Pistons, what brand, what options?
#2830144
10/07/20 08:53 PM
10/07/20 08:53 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have my name on a World aluminum block, and may buy new pistons to best match the combo. I talked to Ross pistons today and got some ideas. For sure what i want is .043 , .043, 3mm low tension rings, gas ports and skirt coatings. Ed at Ross suggested .200 wall pins from tool steel. This will be the same configuration, 550 cubes, 15/1 compression. What piston brands are good, and any options i should consider?
Re: Pistons, what brand, what options?
[Re: gregsdart]
#2830154
10/07/20 09:48 PM
10/07/20 09:48 PM
Posts: 4,457 Washington
madscientist
Washington
I like the last 10 or so sets of Ross pistons I’ve seen. They are at least as good as anything else, and better than a bunch of stuff.
Before I picked a ring pack, I’d call Total Seal and ask THEM what they think you should run for rings. IMO, and .043/.043 ring pack is a bit thick, even on a bracket engine. I’d let them pick the ring pack and rings.
[Re: madscientist]
#2830220
10/08/20 07:59 AM
10/08/20 07:59 AM
Posts: 1,051 The Great White North
RAMM
I would call Diamond and have a convo with Ron--He's a Mopar guy and has good advice and experience. Or I see Mahle Motorsports now has a Custom department which I am looking forward to using. J.Rob
Ron Beaubien - Senior Sales Representative rbeaubien@diamondracing.net Phone: 586-792-6620 x 6125 Location: Austin TX Strengths: 20+ years with Diamond Pistons, specializes in Mopar, factory replacement, drag racing and circle track applications.
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: gregsdart]
#2830225
10/08/20 08:23 AM
10/08/20 08:23 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
You might consider Gibtec in Denver. They are part of V Gaines' Western Motorsports group in Denver. The group includes Winberg Cranks, GRP Rods, etc.
You also might want to consider Total Seals "gas ported rings". Dyno tests show they can make more power than gas ports.
[Re: 340Cuda]
#2830255
10/08/20 09:55 AM
10/08/20 09:55 AM
Posts: 4,704 Wichita
GY3
Wichita
https://www.speed-talk.com/forum/viewtopic.php?t=60301Call Rebco in Wichita, KS and see what they recommend. They do pistons for a lot of high end racers. REBCO MACHINE, INC. 1100 W. 37TH STREET N. WICHITA, KANSAS 67204 Phone 316-440-2828 Fax 316-440-2849 Email ERICHENKE@REBCOMACHINE.KSCOXMAIL.com
[Re: merpar]
#2830363
10/08/20 01:12 PM
10/08/20 01:12 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
Greg, I would call Icon pistons. They have the best slipper design in the business Not even close
[Re: gregsdart]
#2830367
10/08/20 01:19 PM
10/08/20 01:19 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I'd talk with Todd. You are already getting the block from him. He won't steer you wrong. He is doing my KB wedge and going with Diamond pistons on my build. I have heard that many of the piston suppliers are way behind due to the shut down.
Ok
[Re: cudatom]
#2830400
10/08/20 02:21 PM
10/08/20 02:21 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
[Re: LSP]
#2830492
10/08/20 06:00 PM
10/08/20 06:00 PM
Posts: 294 Nevada
merpar
Nevada
[Re: merpar]
#2830502
10/08/20 06:23 PM
10/08/20 06:23 PM
Posts: 2,527 PA
moparacer
PA
I have used Ross, Diamond, JE, and the Weisco's in my engine now have been to hell and back.
Never had any problems.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: gregsdart]
#2830913
10/09/20 07:18 PM
10/09/20 07:18 PM
Posts: 903 Saskatchewan, Canada
cudabin
Greg, I used Diamond pistons and they have a dome shaped to match the Indy 440-1 heads which might help in a high compression build... Work good for me!
Good Luck, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: Scully]
#2831070
10/10/20 10:41 AM
10/10/20 10:41 AM
madscientist
Washington
A household name at one of the big engine parts companies told me that Ross makes a lot of pistons for some of the other piston companies, he made me promise not to say he said it. LOL...glad you can keep a secret!!!!!
[Re: LSP]
#2831085
10/10/20 11:21 AM
10/10/20 11:21 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
Let's see a picture of the "best in the business" slipper style piston, then I'll show you mine. OMG, another mine is better than yours I've used a bunch of different piston makers in my long engine building and racing career, some where not as good as others but I know now to you buy a custom race piston for a race motor and not to buy a expensive race piston for a street and strip motor I placed a order for a set of Probe shelf pistons for a pump gas RB motor with the Summit several years back, Summit racing side told me they would be drop shipped directly to me in 3 to 6 weeks. 10 months later I called Probe and ended up talking to another holding company who had bought them out along with several other SO CA piston companies, I got them several weeks later and they where made by Auto Tec I've had really good luck with Icon on pump gas street motors Quality product at a reasonable price
[Re: LSP]
#2831352
10/10/20 09:50 PM
10/10/20 09:50 PM
Cab_Burge
He said "best in the business", I'd like to see it is all I did not key on that or realized that had been said
[Re: Cab_Burge]
#2831654
10/11/20 06:19 PM
10/11/20 06:19 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
I prefer CP personally, but have a relationship there too. I have used Diamond and Ross in the past. Use Rebco for some stuff, usually changes or further profiling made after manufacture. Yes even with molds or digitized chambers sometimes stuff changes slightly and needs addressed. But we are talking ultra high compression stuff. Been to the Gibtec facility and it is very nice and they do a fair number of billets for Pro Stock and Pro Stock bike.
