Data Loggers #2825885
09/28/20 01:12 AM
09/28/20 01:12 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
A question that has been asked a lot I know, but I am looking at getting a data logger for the car I am building. I was looking initially at a data logging dash, but am really open to anything really. A friend even suggested I look at EFI ECU's
What have you used? My combo is a Dodge R5 in an early Valiant
Thanks in advance
Alan Jones
Re: Data Loggers [Re: LA360] #2825961
09/28/20 10:15 AM
09/28/20 10:15 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I hope to get one next year and will probably use a Megasquirt ECU.
I can use it for data logging and then in the future add Coil Near Plug ignition. I can also use the ECU to control fans, fuel pumps and anything else I would like.
While my class does not allow fuel injection I could of course add that later if I wanted to.
Re: Data Loggers [Re: LA360] #2825971
09/28/20 10:40 AM
09/28/20 10:40 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Hard to beat the Holley EFI for both power and ease of use.
Re: Data Loggers [Re: Mopar_Rich] #2825977
09/28/20 10:59 AM
09/28/20 10:59 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I agree that with the cost of the data loggers using an ECU to makes sense. Lots of capable options out there.
I went the assemble your own route in 2015 and couldn't be happier for money invested vs features. I had it apart this weekend to add wires for the canbus to work, I never thought I would need it when I built it but now I need it to use a digital readout.
The gauge I wanted to add https://www.diyautotune.com/product...-AIzpuNhyhhDTIelM41oQF8RdDEaAs-LEALw_wcB
68 Barracuda Formula S 340
Re: Data Loggers [Re: Bad340fish] #2826005
09/28/20 12:27 PM
09/28/20 12:27 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I went the Holley Pro Dash route and that connected to my Holley Sniper Stealth...I like it a lot.
Re: Data Loggers [Re: Bad340fish] #2826010
09/28/20 12:46 PM
09/28/20 12:46 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the Holley HP, and the Holley 7" dash Thank you Mopar_Rich, works AWESOME, Going LEAN on the hit,
Re: Data Loggers [Re: CSK] #2826012
09/28/20 12:48 PM
09/28/20 12:48 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Check the number of inputs you need. Buy Fueltech FT450 or FT550.
1973 Brasilian Dart
E100, boosted 390"
Re: Data Loggers [Re: CSK] #2826013
09/28/20 12:49 PM
09/28/20 12:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Im old school I guess with those carb thingies and a Racepak
Re: Data Loggers [Re: Al_Alguire] #2826054
09/28/20 02:13 PM
09/28/20 02:13 PM
AndyF Offline
AndyF  Offline
A Holley Sniper is around $1000 and it comes with built in data logging. The Sniper is limited to the number of channels it can data log but it is still more data logging than most people have and the Sniper doesn't cost much more than high quality race carb.
Re: Data Loggers [Re: CSK] #2826201
09/28/20 06:33 PM
09/28/20 06:33 PM
Dragula Offline
Dragula  Offline
I also got mine from Rich, going to order one for my other car this winter.
Add some squirter shot!
Re: Data Loggers [Re: Dragula] #2826218
09/28/20 07:28 PM
09/28/20 07:28 PM
LA360 Offline OP
LA360  Offline OP
I am not planning on running EFI, I am old school and will be running a carb (the classes I am looking at running dictate this as well)
Alan Jones
Re: Data Loggers [Re: CSK] #2826231
09/28/20 07:44 PM
09/28/20 07:44 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Hard to tell from a static screen shot, but to me it looks like you need to put some fuel in the upper map regions at that rpm area.
Remember that when the throttle rate of change exceeds your programming value, wideband feedback is suspended. It will never fill in that region because the correction is off when the throttle is whacked.
Sorry for the sidetrack of the thread.
I also feel that an efi system is a good choice for a data logger.
Re: Data Loggers [Re: TRENDZ] #2826241
09/28/20 08:05 PM
09/28/20 08:05 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thanks, long since been corrected, I posted this screen shot to show the usefulness of data logging smile
Re: Data Loggers [Re: LA360] #2826342
09/29/20 07:01 AM
09/29/20 07:01 AM
Down under
slantman Offline
slantman  Offline
Down under
I’m in the same boat as you, and I’m using a Comptech Datamax logger with the associated digital dash. Works good, easy to install and use, and was reasonably priced too.
Re: Data Loggers [Re: LA360] #2826374
09/29/20 09:40 AM
09/29/20 09:40 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO the Racepak stuff has been around a long time and can do whatever you want it to do. We have them in both cars and both have dashes. Dragster is a Sportsman with an IQ3 dash and the Stratus is a V300sd with a UDX dash. No complaint with either really
Re: Data Loggers [Re: LA360] #2826385
09/29/20 10:13 AM
09/29/20 10:13 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
RACEPAK!
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Data Loggers [Re: Plumb Wired] #2826491
09/29/20 02:55 PM
09/29/20 02:55 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
^^^^ RACEPAK^^^^
