lines #2820983
09/15/20 10:05 AM
09/15/20 10:05 AM
indy
70moparmike Offline OP
indy
is a 3/8 fuel line big enough to handle a 600 hp engine? what are you using if not? have a snipper fuel pump in tank before you ask and no mechnical pump. have a holley regulator i was going to use a 3/8 line for return also. thanks for any help
Re: lines [Re: 70moparmike] #2820986
09/15/20 10:15 AM
09/15/20 10:15 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I would look at the pump manufacturer's recommendations.
With a BG 240HR pump they wanted -8 delivery and -10 return.
The larger return surprised me , but it makes sense after kicking it around for a while.
3/8th will feed 600 h.p. , but I might like a little larger just because overkill and I are old friends.
Re: lines [Re: tubtar] #2821055
09/15/20 12:40 PM
09/15/20 12:40 PM
indy
indy
my pump says 255 gph but the fittings on the sender is 1/4 npt out of there sender? going to restrict it there anyway?
Re: lines [Re: 70moparmike] #2821093
09/15/20 01:47 PM
09/15/20 01:47 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
With an in-tank pump you will be fine.
I've ran in tank pumps and 3/8 feed line at over 1000rwhp, fwiw.
Re: lines [Re: INTMD8] #2821118
09/15/20 02:38 PM
09/15/20 02:38 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
The bigger the line the bigger the pump to push the fuel up front, inertia
Re: lines [Re: cudaman1969] #2821133
09/15/20 02:58 PM
09/15/20 02:58 PM
iagree
The Magna fuel 275 pump has right at 18 lbs. of bypass pressure, their 300 pump ( I've owned and used both) looks identical to the 275 pump but it has 25 Lbs. of bypass pressure, if I'm remembering correctly now work
Both want a #10 inlet with a #8 outlet, the bypass line from the outlet line on the pump going up to the return line to the tank is a #8 also shruggy
