440 Milodon Pan Rubbing
#2827259
10/01/20 10:06 AM
10/01/20 10:06 AM
Posts: 568 Ormond Beach, FL
71STROKERFISH
Ormond Beach, FL
Added a stock Milodon 4 qt oil pan and windage tray to my 440 installed in a 70 Superbird. Now, the steering center link rubs the pan. The pan is visibly a bit deeper versus the stock pan. Any thoughts here? Look at the motor mounts and they look ok...
-Dc
-dc SOUTHERNPLAINSMOPAARFEST.COM 2018 Jeep Trackhawk 1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997 1971 Barracuda, 414ci, 6bbl Fitech, 727 1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: 440 Milodon Pan Rubbing
[Re: AndyF]
#2827275
10/01/20 10:23 AM
10/01/20 10:23 AM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A repop “402” pan from Mancini is probably a better fit.
[Re: 71STROKERFISH]
#2827285
10/01/20 10:44 AM
10/01/20 10:44 AM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
-Dc
Ugh. That's frustrating.
[Re: BSB67]
#2827296
10/01/20 11:03 AM
10/01/20 11:03 AM
71STROKERFISH
Ormond Beach, FL
I'm planning to get it all the way on the ground and see what it looks like. It's on my friends chassis lift now. I know it wasn't hitting the stock dented pan when I started this clutch, oil pan, windage tray, trans, shock, rear main seal, Dana pinion/cover seal, plugs, valve cover job......LOL! Amazing what needs replaced once its visible and at eye level...LOL!
Tom at Milodon has been pretty helpful and having just talked to him, he mentioned a motivational apparatus....like a hammer....soo.., I guess we'll see....
Oh, also the rear of the engine is not being supported....so maybe some clearance will be gained when the trans goodies are reinstalled....TBD...
-DC
[Re: 71STROKERFISH]
#2827356
10/01/20 12:30 PM
10/01/20 12:30 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
Oh, also the rear of the engine is not being supported....so maybe some clearance will be gained when the trans goodies are reinstalled....TBD... That was my first thought when you mentioned all the stuff you were changing and YES you must install the trans and crossmember before you worry about the pan hitting the centerlink..
[Re: GomangoCuda]
#2827358
10/01/20 12:35 PM
10/01/20 12:35 PM
fast68plymouth
So. Burlington, Vt.
Oh, also the rear of the engine is not being supported....so maybe some clearance will be gained when the trans goodies are reinstalled....TBD... That was my first thought when you mentioned all the stuff you were changing and YES you must install the trans and crossmember before you worry about the pan hitting the centerlink.. Uumm....yeh.
[Re: fast68plymouth]
#2827384
10/01/20 01:54 PM
10/01/20 01:54 PM
71STROKERFISH
Ormond Beach, FL
Yep...Been laboring on this sucker for 2 weeks solo and needed to step back and think about it after last night....Yep...I'll get her squared away and report back...last pan I did I was on my back, in the grass and trans was installed.....and it never leaked.....LOL!!
I cannot wait to feel the new clutch/PP and not hear THROWOUT bearing to howl anymore!
-DC
[Re: AndyF]
#2827925
10/02/20 02:49 PM
10/02/20 02:49 PM
71STROKERFISH
Ormond Beach, FL
Doing that for sure!
Thanks!
[Re: TC@HP2]
#2827940
10/02/20 03:18 PM
10/02/20 03:18 PM
Posts: 4,727 Florida
BDW
Agree with the above and would also add that once everything is together and if you still have interference, perhaps adjusting the steering box and idler to lower the center link can gain you clearance without bashing the pan. How is this done?
