Grr! Split cylinder, head damage!
#2828376
10/03/20 06:37 PM
10/03/20 06:37 PM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have a caved in #2 cylinder and a torched cylinder head to deal with now. Not sure why this happened, but I remember the starter baulking once. So, did the gasket fail, then hydro lock the cylinder? Thats what i assume. Makes me wonder if the surface finish was right for cometic gasket? The bad spot on the head is very shallow, like maybe .002 deep but still will have to be fixed. I hope they don't have to cut both heads to fix this. The block is fine on the deck surface luckily.
Re: Grr! Split cylinder, head damage!
[Re: gregsdart]
#2828380
10/03/20 06:52 PM
10/03/20 06:52 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Did the gasket fail in the area adjacent to the crack in the cylinder?
Hard to tell by looking st a pic on my phone....... and it may not have anything to do with the failure........ but the machining marks in the gasket look coarser than what I’d do for a MLS gasket.
I’d also look at the relationship between the gasket bore and the cylinder bore....... to be sure the edge of the gasket bore was definitely not hanging into the cylinder bore...... at all.
[Re: Clanton]
#2828413
10/03/20 08:12 PM
10/03/20 08:12 PM
gregsdart
Not sure what happened. It may have gotten too much fuel in the cylinder from the primerplus gasoline system. I have a 5 psi oil pressure switch for safety but also use an acumulater to prelube, which would allow fuel to pump into the motor if i turned the primerplus switch on before i prelubed.
[Re: gregsdart]
#2828921
10/05/20 12:59 PM
10/05/20 12:59 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Was it a new gasket or a reuse? Have seen a couple Cometic failures of late but with in the "firing ring" area of the gasket not a water jacket? The head surface finish sure seems a tad "rough" but could just be the pic..FWIW we actually use a bit of Hylomar around the water jackets on the ends. Hopefully wont be to spendy to get fixed up.
[Re: Al_Alguire]
#2828954
10/05/20 02:28 PM
10/05/20 02:28 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Did the raised embossing of the head gasket's compression ring area fall into an un-compressed area... of the head chamber? I've seen that on various engines ... and then the gasket cannot seal compression.
Also, it looks as though the surface finish is very rough... far greater than what is required for MLS gaskets (requires near glass-smooth... and sometimes the machine shops simply can't get that surface finish without spending careful time doing it... on both the deck and head surfaces, not just the head surface as is commonly brought to the shop).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Cab_Burge]
#2828994
10/05/20 04:40 PM
10/05/20 04:40 PM
gregsdart
A couple of things; those areas that look like corrosion are actually depressions in the bore that are DEEP. And the one further down the bore is a crack you can catch a fingernail on. Also look at the fire ring of the gasket itself. It looks narrower close to the water jacket. That would indicate it wasn't squeezed enough ; improper(low) torque or a warped block? There is no corrosion anywhere. I cleared the motor with gasoline before putting it away for the day to eliminate corrosion.
[Re: Cab_Burge]
#2829556
10/06/20 09:25 PM
10/06/20 09:25 PM
Posts: 2,498 PA
moparacer
PA
I see corrosion around the rings in that cylinder in the last photo from sitting and maybe condensation in that cylinder while sitting, no cracks in a cylinder I see Sorry for your problems, I hate Murphy That is from methanol laying in the cylinders. I have seen that enough times over the years. The only way I ever got that to stop is to put a gas primer on my car and run it on gas to clean the cylinders out at the end of the day.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2829634
10/07/20 07:41 AM
10/07/20 07:41 AM
Posts: 16,925 NC
440Jim
NC
Does running top end lube in the methanol help at all? I see Greg did use a gas primer system, including at the end of the day to clear the engine.
[Re: Al_Alguire]
#2829655
10/07/20 09:09 AM
10/07/20 09:09 AM
Posts: 4,048 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Was it a new gasket or a reuse? Have seen a couple Cometic failures of late but with in the "firing ring" area of the gasket not a water jacket? The head surface finish sure seems a tad "rough" but could just be the pic..FWIW we actually use a bit of Hylomar around the water jackets on the ends. Hopefully wont be to spendy to get fixed up. Agree surface APPEARS a little rough...when in doubt, lap the surface. ALSO, i always use some type of sealer around water...anaerobic, hylomar, even pipe dough sparingly sometimes. I'm sorry for the bad luck here Greg. Hope you an piece it back together economically reasonable.
[Re: gregsdart]
#2829659
10/07/20 09:12 AM
10/07/20 09:12 AM
Posts: 4,457 Washington
madscientist
Washington
A couple of things; those areas that look like corrosion are actually depressions in the bore that are DEEP. And the one further down the bore is a crack you can catch a fingernail on. Also look at the fire ring of the gasket itself. It looks narrower close to the water jacket. That would indicate it wasn't squeezed enough ; improper(low) torque or a warped block? There is no corrosion anywhere. I cleared the motor with gasoline before putting it away for the day to eliminate corrosion. I can’t remember for sure if you have an aluminum block (I'm pretty sure you do) so whenever I do an all aluminum engine I torque the heads from the OUTSIDE in, not from the inside out. I forget who taught me that because it’s been 25 or 30 years, but it’s still the way I do it.
[Re: 440Jim]
#2829847
10/07/20 02:48 PM
10/07/20 02:48 PM
gregsdart
No Jim, it is closer to the top. Al, new gasket. I was told it could have been caused by a register dowel being too tight
[Re: gregsdart]
#2829887
10/07/20 03:31 PM
10/07/20 03:31 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Iron megablock. I don' t think it is going to be cheap😢we will see. Is that a end cylinder or not? I have had a bunch of stock blocks sleeved for different reasons, I ended up learning that you can sleeve a block like yours two ways, pressed in with a press in interference fit from .0025 to .0040 or chilling the sleeve in dry ice and heating the block up enough to allow the cold sleeve drop in or be push in by hand with a .00010 to .0010 interference fit. The pressed in with the tighter fit can and may affect the cylinder wall shape on the cylinders beside it which may need a lot of honing to make them round again . I now plan on installing all four sleeves on the side needing the sleeve unless I'm going to have it bored and honed to the next over size and buy new pistons Either way make sure and use a good sleeve sealer on the sleeves that go in all the cylinder that have cracks in them
[Re: Cab_Burge]
#2830043
10/07/20 05:16 PM
10/07/20 05:16 PM
gregsdart
Thanks Cab. I have decided that it makes sense to go to a new block. I have always wanted to go aluminum and i am using this as my excuse. I assume there is some value in the megablock since it can be sleeved. I talked to Todd at Marsh performance and have my name on a World aluminum block that is on its way to Todd.
[Re: moparacer]
#2830166
10/07/20 10:20 PM
10/07/20 10:20 PM
gregsdart
Again, there is no corrosion in the bores. This motor has never been shut down for the day until it was run for several seconds on gasoline and still very warm, like above 180. It had dyno pulls on it and eight passes total after being honed and reringed. What may look like corosion is a depression you can feel, it is that deep. The cylinderwall colapsed.
[Re: 440Jim]
#2830480
10/08/20 05:22 PM
10/08/20 05:22 PM
Posts: 2,498 PA
moparacer
PA
Does running top end lube in the methanol help at all? I see Greg did use a gas primer system, including at the end of the day to clear the engine. I dont think lube makes much of a difference Jim. They are more like stains that look worse than they actually are. I found that just shutting the alky off and running on the primer isn't enough. Seems like fuel will still be left in the barrel valve, lines and nozzles and drain and drip into the engine. After I have run mine for a few minutes I blip the throttle several times before I shut it off.
