" high stall stock converter, will be plenty for my application and a few 618 parts inside. What I'm trying to figure out is bolting to the 383. Did you use an adapter kit or a JW Ultra Bell? Or is there another option?
Thanks,
DC
Re: 46RH Lockup Swap [Re: dbc105] #2897340
03/09/21 11:39 AM
03/09/21 11:39 AM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
Thanks,
DC
I have a 47re housing that I used the JW Ultra Bell.
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: 46RH Lockup Swap [Re: A39Coronet] #2897342
03/09/21 11:46 AM
03/09/21 11:46 AM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
For those of us who already have an expensive non lock-up converter, is it possible to replace certain transmission parts to convert it to a non lock-up?
The obvious stuff are things like the Input shaft and the valve body...but other than that, are there any other "guts" that need to be sourced?
Thanks!
Re: 46RH Lockup Swap [Re: dbc105] #2897389
03/09/21 02:25 PM
03/09/21 02:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thanks,
DC
I used a JW bell
Re: 46RH Lockup Swap [Re: Diplomat360] #2897475
03/09/21 07:28 PM
03/09/21 07:28 PM
A727Tflite Offline
A727Tflite  Offline
Thanks!
Find yourself a good complete pump or go with just the reaction shaft support.
Re: 46RH Lockup Swap [Re: CSK] #2897581
03/09/21 11:17 PM
03/09/21 11:17 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Does the Holley EFI not have any mappable auxiliary outputs for generic transmission control? If not, that seems like a real swing and a miss for Holley in terms of retrofit efi for resto-mod vehicles.
Re: 46RH Lockup Swap [Re: Uberpube] #2897674
03/10/21 11:04 AM
03/10/21 11:04 AM
Missouri
randavis Offline
randavis  Offline
Missouri
I don't think the Sniper line has that capability. It's an entry level efi. The Super Sniper will have those configurable inputs, I think. Otherwise, it's on to the more expensive units.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
