Page 2 of 4 1 2 3 4
Re: New project truck found! [Re: RapidusMaximus] #2807580
08/11/20 09:16 AM
08/11/20 09:16 AM
RWG75
RWG75
Originally Posted by RapidusMaximus
Originally Posted by RWG75
Did I say nice find?
.and actually I think I've decided I like the green shruggy work laugh2
I asked google to show me some green duallys or club cabs. I saw a couple cool examples.
Re: New project truck found! [Re: ] #2807635
08/11/20 11:52 AM
08/11/20 11:52 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
I think the third pic is the one I'm going with...is that F8 Forrest green?
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: New project truck found! [Re: RapidusMaximus] #2807686
08/11/20 01:32 PM
08/11/20 01:32 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Cool Dually!!!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: New project truck found! [Re: 11secdart] #2807736
08/11/20 03:16 PM
08/11/20 03:16 PM
Weatherford, Texas
Weatherford, Texas
Originally Posted by 11secdart
Cool Dually!!!
Thanks!
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2807747
08/11/20 03:40 PM
08/11/20 03:40 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
My original owner dark forest green 92 ( old picture, has different wheels and LED headlights now ) i couldn't get new pics to post
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: New project truck found! [Re: RapidusMaximus] #2808117
08/12/20 02:39 PM
08/12/20 02:39 PM
scratchnfotraction Offline
that is sweet! good luck with it. sounds solid and ready to work. growing up here in FL. Forrest green has been the state forestry division color as long as I can remember. my 85 step side was that color. I like it myself.
Re: New project truck found! [Re: scratchnfotraction] #2808151
08/12/20 04:25 PM
08/12/20 04:25 PM
Weatherford, Texas
Weatherford, Texas
Thanks Scratch, reassembly starts this weekend on the rear brake system and dual tanks, found some NOS parts online and a couple of handy Moparts vendors had some other things I needed up beer
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2812925
08/25/20 06:35 AM
08/25/20 06:35 AM
Weatherford, Texas
Weatherford, Texas
Little update and help needed, all the parts arrived, rear brake lines are complete and bled, front and rear fuel tanks are installed, plumed, wired, new fuel lines from the pump back and new sumps in both tanks. Truck is now disassembled and prepped for primer/sealer/paint, temporary paint booth is built, paint my happen this weekend luck Now for the help needed...when I got the truck it had zero fuel system installed, it had a one gallon jug bungied in front of the radiator and plumed straight to the fuel pump, the truck ran perfect during all the yard driving ( burned 2 gallons of gas) that I did prior to disassembly for paint...then...installed the complete fuel system, both tanks were blown and vaccumed, fuel lines were new, switching valve is new, sumps are new, both tanks have a vent in the top that I guess used to go to the vapor canister? I plumbed them together with a "T" vent...ok...that's a long story to get to the point...the truck now runs like "S@#T!!! Won't idle, revs up and down on its own when you make it stay running...what am I missing here, any ideas?
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2812951
08/25/20 08:16 AM
08/25/20 08:16 AM
Guitar Jones Offline
Sounds like low fuel level in the carb. Maybe sucking air somewhere or the pump isn't putting out the volume it needs to fill the carb. I would get it running for a minute or so then check the fuel level in the carb or put a pressure gauge on it. Or just pull the line off, put it in a catch can and crank it to see how much volume is coming out.
Re: New project truck found! [Re: Guitar Jones] #2812996
08/25/20 10:06 AM
08/25/20 10:06 AM
Weatherford, Texas
Weatherford, Texas
Thanks for the ideas, I'll go back over all the connections and check the fuel pressure, it came with an AFB installed so checking fuel level will require removing the top of the carb, I was going to do that anyway just to make sure it didn't pick up some trash somehow.
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2813420
08/26/20 08:12 AM
08/26/20 08:12 AM
RWG75
RWG75
I was thinking about sucking air too except that it would probably leak gas from the same place. Other thought was maybe the one fuel line you didn't replace, if there is one. Clear bodied fuel filters are a good way to see how much fuel is getting pumped to the carb. Maybe go back to the aux fuel can feeding the pump to verify the carb and if it runs good from that, work your way back one connection at a time until it has a problem again.
Re: New project truck found! [Re: ] #2813498
08/26/20 11:11 AM
08/26/20 11:11 AM
Weatherford, Texas
Weatherford, Texas
Thanks for the ideas, only line that's not new is the line from the pump to the carb, and it has a clear filter at the carb inlet but I didn't notice how much gas was in it, I'll check that. I like the idea of hooking it back up to the aux one gallon tank to see if it clears up then working my way back, I'll try that also up
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2814942
08/29/20 10:24 PM
08/29/20 10:24 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Paint it yourself, find the HVLP paint gun and turbine, there is no over spray! All the paint goes on the vehicle. I’ve painted with the same gun-turbine for 33 years. You’ll never go back to a conventual gun.
Re: New project truck found! [Re: cudaman1969] #2815265
08/30/20 10:08 PM
08/30/20 10:08 PM
Weatherford, Texas
Weatherford, Texas
Made some progress today, painted early this morning before it got too hot and then this afternoon after the sun went down, only have the cab left to do, single stage dark jade metallic...
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2815266
08/30/20 10:12 PM
08/30/20 10:12 PM
Weatherford, Texas
Weatherford, Texas
Couple more...
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2816098
09/02/20 06:15 AM
09/02/20 06:15 AM
Weatherford, Texas
Weatherford, Texas
Update...RAIN...also, just looked at the first bed pic and realized half the bed looked dull...couldn't figure out why until I realized it's the reflection of the plastic curtain hanging from the rafter laugh2. Rain (humidity) look to be hanging around until late in the week so I'm on hold....
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2818020
09/06/20 11:00 PM
09/06/20 11:00 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
up Looks good! I always liked single stage paint, but now I like using base/clear much better.
Re: New project truck found! [Re: JDMopar] #2818058
09/07/20 06:40 AM
09/07/20 06:40 AM
Weatherford, Texas
Weatherford, Texas
Thanks, I finished the cab yesterday, no pictures, have to start unmasking today and then check for touch up needed areas. I tried base coat clear coat once but jacked up the cut and buff so I haven't shot it since, on a side note I did figure out why the truck was running bad after I installed the fuel system whistling seems when a 31 gallon tank is bone dry 5 gallons of gas will not cover the pick up...so yes, the pick up was sucking air and a little bit of gas spank...
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2818810
09/09/20 05:40 AM
09/09/20 05:40 AM
Weatherford, Texas
Weatherford, Texas
Couple of questions...does anybody know if there was/is supposed to be a gasket or molding between the Dually fender mount points and bed, I've googled and can't find any mention of it or a replacement listing shruggy. Also, anyone know who sells the tailgate trim mounting clips, thanks up
1968 Plymouth GTX
Re: New project truck found! [Re: RapidusMaximus] #2818812
09/09/20 06:13 AM
09/09/20 06:13 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Yes there is supposed to be a gasket that goes between the fiberglass flare and the bed. Don't know if they are in reproduction. I have a set here that I can text you a pic of later this morning if you need to see what they look like.
These guys might sell the gaskets...
http://duallyfendersfiberglasstruck.com/_Home_2.html
https://www.cumminsforum.com/threads/what-to-do-dually-fenders-to-bed.240053/
Not sure of clip reproduction. Seems like they could be produced with a 3D printer.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1607890/re-nos-truck-trim-clips.html
Truck looks great!
Page 2 of 4 1 2 3 4
