So i did a thing today. The Imperial will thank me.
#2830955
10/09/20 09:53 PM
10/09/20 09:53 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I did some pretty heavy soul searching on the Imperial engine project. My nerdy side had taken over and I got all caught up in making the engine as efficient as possible. Efficient engine means torque. It also means better fuel economy. Big torque also means lively performance and more fun to drive but focusing on that trades off horsepower. Digging back into my fuel and mileage records from the 2012 Power Tour (Dallas to Detroit and back) I saw that I was only getting 12 mpg. I'd told myself a while back this was likely to be my last old school engine build. The new stuff is just too efficient and easy to get power out of. That's doubly true when you think of these old big blocks with what are essentially small block heads on them. Looking back at my engine builds I realized that I had done some fun stuff but never really built an engine with good parts. They'd always been a hodge podge of used factory bits with cams and other stuff bolted to them. As for the car, it's only value is the engine. Without a 440/727/8.75 this car is little more than demo derby material. It's an organ donor on wheels. Only after hours of soul searching and long deep conversation with close friends did the real me resurface. The Imperial is going back on the road with 543 cubic inches of RB power. It's too late to talk me back from the edge. The money is spent. I'm going back to my happy place which is just a wee bit on the other side of bonkers. I was only fooling myself with all that adult supervision talk. I ordered a 440 Source 543 kit with 10:1 compression on 88 CC heads. I'll call Comp and discuss a new cam for this build. The old Edelbrock heads that helped the 440 and TT440 will become the bottleneck in the build. Torque will be fierce but there's no way these heads will support over 600 hp naturally aspirated. The heads will likely limit rpm to something around 5500 before they strangle things. That's fine because piston speed will be excessive with the 4.5" stroke. I'm not going all out. This will still be a relatively mild mannered build compatible with power brakes and a stock-ish converter. However, with the inches I can get away with a bit more cam. The Headman headers I was looking at are going to be too small so I'll likely have to call TTI for something that fits properly and can handle the flow. There's plenty of room under the car for 3" exhaust. It will be fun getting back to my maniacal side with something as absurd as an early 70s land yacht. Imagine the look on Mr Mustang's face when this old dinosaur picks on him. It's the Imperial! I'll be ahead of him and behind him at the same time. I might be able to squeeze out 10 mpg if I behave myself. The OD would still be handy but could lead to bad ideas. The Imp was not designed for high speeds but it would certainly be capable. I'm not always on my best behavior as witnessed by my jaunt to the high side of 160 mph in the half-pint AMG this week.
Re: So i did a thing today. The Imperial will thank me.
[Re: feets]
#2830962
10/09/20 10:01 PM
10/09/20 10:01 PM
Posts: 20,175 Park Forest, IL
slantzilla
Park Forest, IL
Sounds like a great project!
[Re: slantzilla]
#2830982
10/09/20 11:08 PM
10/09/20 11:08 PM
Posts: 4,740 Star Idaho
67vertman
Star Idaho
Good deal Feets! You are going to love the Old school feel of an RB big block!
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#2830988
10/09/20 11:25 PM
10/09/20 11:25 PM
Posts: 43,539 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Good to hear! Why not twin turbo's...LOL
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2830990
10/09/20 11:31 PM
10/09/20 11:31 PM
feets
Senior Management
Senior Management
Irving, TX
Good to hear! Why not twin turbo's...LOL You don't know how many times I've heard that already. I've got to keep a hint of normalcy to this thing and get it going again. There's another project waiting on me and I really want to start on it.
[Re: feets]
#2831002
10/10/20 01:50 AM
10/10/20 01:50 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Overdrive, period. If a 5000+ pound 488 cu in 2wd V10 with 3.54's can get 15 mpg on the highway, so should the 440.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2831018
10/10/20 07:11 AM
10/10/20 07:11 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Overdrive, period. If a 5000+ pound 488 cu in 2wd V10 with 3.54's can get 15 mpg on the highway, so should the 440. Overdrive, Diff ratio, Low rolling resistance tires, Air Fuel ratio higher than 14.7, or alternatively custom controlled EGR, can raise the fuel economy of a “Torque Monster” engine choice. Nearly invisible aerodynamic tweaks underneath the car can help MPG too.
[Re: GoodysGotaCuda]
#2831038
10/10/20 08:58 AM
10/10/20 08:58 AM
feets
Senior Management
Senior Management
Irving, TX
EFI + OD will seal the deal! I'm going to mock up the factory intake, carb, and air cleaner for measurements. If the intake off the hot rod will fit it'll go on. The Holley Quadrajet Sniper won't feed this thing.
[Re: Twostick]
#2831096
10/10/20 11:49 AM
10/10/20 11:49 AM
feets
Senior Management
Senior Management
Irving, TX
The Sniper Xflow is good for 800 hp. The Quadrajet one claims 650 hp.
Kevin According to the Holley site the Q-jet only holds 500.
[Re: feets]
#2831244
10/10/20 05:37 PM
10/10/20 05:37 PM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin According to the Holley site the Q-jet only holds 500. I saw it on a chart from their website which of course I can't find now... lol Is there a reason you were going with the spread bore? The 4150 series seems to start at 650 hp and goes north from there. Kevin
[Re: Twostick]
#2831247
10/10/20 05:45 PM
10/10/20 05:45 PM
feets
Senior Management
Senior Management
Irving, TX
Kevin According to the Holley site the Q-jet only holds 500. I saw it on a chart from their website which of course I can't find now... lol Is there a reason you were going with the spread bore? The 4150 series seems to start at 650 hp and goes north from there. Kevin I wanted the sound of a TQ at full song. No other reason.
[Re: feets]
#2831258
10/10/20 06:02 PM
10/10/20 06:02 PM
Twostick
Still wishing...
Still wishing...
Kevin According to the Holley site the Q-jet only holds 500. I saw it on a chart from their website which of course I can't find now... lol Is there a reason you were going with the spread bore? The 4150 series seems to start at 650 hp and goes north from there. Kevin I wanted the sound of a TQ at full song. No other reason. The 2x4 system should be close. Kevin
[Re: feets]
#2831296
10/10/20 07:31 PM
10/10/20 07:31 PM
Posts: 31,021 Oregon
AndyF
EFI + OD will seal the deal! I'm going to mock up the factory intake, carb, and air cleaner for measurements. If the intake off the hot rod will fit it'll go on. The Holley Quadrajet Sniper won't feed this thing. You will most likely be fighting hood clearance the whole time. Probably need to use a Holley Strip Dominator intake with a Sniper XFlow to feed that engine.
[Re: AndyF]
#2831310
10/10/20 08:07 PM
10/10/20 08:07 PM
McCandlessboy
