How Do I Get This Off My Durango?
#2831192
10/10/20 03:54 PM
10/10/20 03:54 PM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi All,
It has been awhile since I posted here but I have another question for you experts. I bought another Durango recently and I took the door panel or I believe card off to fix the window, and now the inside door hinge broke so now I need a new one. My question is how the hell do I get it off? Here are some pictures, any help would be appreciated.......
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: How Do I Get This Off My Durango?
[Re: SportFuryS/23383]
#2831263
10/10/20 06:11 PM
10/10/20 06:11 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
[Re: GarageDodge]
#2831341
10/10/20 09:04 PM
10/10/20 09:04 PM
Guitar Jones
They don't but you can get one from a junkyard door panel of any color.
[Re: 5thAve]
#2835015
10/20/20 12:49 PM
10/20/20 12:49 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Are those poly rivets?
I just saw a poly rivet tool and rivet set on Jegs the other day and was like where would someone ever need a plastic pop rivet?
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#2835412
10/21/20 03:56 AM
10/21/20 03:56 AM
Posts: 10,167 A Red State
SNK-EYZ
A Red State
I just saw a poly rivet tool and rivet set on Jegs the other day and was like where would someone ever need a plastic pop rivet? That's what they look like to me, poly pop rivets. That what they use to secure the front fender liners on a 2004 Durango. I just used a thin punch (framing nail size) to punch it straight through and it releases the rivet. I bought new ones from a body shop supply. The pin is a littler larger than the standard metal pop rivet pin. I have multiple pop rivet guns so I just drilled out one of the adapter heads to fit them. Otherwise it might require buying the correct pop rivet gun.
[Re: hp383]
#2835430
10/21/20 06:47 AM
10/21/20 06:47 AM
Guitar Jones
I just saw a poly rivet tool and rivet set on Jegs the other day and was like where would someone ever need a plastic pop rivet? Those are not poly rivets, they are melted over plastic. There is no opening on the other side for the rivet to expand too. The poly rivets are used for multiple applications of trim, fender liners, shields and what not.
[Re: OrangeProwler]
#2836798
10/24/20 12:47 AM
10/24/20 12:47 AM
Posts: 4,159 Canada -- Posts: 4034 -Registe...
5thAve
I'm wondering if you could carefully use a Dremel with a small cutting attachment and then find similar rivets/buttons and use plastic welding to put them back on? That's pretty much how you deal with those things but you don't need any additional parts. You cut off or re-melt the part that's been melted and flattened to push it back thru the hole and to put it back together you need to use something to glue the post in the hole so it doesn't come out again.
