TTI's and column shifts? #2823112
09/20/20 11:07 PM
09/20/20 11:07 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
What is the modification needed to run 440 TTI's with a column shift in a B-body? I can't seem to find the answer or pics anywhere.
Re: TTI's and column shifts? [Re: Jeff_383] #2823414
09/21/20 07:48 PM
09/21/20 07:48 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
None on my 67'
Re: TTI's and column shifts? [Re: PossessedDuster] #2823435
09/21/20 08:19 PM
09/21/20 08:19 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
2" Tubes? Regular old column shift?
Then why does their website say no, without modifications?
Re: TTI's and column shifts? [Re: Jeff_383] #2823471
09/21/20 10:29 PM
09/21/20 10:29 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
What type of headers? full length, shorties, and size? 3.0" 1 7/8" ??
Call them directly, they always answer the phone. (951) 371-4878 - Mon-Fri, 8am-4pm PST
My Monster are real!
Living within your means makes life pretty easy.
Re: TTI's and column shifts? [Re: 67vertman] #2823490
09/21/20 11:39 PM
09/21/20 11:39 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
It depends on which header you are talking about but mostly it is on the 71-74 B bodies and it requires a linkage that they will sell you or you could make. The linkage and the header want to occupy the same space is the issue. There is a picture of the modification on their website.
Todd
Re: TTI's and column shifts? [Re: Jeff_383] #2823554
09/22/20 10:05 AM
09/22/20 10:05 AM
None
71rm23 Offline
71rm23  Offline
None
Go with 1 7/8" with less "mods".
