headlight relocation ??? #282995
04/09/09 08:16 PM
04/09/09 08:16 PM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
does anyone see any reason why i couldnt mount my headlight buckets where the horn covers are sposed to be on my 36 dodge anyone done this any tips
Re: headlight relocation ??? [Re: leavitt4] #282996
04/09/09 08:58 PM
04/09/09 08:58 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Headlight buckets where the horn covers are is where stock 36 Plymouth buckets are mounted. Get a couple of Plymouth mounts and buckets, it should work. Notice the location of the mounting bolts on the Plymouth buckets. Compare to the Dodge.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: headlight relocation ??? [Re: leavitt4] #282997
04/09/09 08:59 PM
04/09/09 08:59 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Buckets and mounts
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: headlight relocation ??? [Re: 36PLYM] #282998
04/09/09 09:15 PM
04/09/09 09:15 PM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
im thinkin cutting the opening a lil wider in the fender and moulding my headlight buckets in with the fender you know trim here weld there a lil grinding there tada done
