lines #2820929
09/15/20 06:33 AM
09/15/20 06:33 AM
indy
70moparmike Offline OP
indy
69 gtx put subframe connectors in and wondered what you guys use now to get the fuel lines back in place? didn't have a option to put in first, went to dippers. have stainless lines and need a remedy to cut and put them back together, and its 1/2 lines. thanks for any help.
Re: lines [Re: 70moparmike] #2821220
09/15/20 06:37 PM
09/15/20 06:37 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
What style connectors...the US Car Tool units that are fully welded to the floor pans or the square stock style? Any photos available of the problem area?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: lines [Re: 70moparmike] #2821265
09/15/20 08:23 PM
09/15/20 08:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If the lines are not annealed you likely will not be able to flare them. Even if they are, flaring 1/2" SS will require a REALLY GOOD flaring tool. Also be aware that cutting annealed SS with a normal tubing cutter will work harden it. Best to use a small chop saw. HF has one that does the job.
Another option is to use Swagelok fittings. They are NICE but pricey. I do have some left over from a previous project .If you decide to go that way PM a list of what you need and I'll see if i have them.
beer
