Re: Spool Mount BB A-Body Swap
[Re: Dan Halen]
#2820205
09/13/20 12:46 PM
09/13/20 12:46 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I swapped a 413 into a 360 Dart Sport many moons ago. Used stock big block spool mounts to do it and it fit manifolds and all albeit after making manifold clearance with a BFH.
No idea if the engine was sitting correctly height wise or not but once the manifolds had clearance, it dropped into the Kframe and the trans mount lined up.
Kevin
[Re: Dan Halen]
#2820260
09/13/20 03:44 PM
09/13/20 03:44 PM
Posts: 31,036 Oregon
AndyF
I have a '74 318 Duster I want to swap a 383 into. I've seen that Schumaker is NLA but have heard rumors that factory B/C body spool engine mounts will work. Anybody have first hand knowledge? TIA If it was that easy then Direct Connection would not have built the BB swap K frame. It isn't difficult to move the mounts back on the K frame. If you don't have the time/talent/tools then you can find a local fab shop to do it. Jim Lusk has videos showing how to do it. https://www.forabodiesonly.com/mopa...dy-small-to-big-block-conversion.470292/
[Re: AndyF]
#2820298
09/13/20 05:15 PM
09/13/20 05:15 PM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
I have a '74 318 Duster I want to swap a 383 into. I've seen that Schumaker is NLA but have heard rumors that factory B/C body spool engine mounts will work. Anybody have first hand knowledge? TIA If it was that easy then Direct Connection would not have built the BB swap K frame. It isn't difficult to move the mounts back on the K frame. If you don't have the time/talent/tools then you can find a local fab shop to do it. Jim Lusk has videos showing how to do it. https://www.forabodiesonly.com/mopa...dy-small-to-big-block-conversion.470292/ What prompted my question was several people chiming in on another site, that they have done it. I had a DC K-member 40 years ago, but that was replacing the earlier style small block piece. With Mopar's tendency to re-brand assembly line parts with a "performance" part # I never discount the possibility anymore. Thanks for the info.
[Re: 65rbdodge]
#2820313
09/13/20 05:52 PM
09/13/20 05:52 PM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Cut and move the mount 3/4" and it works. As said above, Jim Lusk is the man and his video shows what you need to do.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Dan Halen]
#2820328
09/13/20 06:13 PM
09/13/20 06:13 PM
AndyF
I have a '74 318 Duster I want to swap a 383 into. I've seen that Schumaker is NLA but have heard rumors that factory B/C body spool engine mounts will work. Anybody have first hand knowledge? TIA If it was that easy then Direct Connection would not have built the BB swap K frame. It isn't difficult to move the mounts back on the K frame. If you don't have the time/talent/tools then you can find a local fab shop to do it. Jim Lusk has videos showing how to do it. https://www.forabodiesonly.com/mopa...dy-small-to-big-block-conversion.470292/ What prompted my question was several people chiming in on another site, that they have done it. I had a DC K-member 40 years ago, but that was replacing the earlier style small block piece. With Mopar's tendency to re-brand assembly line parts with a "performance" part # I never discount the possibility anymore. Thanks for the info. I guess it boils down to who you are going to believe. Here is a picture of my Duster with a DC type of K frame. The transmission lines up with the transmission mount and I have enough room in front of the engine for a clutch fan, full size radiator and a shroud. If you drop it in on the stock SB mounts you'll be fighting clearance issues all over the place. It can probably be done that way but don't be surprised if a lot of stuff doesn't fit.
[Re: AndyF]
#2820332
09/13/20 06:18 PM
09/13/20 06:18 PM
Dan Halen
Harm City Md.
I have a '74 318 Duster I want to swap a 383 into. I've seen that Schumaker is NLA but have heard rumors that factory B/C body spool engine mounts will work. Anybody have first hand knowledge? TIA If it was that easy then Direct Connection would not have built the BB swap K frame. It isn't difficult to move the mounts back on the K frame. If you don't have the time/talent/tools then you can find a local fab shop to do it. Jim Lusk has videos showing how to do it. https://www.forabodiesonly.com/mopa...dy-small-to-big-block-conversion.470292/ What prompted my question was several people chiming in on another site, that they have done it. I had a DC K-member 40 years ago, but that was replacing the earlier style small block piece. With Mopar's tendency to re-brand assembly line parts with a "performance" part # I never discount the possibility anymore. Thanks for the info. I guess it boils down to who you are going to believe. Here is a picture of my Duster with a DC type of K frame. The transmission lines up with the transmission mount and I have enough room in front of the engine for a clutch fan, full size radiator and a shroud. If you drop it in on the stock SB mounts you'll be fighting clearance issues all over the place. It can probably be done that way but don't be surprised if a lot of stuff doesn't fit. I've seen enough of your work, I don't doubt anything you say. That image speaks volumes, everything looks to be where it "belongs". Thanks!!
[Re: Dan Halen]
#2820396
09/13/20 08:45 PM
09/13/20 08:45 PM
AndyF
If I ever did another one of these cars I'd do it differently. The next time around I'd leave the engine mounts as a variable and solve for them. This time around I accepted the DC K frame as a given and I made other stuff fit. Next time I'd use the cooling system and the headers as fixed points and I'd allow the engine mount location to float until I was positive that everything else fit. Once it all fit I'd weld the ears on the K where they needed to go.
