Re: Stupid 6.00 Barrier!......w/Vids & Time Slips
[Re: Dragula]
#2822759
09/19/20 09:56 PM
09/19/20 09:56 PM
Posts: 4,068 Mo.
racerx
Mo.
[Re: tubtar]
#2822791
09/20/20 12:13 AM
09/20/20 12:13 AM
Posts: 4,672 Wichita
GY3
Wichita
I have a friend that is like that trying to break into the 10's. We laugh at him and say he has an 11.0 bracket car. Last week it went 11.03..
[Re: dvw]
#2822810
09/20/20 07:35 AM
09/20/20 07:35 AM
Posts: 4,675 On the parachute mount
n20mstr
You cut nice Lights and have a consistent car ! I’d look for some weight . Nice runs ! I did go with a buddy to Lebanon valley yesterday. We got his car from 9.60 to 9.40 just Playing with rear tire pressure . Added a lb at. Time each pass . It got the 60 from 1,40 to 1.34 . Your 60 looks good though
....BAD A$$ STREET CAR.....
[Re: racerx]
#2822857
09/20/20 10:43 AM
09/20/20 10:43 AM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
To get where I am, I put in a Mezeire electric water pump in place of the mechanical one, I jetted the carb up twice yestarday and once a week earlier, I could not find a 4500 by .250 spacer, so I stacked carb gaskets up to get the carb as high as possible and allow for as much plenum as possible, and I have been pushing the timing....And switched to trans brake launches after pushing thru the brakes.
So this caused one unforeseeable problem, the motor likes heat to run fast, I need to add a T-stat back in to get the temp back up to +170.....Right now, getting it over 150 is a chore.
What I have not done, is raised the shift points or the launch rpm....
[Re: racerx]
#2822861
09/20/20 10:52 AM
09/20/20 10:52 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
So close!! Surely you must have a hundredth hidden somewhere...You’ll find it
2 kids and a dog
[Re: Dragula]
#2822876
09/20/20 11:34 AM
09/20/20 11:34 AM
Posts: 13,188 aZLiViN
J_BODY
aZLiViN
Brotherhood of ET chasing bracket racers unite!! I’ve had a pretty dang good package car that I’ve screwed up a few times with my “I wonder what this will do?” curiosities.... Question is do you get another swing at it before that nasty “Winter” word sets in??
[Re: J_BODY]
#2822904
09/20/20 01:12 PM
09/20/20 01:12 PM
Dragula
I think I get one more try at it this coming weekend....Probably going to raise the shift point up...And put a T-stat in it.
[Re: Dragula]
#2823045
09/20/20 08:19 PM
09/20/20 08:19 PM
GY3
Wichita
I think I get one more try at it this coming weekend....Probably going to raise the shift point up...And put a T-stat in it. Drain three quarts of oil out of it.
[Re: J_BODY]
#2823477
09/21/20 11:03 PM
09/21/20 11:03 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Put a small block in it. Well I wasn’t going to point out the obvious.... Exactly!
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2823479
09/21/20 11:06 PM
09/21/20 11:06 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Put a small block in it. Well I wasn’t going to point out the obvious.... Exactly! Bingo.
[Re: Dduster]
#2823960
09/23/20 10:05 AM
09/23/20 10:05 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
What's Your launch rpm? Your challenge to 5's looks to be in 60 ft times. Car runs hard once past 60 ft. New tires? 60' is all over the place.
