09/24/20 08:52 PM
09/24/20 08:52 PM
florida dade
cesar perez Offline OP
florida dade
What hp rating on indy 600-13 heads
Re: 600-13 [Re: cesar perez] #2824755
09/24/20 09:27 PM
09/24/20 09:27 PM
Depends on which short block and N/A or power adder, doesn't it work whistling stirthepot grin
I'm thinking near or maybe a tiny bit better than B1s, 1000 HP + N/A with 500 + C.I.up
Re: 600-13 [Re: Cab_Burge] #2824802
09/24/20 11:30 PM
09/24/20 11:30 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
The 655s will make around 1150 but that is a total effort engine. Jesel, Belt drives, Titanium every thing, $$$$$$$ The only block that they will work on is a spread bore INdy. Very picky heads. I know that Todd Godwin was working on them to get them better but not sure how he did. Not for the faint of heart or wallet.
Todd
Re: 600-13 [Re: cesar perez] #2824860
09/25/20 09:24 AM
09/25/20 09:24 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
Hey Cesar..
I have a supercharged Indy billet headed HEMI engine, fresh and ready to run that makes about 2300 hp that will twist your Dart real good if you are interested callme
Randy
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: 600-13 [Re: Rapid588] #2824876
09/25/20 10:02 AM
09/25/20 10:02 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have a 600-13 engine in the dragster. Far from being anywhere near max effort deal for sure. Compression and cam are on the tamer side for sure. Single 4bbl wet sump deal. Made just short of 1100 on a dyno I know little about as it was the only time we have used it. We have been 7.20's and I believe 185 in Vegas in the summer with it in our suspended dragster. My first go around with these heads. It works well for what it is for sure. No complaints.
Re: 600-13 [Re: Al_Alguire] #2825244
09/26/20 10:06 AM
09/26/20 10:06 AM
Penna
70satelliteguy Offline
Penna
These heads will not work on a MP mega block? I was looking to replace my 572-13's which are getting worn out!
Mike
Re: 600-13 [Re: 70satelliteguy] #2825247
09/26/20 10:18 AM
09/26/20 10:18 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Needs 4.84 bore spacing.
Re: 600-13 [Re: 70satelliteguy] #2825249
09/26/20 10:25 AM
09/26/20 10:25 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
The heads use a 2.400 intake along with a 1.900 exhaust. To get the valves to fit you have to spread the bore centers of the block from 4.800 to 4.840. They start in the back of the block and move the bore center of the block as they machine each hole. To my knowledge Indy is the only block manufacturer that can or will do this. So no on the mega block. You would have to rotate the valves out of alignment like canted valve heads that are available. I guess you MIGHT be able to run smaller valves but then you are talking replacing all the seats. NOT advisable. Todd Godwin was looking into some things on these heads but I am not sure how far he got or what he was looking at doing.
Todd
Re: 600-13 [Re: sasquatch] #2825431
09/26/20 08:51 PM
09/26/20 08:51 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I don't know the gentleman's name (Clinton?) that runs a late 60's blue Dart, he has a set of the Goodwin Competition 600-13 heads on his car?
Alan Jones
