what size elec fan??? #282018
04/08/09 10:17 PM
04/08/09 10:17 PM
On the parachute mount
N
n20mstr Online content OP
n20mstr  Online Content OP
N
I have always run a regular 18" fan water pump driven,, Now that i have added a vacum pump, the drive manderel is in the way of a fan, I have to switch to electric. SO, i see a lot fo 16" fans in Jegs etc, what is a good cfm rating??? 2000? Yea its a big block, and used to run about 180-ish with a 180 t stat on a hot day so,,.,,,
....BAD A$$ STREET CAR.....
Re: what size elec fan??? [Re: n20mstr] #282019
04/08/09 10:28 PM
04/08/09 10:28 PM
Idaho
Runner Offline
Runner  Offline
Idaho
might want to take a look at the chevy hhr fan. i dont know if eric can still get a deal on them or not.
Re: what size elec fan??? [Re: n20mstr] #282020
04/08/09 10:29 PM
04/08/09 10:29 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
I am running a spal fan 2500 cfm IIRC maybe 2750?
not to bad on temps. between 180-190 at lights on the street
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: what size elec fan??? [Re: DRDart] #282021
04/09/09 01:14 AM
04/09/09 01:14 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I always thought you wanted 3000 CFM of airflow through the radiator core for proper cooling...and to use a fan with a shroud so that you're pulling air through the entire core, instead of just an 18" circle
my big block dakota has a single core aluminum radiator that's like 20"x24" and I have a 19" electric fan on it with a shroud that's around 20x22, and it cools me down just fine.
**Photobucket sucks**
Re: what size elec fan??? [Re: n20mstr] #282022
04/09/09 01:21 AM
04/09/09 01:21 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
How much room do you have between the waterpump and the rad?
My 68 Dart with an RB doesn't have alot of room there, so I had to offset the 16" fan towards the driver's side. Not ideal, but what can you do? Don't really want to cut the rad support to gain extra room.
The HHR setup is a good one though, and can be ordered from your local chebby dealer for about $60, and comes with a shroud.
codfish
Re: what size elec fan??? [Re: codfish] #282023
04/09/09 01:26 AM
04/09/09 01:26 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
my opinion....find an OEM fan that fits your radiator. They usually flow much more than most aftermarket units and cost much less too.
HHR, ford taurus 3.8 V6, Lincoln/mark IV are all popular choices for example.
Re: what size elec fan??? [Re: n20mstr] #282024
04/09/09 08:36 AM
04/09/09 08:36 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
if possible:
If space permits it is always better to have your fan operate as a "puller" by mounting it on the water pump side of the radiator. A "puller" electric fan is approximately 15% more efficient than a "pusher" electric fan.
from Becool.
I'm currently changing the fan around on my car to pull rather than push.
some modification required!
Re: what size elec fan??? [Re: Rodney] #282025
04/09/09 09:06 PM
04/09/09 09:06 PM
N
N
Thanks for all the replys so far, im going to check out the HHR fan, ill see just how much room i have when i get the motor back in the car. HHR is a little big at 4.5" some 16" fans in Jegs are only 2.5"
THANKS
Re: what size elec fan??? [Re: n20mstr] #282026
04/09/09 09:17 PM
04/09/09 09:17 PM
an8sec70cuda Offline
You want ATLEAST 3000 cfm if you ever street drive it. I had a 16" zirgo that pulled 3000 cfm and it wouldn't keep up. Partially b/c of the radiator I had at the time, but the 2005 Viper fan I replaced it with does a MUCH better job. I have a big Griffin radiator now so no more troubles. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: what size elec fan??? [Re: an8sec70cuda] #282027
04/09/09 10:37 PM
04/09/09 10:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Note that amperage draw varies widely - some need a 40 amp circuit. You'll need a decent alternator. The 2000CFM fan on my drag car does a pretty good job, but of course the car only runs for minutes at a time; I don't think I'd use the same setup in traffic or in hot weather.
Re: what size elec fan??? [Re: topside] #282028
04/10/09 08:30 AM
04/10/09 08:30 AM
South Lyon, Michigan
6bblRoadrunner Offline
Good post. I'm looking at going to an electric fan myself. Does anyone have the dimensions of an HHR fan?
Re: what size elec fan??? [Re: 6bblRoadrunner] #282029
04/10/09 10:25 AM
04/10/09 10:25 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
The hhr fans is great but it pulls alot of amps.
The spals are the best of the aftermarket junk.
Re: what size elec fan??? [Re: Scamp408] #282030
04/10/09 11:15 AM
04/10/09 11:15 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I like the Ford Taurus fans. Here are some of the specs on it. http://www.dccontrol.com/0820.htm click on intergral fans and specs in the description
Re: what size elec fan??? [Re: an8sec70cuda] #282031
04/10/09 06:56 PM
04/10/09 06:56 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
HHR fan,,,love it,,,,,,
Re: what size elec fan??? [Re: 69CHARGERMD] #282032
04/10/09 06:59 PM
04/10/09 06:59 PM
N
N
Didnt you have issues with it fitting with the stock water pump?? thats what i have, stock pump with elec moroso drive, will it fit??
Re: what size elec fan??? [Re: n20mstr] #282033
04/10/09 07:15 PM
04/10/09 07:15 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
YES.......
I ended up going to a Meizere pump,,,and had lots of clearance....
New fan,,,and Moroso setup,,,,too tight,,,
New fan,,with Meizere...lots of clearance
Re: what size elec fan??? [Re: n20mstr] #282034
04/10/09 07:15 PM
04/10/09 07:15 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I had a SPAL dual 11 inch with shroud mounted on a BeCool rad for my Charger, They cleared the stock pulleys and pump but when I installed the March serpentine pulleys, it moved the power steering forward and ran into the shroud. BeCool claims that the rad I had with those fans would cool 700HP. Same fan setup with a larger Rad was supposed to be good for 1000HP. I replaced the Dual Spals with a dual fan setup from a '90 Contour (or was it '95) that offsets the two dans and it now fits. The SPALs are for sale in the classifieds here if you are interested.
Re: what size elec fan??? [Re: PC-CHARGER] #282035
04/10/09 07:17 PM
04/10/09 07:17 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Here's the Contour fans.
Re: what size elec fan??? [Re: PC-CHARGER] #282036
04/10/09 07:29 PM
04/10/09 07:29 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
and try and find a fan that covers the complete core I looked at an HHR fan but it was too small to cover my whole rad so I ended up with a fan assembly of a 95 Caravan fit the whole core and pulls a ton of air.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: what size elec fan??? [Re: dusturbd340W5] #282037
04/10/09 07:34 PM
04/10/09 07:34 PM
Idaho
Runner Offline
Runner  Offline
Idaho
the hhr fan fits a summit 27.5 radiator very well. how big is your radiator?
