55 dodge 1/2 ton truck Disk brake conversion? #2830149
10/07/20 09:19 PM
10/07/20 09:19 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I should have the 55 home this weekend. Oklahoma farm truck. Ugly enough to be cute. Bought it for the wife and needs a lot of work. The frame is solid. Want to put disks on front and looking for advice. Straight axel on front. Have heard of guys installing a frame from a newer model but not sure I want to go that route. Any thoughts or ideas on what should be done?
Thanks, Kevin
Re: 55 dodge 1/2 ton truck Disk brake conversion? [Re: dart67] #2830423
10/08/20 02:59 PM
10/08/20 02:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 55 dodge 1/2 ton truck Disk brake conversion? [Re: John_Kunkel] #2830635
10/09/20 05:05 AM
10/09/20 05:05 AM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Hey,John. Do you kno if they will fit inside 14 inch rims?
Re: 55 dodge 1/2 ton truck Disk brake conversion? [Re: dart67] #2830650
10/09/20 07:51 AM
10/09/20 07:51 AM
E
earlymopar Offline
earlymopar  Offline
E
I doubt that they will clear, at least not without grinding clearance in some areas. I have the same caliper on my 65 and had to clearance to outside corners and this is on 15" wheels.
Re: 55 dodge 1/2 ton truck Disk brake conversion? [Re: dart67] #2830791
10/09/20 12:53 PM
10/09/20 12:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ask them. tech@scarebird.com
