intake manifold question #2820030
09/12/20 05:48 PM
09/12/20 05:48 PM
taunton, mass. 02780
moparthunder70 Offline OP
I have a cast iron stock intake manifold part # 2951666 for a 383 ( single 4 barrel ) which I believe to be a 1970 0r 1971 intake..can this be used on a 1969 383 block...is it interchangeable with this year ?
Re: intake manifold question [Re: moparthunder70] #2820038
09/12/20 06:25 PM
09/12/20 06:25 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
It will work just fine.
Re: intake manifold question [Re: elmor353] #2820044
09/12/20 06:39 PM
09/12/20 06:39 PM
yes..another mopar guy just confirmed it...thanks...
Re: intake manifold question [Re: moparthunder70] #2820322
09/13/20 06:02 PM
09/13/20 06:02 PM
Mopar switch to Holley carbs on the 1070/1971 Magnum 383 morors cwhich uses a different choke set up. Your AVS arb will bolt on the later intake fine but without any way to make the stock AVS choke work choke work shruggy
