L2355F TRW Pistons- Good Choice?
#2820111
09/12/20 11:27 PM
09/12/20 11:27 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I'm putting together a 78 block, 79 build date, 440 RV motor. Going into a 2wd Ramcharger.
I'm looking to bring the compression up and have a nice respectable cruiser/driver thats got a bit to play with once in awhile.
I found a set of new in the box TRW L2355f pistons. But it seems they are discontinued so specs on them are not easy to find.
They were originally purchased for the guys 70 440 6 pack superbee. But he went with a high compression piston instead.
These have been on a shelf for 20 or more years.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: L2355F TRW Pistons- Good Choice?
[Re: hp383]
#2820162
09/13/20 09:26 AM
09/13/20 09:26 AM
Posts: 4,209 New York
polyspheric
New York
Strong Tall compression distance Heavy
Boffin Emeritus
[Re: hp383]
#2820271
09/13/20 04:23 PM
09/13/20 04:23 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
But it seems they are discontinued so specs on them are not easy to find. Comp height= 2.061" Weight= 872 grams (.030" over) Valve cuts = 7 cc's
[Re: John_Kunkel]
#2820333
09/13/20 06:18 PM
09/13/20 06:18 PM
Posts: 31,049 Oregon
AndyF
But it seems they are discontinued so specs on them are not easy to find. Comp height= 2.061" Weight= 872 grams (.030" over) Valve cuts = 7 cc's Yep, about 1 lb heavier each than a modern piston. We used to build them with these slugs and the bobweight was around 3200 or 3300 grams. Now the bobweight is down in the 2500 gram range for a lot of BB engines that I see.
[Re: AndyF]
#2820351
09/13/20 07:19 PM
09/13/20 07:19 PM
polyspheric
New York
Are you sure? 1 lb. is 454 grams
Boffin Emeritus
[Re: BSB67]
#2820417
09/13/20 09:33 PM
09/13/20 09:33 PM
hp383
State of Confusion
You must not have looked very hard. You can by them anywhere. Summit has them for $370. Not TRW, different brand yes. Wasn't sure if the specs would be the same under a different manufacturer.
[Re: Dan Halen]
#2820418
09/13/20 09:35 PM
09/13/20 09:35 PM
hp383
State of Confusion
These are SpeedPro not TRW. My concern was that a different manufacturer may have made some changes from the TRW specs.
[Re: hp383]
#2820530
09/14/20 10:14 AM
09/14/20 10:14 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Federal-Mogul absorbed TRW probably about 25 years ago.
[Re: hp383]
#2820628
09/14/20 02:05 PM
09/14/20 02:05 PM
polyspheric
New York
Some non brand-name parts are listed with TRW numbers to make identification easier.
Boffin Emeritus
[Re: fast68plymouth]
#2820632
09/14/20 02:13 PM
09/14/20 02:13 PM
hp383
State of Confusion
Thank you for this information. I haven't delt with any performance engine building since the late 90's I'm just trying to get up to speed again. I'm sure I have forgotten a lot, and there's probably a slew of new stuff, or a new different way of doing it that I don't know.
[Re: bobby66]
#2820664
09/14/20 03:40 PM
09/14/20 03:40 PM
fast68plymouth
So. Burlington, Vt.
Looks like the Federal-Mogul/TRW thing happened in 1992.
Then they acquired Sealed Power/Speed-Pro in 1993.
[Re: hp383]
#2820771
09/14/20 08:16 PM
09/14/20 08:16 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I remember when TRW started their name in the early 1960s, I think it stood for Thompson Racing Wholesale One of the local parts stores started pushing the TRW line back then
[Re: Cab_Burge]
#2820788
09/14/20 08:49 PM
09/14/20 08:49 PM
Posts: 3,083 Michigan
A727Tflite
Thompson Ramo Wooldridge.
[Re: dOoC]
#2820849
09/14/20 10:23 PM
09/14/20 10:23 PM
Posts: 6,145 Melbourne , Australia
LA360
If you are doing a complete engine, there are much better pistons out there these days. Unless this guy is practically giving them away, I'd look around a little more.
I have KB pistons in a 360, I used them because I got them for free. A friend had them sitting on his shelf for 10 plus years.
Alan Jones
[Re: dOoC]
#2820867
09/14/20 11:09 PM
09/14/20 11:09 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Any custom piston manufacturer make something SIMILAR to the 2355 as a lite weight? Yes almost all of them have a shelf stock piston that is close to that one only way lighter. I used a set of ross with manley h-beam rods and had a bobweight in the 2400s.
[Re: 4406bbl]
#2820872
09/14/20 11:27 PM
09/14/20 11:27 PM
Posts: 30,450 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Any custom piston manufacturer make something SIMILAR to the 2355 as a lite weight? Yes almost all of them have a shelf stock piston that is close to that one only way lighter. I used a set of ross with manley h-beam rods and had a bobweight in the 2400s. Same CD ? ... flycuts for what cam ? How does the price and weight compare to the heavy ones ? Pin size ?
