Holley Hi Ram intake #2819199
09/10/20 08:38 AM
09/10/20 08:38 AM
USA
hudsonhornet7x Offline OP
USA
Holley just came out with a Hi Ram for the gen 3 motor. Fuel injected but you can swap tops and use carbs as well.
https://www.holley.com/products/intakes/hi-ram_manifolds/parts/300-651BK
Re: Holley Hi Ram intake [Re: hudsonhornet7x] #2820123
09/13/20 01:02 AM
09/13/20 01:02 AM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
I had a Sniper intake for my car. It was junk sent it back they sent me a second one same issues. Then I found a dyno test of it car lost 40HP. So my gut would say unless you are boosted don't waste your money.
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
Re: Holley Hi Ram intake [Re: Bakaruda] #2820288
09/13/20 05:00 PM
09/13/20 05:00 PM
IL
furious70 Offline
furious70  Offline
IL
seems like a product without a use today except for a couple no limit builds that have been on here? Hi rpm, probably loses a ton of TQ to OEM manifolds, and you have to spend a gob ton to get valve gear that also support the hi rpm?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Holley Hi Ram intake [Re: hudsonhornet7x] #2820560
09/14/20 11:51 AM
09/14/20 11:51 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I'm sure they saved $ using the same top found on LS intakes of the same design, but I agree, how many people can run this? Definitely won't fit under a stock hood.
I'd think either a single plane or dual plane intake, either efi or carb, would be substantially more lucrative.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Holley Hi Ram intake [Re: A39Coronet] #2820616
09/14/20 01:52 PM
09/14/20 01:52 PM
ghinmi Offline
ghinmi  Offline
They sell a ton of 'em to LS guys and they're very similar platforms as far as parts and potential. No reason why they won't sell a ton of 'em to hemi guys. It's filling a hole that's been missing in the hemi world.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Holley Hi Ram intake [Re: ghinmi] #2820686
09/14/20 04:53 PM
09/14/20 04:53 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
The short Ritter intake is 7 inches to the carb mount surface from the head flange and it has a hard time fitting under anything. I would be curios what the height of this with a carb top is. I'd try it with 2 4s
Re: Holley Hi Ram intake [Re: hudsonhornet7x] #2820741
09/14/20 07:18 PM
09/14/20 07:18 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
When I spoke to John Ritter on the phone he believed there was someone running on in an ebody under a stock hood. Having used the shorter Prefix intake, I don't see how it's possible unless the motor has been lowered or a scoop was used
I'm certainly not against any new intake, but I still scratch my head over the high rise version of this style.
