Stupid 6.00 Barrier!......w/Vids & Time Slips #2822738
09/19/20 09:04 PM
09/19/20 09:04 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I just can't seem to get it over the damn line.......Steller Air today to boot. Slicks are shot and I need to put a T-stat in to better maintain temp...Hotter is faster....
Off the trailer 6.06at 114.04mph and a near perfect light!
https://www.youtube.com/watch?v=P3ASl852hnU
2nd Time Trial.....6.0022 at 114.62mph
1st round....6.01 at 115.44mph and a Damn -.007 red light....Playing a little too close, should have knocked 1-2psi out of the front tires damit.
https://www.youtube.com/watch?v=vKgihckS-5Q
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: Dragula] #2822759
09/19/20 09:56 PM
09/19/20 09:56 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I feel your pain
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: racerx] #2822773
09/19/20 10:35 PM
09/19/20 10:35 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use to run 6.0 @112mph in my valiant, almost every pass, but we were 1/4 mileing it
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: rebel] #2822785
09/19/20 11:39 PM
09/19/20 11:39 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You are certainly flirting with a 5.
Maybe a little smaller breakfast ? up
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: tubtar] #2822791
09/20/20 12:13 AM
09/20/20 12:13 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have a friend that is like that trying to break into the 10's.
We laugh at him and say he has an 11.0 bracket car. Last week it went 11.03.. rant
'63 Dodge 330
11.19 @ 121 mph
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: Dragula] #2822796
09/20/20 02:56 AM
09/20/20 02:56 AM
Have you found out what RPM it likes to be shifted at to go as fast as it can? If not maybe you should twocents
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: Cab_Burge] #2822805
09/20/20 06:56 AM
09/20/20 06:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have the same problem with the 9.00 barrier. We're going to give it a shot today. Street car is is stuck at the 11.0 barrier as well. Both cars have been within a few thousandths.
Doug
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: dvw] #2822810
09/20/20 07:35 AM
09/20/20 07:35 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
You cut nice
Lights and have a consistent car ! I’d look for some weight . Nice runs !
I did go with a buddy to Lebanon valley yesterday. We got his car from 9.60 to 9.40 just
Playing with rear tire pressure . Added a lb at. Time each pass . It got the 60 from 1,40 to 1.34
. Your 60 looks good though
....BAD A$$ STREET CAR.....
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: n20mstr] #2822829
09/20/20 09:34 AM
09/20/20 09:34 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I'll keep some eyes coffeeon this thread and see what it takes to push it into those 5's
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: racerx] #2822857
09/20/20 10:43 AM
09/20/20 10:43 AM
Dragula Offline OP
Dragula  Offline OP
To get where I am, I put in a Mezeire electric water pump in place of the mechanical one, I jetted the carb up twice yestarday and once a week earlier, I could not find a 4500 by .250 spacer, so I stacked carb gaskets up to get the carb as high as possible and allow for as much plenum as possible, and I have been pushing the timing....And switched to trans brake launches after pushing thru the brakes.
So this caused one unforeseeable problem, the motor likes heat to run fast, I need to add a T-stat back in to get the temp back up to +170.....Right now, getting it over 150 is a chore.
What I have not done, is raised the shift points or the launch rpm....
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: racerx] #2822861
09/20/20 10:52 AM
09/20/20 10:52 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
So close!! Surely you must have a hundredth hidden somewhere...You’ll find it
2 kids and a dog
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: Dragula] #2822876
09/20/20 11:34 AM
09/20/20 11:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Brotherhood of ET chasing bracket racers unite!! laugh2
I’ve had a pretty dang good package car that I’ve screwed up a few times with my “I wonder what this will do?” curiosities....
Question is do you get another swing at it before that nasty “Winter” word sets in??
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: J_BODY] #2822904
09/20/20 01:12 PM
09/20/20 01:12 PM
Dragula Offline OP
Dragula  Offline OP
I think I get one more try at it this coming weekend....Probably going to raise the shift point up...And put a T-stat in it.
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: Dragula] #2823045
09/20/20 08:19 PM
09/20/20 08:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Drain three quarts of oil out of it. grin
'63 Dodge 330
11.19 @ 121 mph
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: GY3] #2823074
09/20/20 09:21 PM
09/20/20 09:21 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Trans fluid in the diff... smile
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: J_BODY] #2823079
09/20/20 09:31 PM
09/20/20 09:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Put a small block in it. whistling biggrin
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: Dragula] #2823453
09/21/20 09:27 PM
09/21/20 09:27 PM
Mo.
racerx Offline
racerx  Offline
Mo.
What fuel do you run and what weight is your a body? I just found the last ticket of 2019 (the last time the car was out and it went a 6.08@113.42) breaking up on top end. Wasn't expecting that shruggy 60' was a 1.36 never got a chance to get out this year. I was working on indexing the rotor and getting back out but never did.
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: justinp61] #2823475
09/21/20 10:49 PM
09/21/20 10:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well I wasn’t going to point out the obvious.... laugh2
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: J_BODY] #2823477
09/21/20 11:03 PM
09/21/20 11:03 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Exactly!
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Stupid 6.00 Barrier!......w/Vids & Time Slips [Re: B3422W5] #2823479
09/21/20 11:06 PM
09/21/20 11:06 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Exactly!
Bingo.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
