Re: Green treated lumber
[Re: blaze]
#2820341
09/13/20 06:48 PM
09/13/20 06:48 PM
Posts: 382 Delta BC, Canada
Baller
Delta BC, Canada
What you need is either Zinc Naphthenate or Copper Naphthenate. The copper will be green in color if matching is important. Many different brands available.
1970 GTX, work in progress...
[Re: Stanton]
#2820635
09/14/20 02:19 PM
09/14/20 02:19 PM
Posts: 13,583 md
mopars4ever
md
[Re: moparmike1]
#2820711
09/14/20 05:51 PM
09/14/20 05:51 PM
Posts: 22,696 Bitopia
jcc
Bitopia
The treatment doesn't penetrate the wood completely from all sides so once you rip the 2x8 to 2x6, the side you cut won't be treated.
You should be able to buy the treatment and brush it on the exposed side.
Mike. I thought the point of "pressure treated" was that solved that penetration issue. I have yet to see much of a color difference with viewing a cross section of cut to length PT board. Are we talking about "new" eco friendly treated wood? The green brush on copper/arsenic treatments I believe are no longer available for sale to the public, or very restricted. My thinking was, the OP had no real concerns to be worried about.
[Re: jcc]
#2820738
09/14/20 07:11 PM
09/14/20 07:11 PM
Posts: 1,834 Sault Ste. Marie, Ontario, Can...
moparmike1
Mike. I thought the point of "pressure treated" was that solved that penetration issue. I have yet to see much of a color difference with viewing a cross section of cut to length PT board. Are we talking about "new" eco friendly treated wood? The green brush on copper/arsenic treatments I believe are no longer available for sale to the public, or very restricted. My thinking was, the OP had no real concerns to be worried about. Based on my experience, the pressure treatment penetrates the surface just enough so that it looks good from the outside. But once a cut is made, you'll see the untreated inner section. All I can say is, if you cut a pressure treated board, you might want to seal that cut with similar treatment to hold off the rot as long as possible. Mike.
[Re: Neil]
#2820772
09/14/20 08:24 PM
09/14/20 08:24 PM
Posts: 8,870 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I built a construction skid sign out of PT wood years ago and after one winter the wood touching the ground was 100% rotted out. A can of Krylon would have been a better moisture barrier than that stuff was. I don't think the stuff was ever intended to sit directly on soil.. Even fence posts that are just planted in the post hole will rot out in a few years. The stuff is fine if used where it gets an opportunity to dry out. At one time it was a big thing to build basement walls (exterior) with PT lumber BUT they still applied a water barrier to the exterior surface.
[Re: Stanton]
#2820778
09/14/20 08:32 PM
09/14/20 08:32 PM
Posts: 9,453 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
If its something not connected to the house and I have no pt and ive a few days I just take a small paint brush and a gallon of old oil mixed with a pint of diesel and brush it on, over and over and let it keep soaking. Its my way of recycling
STOP POTATO HATE!
[Re: Stanton]
#2820795
09/14/20 08:56 PM
09/14/20 08:56 PM
Posts: 20,541 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I built a construction skid sign out of PT wood years ago and after one winter the wood touching the ground was 100% rotted out. A can of Krylon would have been a better moisture barrier than that stuff was. I don't think the stuff was ever intended to sit directly on soil.. Even fence posts that are just planted in the post hole will rot out in a few years. The stuff is fine if used where it gets an opportunity to dry out. At one time it was a big thing to build basement walls (exterior) with PT lumber BUT they still applied a water barrier to the exterior surface. Yes, I knew because of it sitting on the ground that is wasn't going to last forever. It seemed like it rotted out faster than un-treated wood would have. It literally crumbled apart when I went to move it and these were 4x4 sized pieces. I bought the PT stuff thinking it would be at least a little more durable.
[Re: Baller]
#2820800
09/14/20 09:01 PM
09/14/20 09:01 PM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
What you need is either Zinc Naphthenate or Copper Naphthenate. The copper will be green in color if matching is important. Many different brands available. Careful with this stuff also as it stains your hands for a couple of days.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
