Page 1 of 3 1 2 3
Valley Pan Inverted #2820504
09/14/20 09:09 AM
09/14/20 09:09 AM
New Jersey, U.S.A.
FuriousMopar1968 Offline OP
New Jersey, U.S.A.
So first a little back story, a while back I was having a little street fun with my boss and had a run with his challenger on an empty highway. I was cruising about 40mph then gave the old girl about a 2/3 throttle blast, it blew the tires loose, and it began immediately walking away from his car revving up to about 6500 RPM 125-130ish MPH. Around that time I felt a little hesitation and an off rhythm, idle cycle then normal, but that had subsided not long after. For the rest of the trip home from work I didn’t think much of it. That is until I got home and did my post trip checks, and saw my Valley pan became a Hill Pan. Naturally, after this discovery I was very confused, still runs great and has a boat load of power. (Literally since it’s a C-Body haha) It sat in storage for a while and I finally was able to get back to starting to diagnose this, but I still come up empty on a cause from the basic external diagnostics I’m able to do in a self storage unit. The car is the build from this post: https://board.moparts.org/ubbthread...-ram-68-fury-build-opinions-welcome.html
Compression Test Results: 1: 160PSI 3: 165PSI 5: 160PSI 7: 165PSI 2: 155PSI 4: 160PSI 6: 150PSI 8: 165PSI
Also no smoke or engine noises heard.
Anyone have anything like this happen to them and figure what it was?
Also should the car still be driven or am I at risk of losing everything in the engine?
Thanks in advance for any and all help.
1968 Plymouth Fury - 440 Dual Quad Tunnel Ram
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820509
09/14/20 09:22 AM
09/14/20 09:22 AM
Pittsburgh, PA
1970440RT Offline
1970440RT  Offline
Pittsburgh, PA
I had the same thing happen to me when I built my first 440. I did not have adequate crankcase venting - to much pressure internally in the motor, you will probably have some oil leaks also from the pressure. Make sure your breathers on the valve covers are installed correctly and not clogged. Should be an easy fix - good luck!
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820568
09/14/20 12:22 PM
09/14/20 12:22 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Had that happen when a few pistons came out in more than 1 piece. Your compression numbers look good to me, so I'd check PCV valve, breather(s), if the breather is big enough, something wrong with the baffles. Anything clogged?
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Valley Pan Inverted [Re: metallicareload] #2820595
09/14/20 01:17 PM
09/14/20 01:17 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Thanks for the replies, this is how my breather and PVC system is ran. Do you see any red flags of how I set it up? Should I ditch the PVC and just run breathers or maybe even one of those crankcase blow off valves?
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820599
09/14/20 01:31 PM
09/14/20 01:31 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Is that a breather or an oil cap on the driver side, still needs more breathers that what you have.
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820602
09/14/20 01:36 PM
09/14/20 01:36 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
internal pressure from a backfire... seen it happen on a new 440-6 engine back in the 70's seems like it took out the fuel pump best i remember ....
Re: Valley Pan Inverted [Re: CSK] #2820603
09/14/20 01:37 PM
09/14/20 01:37 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
That’s a breather, where else can you mount them? The Direct Connection covers only have the 1 hole on each side, or do I have to ditch the PCV for a breather, or lose the DC covers for something else?
Re: Valley Pan Inverted [Re: CSK] #2820604
09/14/20 01:38 PM
09/14/20 01:38 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That's a lot of rubber fuel line. Once you have the valley pan sorted out, I'd start replacing that with hard line or at least braided line.
Re: Valley Pan Inverted [Re: ek3] #2820606
09/14/20 01:40 PM
09/14/20 01:40 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Any idea what would of caused the back fire if the cylinders are sealed with decent compression?
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820608
09/14/20 01:41 PM
09/14/20 01:41 PM
Pattison Texas
Pattison Texas
Pull the breather out & take a picture of the underside for us, & the hole size it goes into
Re: Valley Pan Inverted [Re: burdar] #2820613
09/14/20 01:51 PM
09/14/20 01:51 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Gotcha, would that be for longevity’s sake or am I asking for trouble with something else?
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820618
09/14/20 01:54 PM
09/14/20 01:54 PM
Anchorage, Alaska
Anchorage, Alaska
That's basically the same setup I've been using for years, and aside from from what I mentioned above, I've never had any problems
440, 4-Speed, 3.54
Re: Valley Pan Inverted [Re: CSK] #2820619
09/14/20 01:54 PM
09/14/20 01:54 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
I’ll try and swing by the unit today and get the pictures. Those pictures are from a while ago, but I’m still running the same layout currently just with one of the extended breathers on it just don’t have recents of that.
Edit: I forgot, I also swapped on an old set of Moroso Valve covers we had lying around for one reason or another. This event was about a year ago and it stopped me from driving it any further until I figured out what happened. So it just sits in the unit until. Lights right off with a turn of the key though when I went back to it this past week. Haha
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820626
09/14/20 02:04 PM
09/14/20 02:04 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
I've seen fuel pumps leak internally and cause an explosion in the crankcase. Usually blows a valve cover off but the engines I witnessed did not have a valley pan
Re: Valley Pan Inverted [Re: CSK] #2820689
09/14/20 05:03 PM
09/14/20 05:03 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Here’s the pics. Thanks for helping me out with this!
F6547CF6-30EB-4537-ADB2-9CF9C2A293D1.jpeg68E0D8D9-C42C-4FAF-8D0E-F6F4629F5487.jpegD87FB349-E47B-4169-B03E-ED340919892C.jpeg24A5AC16-D080-410F-8231-E95F6B0731E6.jpeg
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820692
09/14/20 05:13 PM
09/14/20 05:13 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Based on those last pics, it’s not vented nearly enough for an extended WOT blast.
There is likely nothing wrong with the motor, it just needs better venting.
Re: Valley Pan Inverted [Re: fast68plymouth] #2820697
09/14/20 05:19 PM
09/14/20 05:19 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Do you think I should open up the flap on bottom and lose the baffle?
Re: Valley Pan Inverted [Re: FuriousMopar1968] #2820746
09/14/20 07:24 PM
09/14/20 07:24 PM
New Jersey, U.S.A.
New Jersey, U.S.A.
Just to add more info to the situation here’s how the oil looks, doesn’t smell like gas, it’s still thick, and a proper golden. (The little specks/dots in the picture are air bubbles.) Spark plugs are also model citizens.
Re: Valley Pan Inverted [Re: fast68plymouth] #2820850
09/14/20 10:24 PM
09/14/20 10:24 PM
Pattison Texas
Pattison Texas
Yep, I have 3 breathers going to a catch can on my car, no PCV for my set up.
Re: Valley Pan Inverted [Re: fast68plymouth] #2820868
09/14/20 11:10 PM
09/14/20 11:10 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Doesn't it seem like the cap would have blown off before the valley pan deflected that way? shruggy
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Page 1 of 3 1 2 3
