Bangshift live from US131 right now
#2819935
09/12/20 11:20 AM
09/12/20 11:20 AM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
T/D, TS Pro Mods and Alky funnies Was there last night, tons of quality cars. First round live right now
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Bangshift live from US131 right now
[Re: B3422W5]
#2819948
09/12/20 11:54 AM
09/12/20 11:54 AM
B3422W5
Portage,michigan
The 71 Orange Billboard Cuda coming up in Pro Mod is sweeeet!
[Re: B3422W5]
#2820019
09/12/20 05:06 PM
09/12/20 05:06 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Terry McMillen commented he could take an Alcohol Funny Car to Michigan and make more money than winning a National in Top Fuel. And spend like $130,000 less doing it.
[Re: CMcAllister]
#2820043
09/12/20 06:35 PM
09/12/20 06:35 PM
B3422W5
Portage,michigan
Think it paid like 15k to win today
[Re: CMcAllister]
#2820075
09/12/20 08:35 PM
09/12/20 08:35 PM
Posts: 1,113 Usa
A39Coronet
Usa
Terry McMillen commented he could take an Alcohol Funny Car to Michigan and make more money than winning a National in Top Fuel. And spend like $130,000 less doing it. Not unless he can cut 00x lights and run it on the dial. Current environment will definitely make big $ bracket racing more enticing for the lower level pros without big sponsorships. However, its apples to oranges to pro classes.
[Re: A39Coronet]
#2820081
09/12/20 08:43 PM
09/12/20 08:43 PM
B3422W5
Portage,michigan
Terry McMillen commented he could take an Alcohol Funny Car to Michigan and make more money than winning a National in Top Fuel. And spend like $130,000 less doing it. Not unless he can cut 00x lights and run it on the dial. Current environment will definitely make big $ bracket racing more enticing for the lower level pros without big sponsorships. However, its apples to oranges to pro classes. Alky funnies run it out the back door, heads up. Not off a dial like T/D or T/S
[Re: B3422W5]
#2820146
09/13/20 08:07 AM
09/13/20 08:07 AM
Posts: 1,113 Usa
A39Coronet
Usa
Terry McMillen commented he could take an Alcohol Funny Car to Michigan and make more money than winning a National in Top Fuel. And spend like $130,000 less doing it. Not unless he can cut 00x lights and run it on the dial. Current environment will definitely make big $ bracket racing more enticing for the lower level pros without big sponsorships. However, its apples to oranges to pro classes. Alky funnies run it out the back door, heads up. Not off a dial like T/D or T/S Ohhh I was bouncing around on three separate races yesterday on YouTube and may have only seen TD sat 131 and thought they were just regular bracket racing.
[Re: A39Coronet]
#2820187
09/13/20 11:13 AM
09/13/20 11:13 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Ohhh I was bouncing around on three separate races yesterday on YouTube and may have only seen TD sat 131 and thought they were just regular bracket racing. T/D(top dragster) and T/S(top sportsman) classes are regular bracket racing. TA/FC(top alcohol funny car) is heads up.
