528 cam in a 340 centerline ? #2823472
09/21/20 10:31 PM
09/21/20 10:31 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
who has used this cam 284 / 528 mopar solid in a 340"
has any one used / dinoed this cam in a 340 ?
where did you set the centerline ?
mopar sugest it be 110 deg.
thank you !
Re: 528 cam in a 340 centerline ? [Re: calrobb2000] #2823487
09/21/20 11:36 PM
09/21/20 11:36 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
I'd stick it in between 108 and 110 icl. You have a loose converter,4.30 gear and compression? Right?
Re: 528 cam in a 340 centerline ? [Re: J. Hammer] #2823496
09/22/20 12:07 AM
09/22/20 12:07 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
not nearly enough info. Buy an engine program, lots of them out there, put in all your specs, a lot more informed answer. Plus you can spend hours and hours building virtual engines you can never afford. Plus you will be surprised how much you can learn, just by understanding the specs you input and why the program needs them to do the calculations.
Re: 528 cam in a 340 centerline ? [Re: calrobb2000] #2823498
09/22/20 12:21 AM
09/22/20 12:21 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i ran one in my with 9.5:1 compression and 340 x heads that were ported. really ran well never got it on the dyno but had plenty of torque down low and lots of pull in the mid range.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 528 cam in a 340 centerline ? [Re: Jerry] #2823504
09/22/20 01:15 AM
09/22/20 01:15 AM
CA
crackedback Offline
crackedback  Offline
CA
Stock compression 340 I installed mine at 107 IIRC. Runs hard with plenty of grunt!
4 speed car and had 3.91's for a while, now has 3.23 with a 26" tire on it. Car moves really well.
