Page 2 of 3 1 2 3
Re: Hood scoop performance .. [Re: Neil] #2824646
09/24/20 04:27 PM
09/24/20 04:27 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Hood scoops are cosmetic
Boffin Emeritus
Re: Hood scoop performance .. [Re: polyspheric] #2824664
09/24/20 05:09 PM
09/24/20 05:09 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Originally Posted by polyspheric
it was picking up SIGNIFICANTLY more air than the engine needed
That's what a supercharger does.
Supercharger forces air into the intake, no amount of scoop is going to creat tangible boost in that way. Youre best bet is you're supplying ample air to the engine and not starving it.
Originally Posted by jcc
Not clear to me in the above example how we know the "Pop up" was from over pressure underneath vs a low pressure above the scoop sucking it up?
Because it occured at the CASS, which I believe was around 42 MPH. No chance, based on the shape of the car, there was enough negative pressure to break the scoop tie downs. A 5" WO67 scoop has a significantly more in^2 than even a pro stock hood. Sealing that scoop to the pan made no sense to me.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Hood scoop performance .. [Re: A39Coronet] #2824681
09/24/20 05:42 PM
09/24/20 05:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
200 mph = 2 psi boost
I saw no remark w/r/t the longer a car is at high speed, the smaller the intake needs to be. Those big scoops are needed for 0-100, not after.
Boffin Emeritus
Re: Hood scoop performance .. [Re: A39Coronet] #2824683
09/24/20 05:49 PM
09/24/20 05:49 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I have seen a 68 SS/AH scoop that was narrowed and the bottom half of the opening was blocked off. I didn't talk to him about what he was going after and if it helped but I think he may have been asked not to bring it back.
Re: Hood scoop performance .. [Re: polyspheric] #2824685
09/24/20 05:55 PM
09/24/20 05:55 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Like I said, no scoop is going to create tangible boost like a blower.
Per Warren Johnson:
“If you plug in the numbers, you’ll find an increase in inlet air pressure of .142 psi at 90 miles-per-hour. Standard atmospheric pressure is 14.7 psi, so this represents an increase of just under 1 percent. If the air/fuel ratio is adjusted to compensate for the increased pressure, there should be a corresponding 1-percent increase in horsepower. For a 1,200-horsepower Pro Stock engine, that’s a gain of 12 horsepower. Hood scoop pressurization increases dramatically at faster speeds: It’s 2 percent at approximately 130 miles-per-hour, and 3 percent at 158 miles-per-hour. At the magical 200 mile-per-hour mark, the theoretical pressure increase is .704 psi, or 4.8 percent. That equals 56 “free” horsepower.
“Unfortunately in racing, just as in life, there is no free lunch. The penalty you pay for this increase in inlet air pressure is the extra aerodynamic drag produced by the hood scoop. A hood scoop is inherently dirty in terms of its aerodynamics. You can minimize the penalty with proper radii and contours, but you can’t get rid of it. And because the scoop has to be large enough to enclose the carburetors and intake manifold, you don’t have much latitude to change its physical dimensions and frontal area.
“From all of my calculations, it’s a wash between the increased horsepower from the ram effect and the higher aerodynamic drag produced by the hood scoop. In other words, though we gain horsepower from the increased inlet pressure, we have to use all of that power just to push the hood scoop through the air.”
Re: Hood scoop performance .. [Re: A39Coronet] #2824693
09/24/20 06:08 PM
09/24/20 06:08 PM
Washington
madscientist Offline
Washington
Per Warren Johnson:
And sadly for WJ, his performance calculations didn’t equate to real life MPH gains. Still today, the MPH is not where it should be for a Pro Stock car factoring in the average gains across the last decade before the scoops were eliminated. Plus, the cars look stupid with that flat hood, and since they aren’t any faster, bring back the hood scoop AND carbs.
Re: Hood scoop performance .. [Re: madscientist] #2824705
09/24/20 06:36 PM
09/24/20 06:36 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
That's probably a sign the decade before the switch was focused on things not induction related but rather ring packs, suspension, and transmissions. I'd imagine those items are all but optimized at this point.
I get their reasons for the switch, those same reasons don't seem consistent with the rest of their program though. However that's another thread for another day.
Re: Hood scoop performance .. [Re: A39Coronet] #2824761
09/24/20 09:39 PM
09/24/20 09:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Easy enough to put a pressure sensor in the scoop.
On just about anything carbureted, the carbs will be thru the hood. Something has to cover them. Why not make it a sealed scoop which will (should) improve performance. If the cowl rear opening type of scoop was effective, I'm sure they would have been in use by the people who had the budget to test such things..
Attention needs to be paid to internal construction to make sure it is pressurized with a minimum of turbulence.
