Data Loggers
#2825885
09/28/20 01:12 AM
09/28/20 01:12 AM
Posts: 6,149 Melbourne , Australia
LA360
A question that has been asked a lot I know, but I am looking at getting a data logger for the car I am building. I was looking initially at a data logging dash, but am really open to anything really. A friend even suggested I look at EFI ECU's
What have you used? My combo is a Dodge R5 in an early Valiant
Thanks in advance
Alan Jones
Re: Data Loggers
[Re: Mopar_Rich]
#2825977
09/28/20 10:59 AM
09/28/20 10:59 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I agree that with the cost of the data loggers using an ECU to makes sense. Lots of capable options out there. I went the assemble your own route in 2015 and couldn't be happier for money invested vs features. I had it apart this weekend to add wires for the canbus to work, I never thought I would need it when I built it but now I need it to use a digital readout. The gauge I wanted to add https://www.diyautotune.com/product...-AIzpuNhyhhDTIelM41oQF8RdDEaAs-LEALw_wcB
68 Barracuda Formula S 340
Re: Data Loggers
[Re: Bad340fish]
#2826010
09/28/20 12:46 PM
09/28/20 12:46 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I have the Holley HP, and the Holley 7" dash Thank you Mopar_Rich, works AWESOME, Going LEAN on the hit,
Re: Data Loggers
[Re: CSK]
#2826013
09/28/20 12:49 PM
09/28/20 12:49 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Im old school I guess with those carb thingies and a Racepak
Re: Data Loggers
[Re: CSK]
#2826201
09/28/20 06:33 PM
09/28/20 06:33 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
I have the Holley HP, and the Holley 7" dash Thank you Mopar_Rich, works AWESOME, Going LEAN on the hit, I also got mine from Rich, going to order one for my other car this winter. Add some squirter shot!
Re: Data Loggers
[Re: Dragula]
#2826218
09/28/20 07:28 PM
09/28/20 07:28 PM
LA360
I am not planning on running EFI, I am old school and will be running a carb (the classes I am looking at running dictate this as well)
Alan Jones
Re: Data Loggers
[Re: CSK]
#2826231
09/28/20 07:44 PM
09/28/20 07:44 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I have the Holley HP, and the Holley 7" dash Thank you Mopar_Rich, works AWESOME, Going LEAN on the hit, Hard to tell from a static screen shot, but to me it looks like you need to put some fuel in the upper map regions at that rpm area. Remember that when the throttle rate of change exceeds your programming value, wideband feedback is suspended. It will never fill in that region because the correction is off when the throttle is whacked. Sorry for the sidetrack of the thread. I also feel that an efi system is a good choice for a data logger.
Re: Data Loggers
[Re: TRENDZ]
#2826241
09/28/20 08:05 PM
09/28/20 08:05 PM
CSK
Pattison Texas
I have the Holley HP, and the Holley 7" dash Thank you Mopar_Rich, works AWESOME, Going LEAN on the hit, Hard to tell from a static screen shot, but to me it looks like you need to put some fuel in the upper map regions at that rpm area. Remember that when the throttle rate of change exceeds your programming value, wideband feedback is suspended. It will never fill in that region because the correction is off when the throttle is whacked. Sorry for the sidetrack of the thread. I also feel that an efi system is a good choice for a data logger. Thanks, long since been corrected, I posted this screen shot to show the usefulness of data logging
Re: Data Loggers
[Re: LA360]
#2826342
09/29/20 07:01 AM
09/29/20 07:01 AM
Posts: 176 Down under
slantman
Down under
I am not planning on running EFI, I am old school and will be running a carb (the classes I am looking at running dictate this as well) I’m in the same boat as you, and I’m using a Comptech Datamax logger with the associated digital dash. Works good, easy to install and use, and was reasonably priced too.
Re: Data Loggers
[Re: LA360]
#2826374
09/29/20 09:40 AM
09/29/20 09:40 AM
Al_Alguire
Las Vegas
I am not planning on running EFI, I am old school and will be running a carb (the classes I am looking at running dictate this as well) IMO the Racepak stuff has been around a long time and can do whatever you want it to do. We have them in both cars and both have dashes. Dragster is a Sportsman with an IQ3 dash and the Stratus is a V300sd with a UDX dash. No complaint with either really
Re: Data Loggers
[Re: LA360]
#2826385
09/29/20 10:13 AM
09/29/20 10:13 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I am not planning on running EFI, I am old school and will be running a carb (the classes I am looking at running dictate this as well) RACEPAK!
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
