what size elec fan???
#282018
04/08/09 10:17 PM
04/08/09 10:17 PM
Posts: 4,684 On the parachute mount
n20mstr
I have always run a regular 18" fan water pump driven,, Now that i have added a vacum pump, the drive manderel is in the way of a fan, I have to switch to electric. SO, i see a lot fo 16" fans in Jegs etc, what is a good cfm rating??? 2000? Yea its a big block, and used to run about 180-ish with a 180 t stat on a hot day so,,.,,,
....BAD A$$ STREET CAR.....
Re: what size elec fan???
[Re: n20mstr]
#282020
04/08/09 10:29 PM
04/08/09 10:29 PM
Posts: 616 Dunedin, Fl
DRDart
mopar addict
mopar addict
Dunedin, Fl
I am running a spal fan 2500 cfm IIRC maybe 2750? not to bad on temps. between 180-190 at lights on the street
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg
1966 Charger
1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
[Re: DRDart]
#282021
04/09/09 01:14 AM
04/09/09 01:14 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I always thought you wanted 3000 CFM of airflow through the radiator core for proper cooling...and to use a fan with a shroud so that you're pulling air through the entire core, instead of just an 18" circle
my big block dakota has a single core aluminum radiator that's like 20"x24" and I have a 19" electric fan on it with a shroud that's around 20x22, and it cools me down just fine.
**Photobucket sucks**
[Re: n20mstr]
#282022
04/09/09 01:21 AM
04/09/09 01:21 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
How much room do you have between the waterpump and the rad?
My 68 Dart with an RB doesn't have alot of room there, so I had to offset the 16" fan towards the driver's side. Not ideal, but what can you do? Don't really want to cut the rad support to gain extra room.
The HHR setup is a good one though, and can be ordered from your local chebby dealer for about $60, and comes with a shroud.
codfish
[Re: Rodney]
#282025
04/09/09 09:06 PM
04/09/09 09:06 PM
n20mstr
Thanks for all the replys so far, im going to check out the HHR fan, ill see just how much room i have when i get the motor back in the car. HHR is a little big at 4.5" some 16" fans in Jegs are only 2.5"
THANKS
[Re: n20mstr]
#282026
04/09/09 09:17 PM
04/09/09 09:17 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
You want ATLEAST 3000 cfm if you ever street drive it. I had a 16" zirgo that pulled 3000 cfm and it wouldn't keep up. Partially b/c of the radiator I had at the time, but the 2005 Viper fan I replaced it with does a MUCH better job. I have a big Griffin radiator now so no more troubles. CHIP
[Re: an8sec70cuda]
#282031
04/10/09 06:56 PM
04/10/09 06:56 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
HHR fan,,,love it,,,,,,
[Re: 69CHARGERMD]
#282032
04/10/09 06:59 PM
04/10/09 06:59 PM
n20mstr
Didnt you have issues with it fitting with the stock water pump?? thats what i have, stock pump with elec moroso drive, will it fit??
[Re: n20mstr]
#282033
04/10/09 07:15 PM
04/10/09 07:15 PM
69CHARGERMD
KENTUCKY
YES.......
I ended up going to a Meizere pump,,,and had lots of clearance....
New fan,,,and Moroso setup,,,,too tight,,,
New fan,,with Meizere...lots of clearance
[Re: PC-CHARGER]
#282036
04/10/09 07:29 PM
04/10/09 07:29 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
and try and find a fan that covers the complete core I looked at an HHR fan but it was too small to cover my whole rad so I ended up with a fan assembly of a 95 Caravan fit the whole core and pulls a ton of air.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#282037
04/10/09 07:34 PM
04/10/09 07:34 PM
Posts: 3,095 Idaho
Runner
Idaho
the hhr fan fits a summit 27.5 radiator very well. how big is your radiator?