Re: Hood scoop performance .. [Re: CMcAllister] #2824886
09/25/20 10:47 AM
09/25/20 10:47 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
On the 1965 Hemi Belvedere with a factory scoop it picked up two MPH placing the factory plate on the carbs sealing the carbs to the hood on the first pass with the plate. I know in 1972 John Petrie decided to copy his 65 car and put a cookie pan on his doms on the1972 Cuda and it picked up a few MPH and some ET. Next time out most people in Pro Stock started to copy him. The scoop was a Shoe box type old pro stock scoop. I would say some work and some do not. You have to experiment to see why some things work and some things do not.
1971 HEMI E BODY REGISTRY
Re: Hood scoop performance .. [Re: bigdad] #2825021
09/25/20 03:25 PM
09/25/20 03:25 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Have fun!
Boffin Emeritus
Re: Hood scoop performance .. [Re: A39Coronet] #2825029
09/25/20 03:36 PM
09/25/20 03:36 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The "CASS" reference is unclear to me also, and so you stating there was not enough low pressure above the hood/scoop to suck it upwards, but there was enough high pressure air inside the scoop to lift the hood up, the latter which I find nearly unbelievable.
Re: Hood scoop performance .. [Re: jcc] #2825043
09/25/20 04:09 PM
09/25/20 04:09 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
I saw almost a tenth in the quarter mile on my high ten second big block Dart, 68 Hemi Dart scoop.....not sealed vs sealed....back to back passes....When I was engineering the seal set up for that scoop, my buddy assured me that I was wasting my time...He ate crow when it worked......Your results may vary....Test, Test, Test
Curator at Adams County Speed Shop
Re: Hood scoop performance .. [Re: 340man4ever] #2825103
09/25/20 06:55 PM
09/25/20 06:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My 64 Maxwedge ran almost the same with a stock hood as with a sealed Six Pac type. Don’t know why they worked but the rage at that time (70s) where newspaper boxes. They just worked, especially on tunnel rams, just cut carb holes and and long rod to hold them on. Prerunner to the Jimmy Durante nose.
Re: Hood scoop performance .. [Re: cudaman1969] #2825117
09/25/20 07:50 PM
09/25/20 07:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
They were simple with a minimum of fabrication, they were sealed and they were free.
Re: Hood scoop performance .. [Re: jcc] #2825132
09/25/20 08:38 PM
09/25/20 08:38 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Losing a scoop and a hood on two separate occasions renders it the opposite of unbelievable. Do the math, per the article, the scoop was too large and my car picked up without the carb sealed to the hood because the excess air captured by the scoop could escape instead of cause aerodynamic drag.
I'm not telling anyone what scoop to run, I'm sharing my experience. That car won the 2017 TriState Stock/Superstock championship without a carb pan, along with a bunch of Mopar event wins. It worked.
Re: Hood scoop performance .. [Re: A39Coronet] #2825640
09/27/20 01:10 PM
09/27/20 01:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A friend raced a Corvette tube chassis car, light, would run 180 mph in the 1/4. Hood blew off and car became very squirmy on top end almost lost it, lucky the chute helped. Like was said aerodynamics plays big time at that mph
Re: Hood scoop performance .. [Re: cudaman1969] #2825810
09/27/20 08:17 PM
09/27/20 08:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
A friend raced a Corvette tube chassis car that would run 180 mph in the 1/4. Hood blew off and car became very squirmy on top end almost lost it, lucky the chute helped. Like was said aerodynamics plays big time at that mph
iagree
I use to live near El Mirage Dry Lake where Southern California timing Association ran their top end Bonneville type cars during the late fall, winter and early spring months, I went out to watch and ended up asking about what cars needed to go fast out there, I had a 1970 Dodge T/A at that time and I had thought about trying to set a record in stock with that car. The record was right at 175 MPH back then so I did the math on what tire RPM would be needed to run over 175 MPH with a set of 2.76 gears, I ended up not doing it due to the rule about having to have SCTA approve tires on any car going faster than 150.00 MPH back then and I could not buy new ones back then, only used from another racer tsk down twocents
I was told by several old time racers that anyone could go 125 MPH in a lot of stock cars, some could go 150 MPH but it took twice the HP to run 175.00 MPH than it did to run 150.00 MPH shock
They said aerodynamics really came into play above 150 MPH on most race cars work shruggy
Re: Hood scoop performance .. [Re: Cab_Burge] #2825926
09/28/20 08:29 AM
09/28/20 08:29 AM
New York
polyspheric Offline
polyspheric  Offline
New York
About 60% more, varies roughly by the cube of the speed.
Boffin Emeritus
Re: Hood scoop performance .. [Re: polyspheric] #2825989
09/28/20 11:47 AM
09/28/20 11:47 AM
PA
moparacer Offline
moparacer  Offline
PA
I have a couple cars that picked up 1 tenth in the 1/8 and 1.5 tenths in the 1/4 making an air pan and sealing it to the 440 six pack hood.
They run 10.50-11.20 range.
Definitely worth the effort.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Hood scoop performance .. [Re: cudaman1969] #2826048
09/28/20 02:03 PM
09/28/20 02:03 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
I still use a paper box.
America First!
Page 2 of 3 1 2 3
