09/10/20 11:12 AM
09/10/20 11:12 AM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Anyone have a fixed airbleed main body, they could measure the air bleeds? I just picked up a used one, and want a baseline. I searched extensively, and could only find HP data. Thanks in advance.
Re: 4781-6 [Re: Leigh] #2819276
09/10/20 12:11 PM
09/10/20 12:11 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
In the past I have used Holley's tech line for info like that and they were great.
Re: 4781-6 [Re: B1MAXX] #2819310
09/10/20 01:13 PM
09/10/20 01:13 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Thanks, sounds like a good idea. I noticed the primary and secondary boosters have a different id. I saw the oem secondary jetting, is 2 sizes leaner, so I’ll measure the bleeds, booster discharge channel and od and id, to get an idea why, before calling.
Re: 4781-6 [Re: Leigh] #2819600
09/11/20 08:36 AM
09/11/20 08:36 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have a 4781 on the shelf...I'll look and see what -# it is.Just for the heck of it. Let you know what I find.
Re: 4781-6 [Re: B1MAXX] #2819602
09/11/20 08:44 AM
09/11/20 08:44 AM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
If you could measure the primary and secondary pvcr as well, that would be great! Thanks!
Re: 4781-6 [Re: Leigh] #2819654
09/11/20 12:18 PM
09/11/20 12:18 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
here is what I have, not sure if it helps you though. It's a 4781-2, the primary bleeds are .070 idle, .026 high speed. The secondary bleeds are .067 idle, .026 high speed. I didn't want to pull a bowl and metering block. its in ready to run shape and didn't want to mess with it but I have written on the bowls primary has a 80 jet with a power valve, and the secondary has a 92 jet with the power valve blocked. I know that doesn't answer the question of the pvcr, but that's the way I have that one set up. up Holley's tech has always been really good.
Re: 4781-6 [Re: B1MAXX] #2819666
09/11/20 12:40 PM
09/11/20 12:40 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Thanks! Did you happen to notice if the primary and secondary boosters are different sizes? That’ll be my last question!
Re: 4781-6 [Re: Leigh] #2820575
09/14/20 12:39 PM
09/14/20 12:39 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I didn't notice any difference in boosters.
