WC replacement #2823795
09/22/20 07:37 PM
09/22/20 07:37 PM
BDW Offline OP
BDW  Offline OP
Got a leaky rear brake cylinder.
Can this be replaced without completely disassembling the pads and HW?
Remove brake line and mounting bolts and slide new 1 in?
Re: WC replacement [Re: BDW] #2823807
09/22/20 08:03 PM
09/22/20 08:03 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
You will have to at least remove the return springs from the shoes so you can spread the shoes apart far enough to remove the wheel cylinder. If it's leaking the shoes are probably contaminated, I would replace them while it's apart.
