Re: 69 Charger Water Temperature Gauge Reading High
[Re: Andrewh]
#2818955
09/09/20 01:04 PM
09/09/20 01:04 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
I'm measuring ~23.5 ohms while the temperature gauge is pegged. 23.5 ohms at the sensor should be at or just left of center on the temperature gauge. For a pegged gauge I would expect at or near 10 ohms at the sensor.
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: Blue69Charger]
#2819959
09/12/20 12:18 PM
09/12/20 12:18 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Thanks guys. I just bought a solid state instrument voltage regulator from real time engineering. I'll give it a try. If in fact the fuel gauge is reading correctly the replacing of the limiter will not help. As said a simple voltage reading at any gauge input would verify if you have the correct 5 volts.
[Re: NITROUSN]
#2820164
09/13/20 09:32 AM
09/13/20 09:32 AM
Posts: 10,741 North Dakota
6PakBee
North Dakota
If in fact the fuel gauge is reading correctly the replacing of the limiter will not help. As said a simple voltage reading at any gauge input would verify if you have the correct 5 volts. If you have a solid state replacement IVR of some sort you can read 5 volts (or whatever the exact voltage output seems to be). If you have the original electromechanical model, it gives a pulsing 12 volt output that averages about 5 volts over time. But you cannot read 5 volts.
[Re: TJP]
#2820411
09/13/20 09:20 PM
09/13/20 09:20 PM
Posts: 6,291 nowhere
Sniper
nowhere
The factory gauge isn't all that precise or accurate. they can be if calibrated. A royal PITA BTDT No indication the OP did or had that done though.
[Re: Sniper]
#2820784
09/14/20 08:43 PM
09/14/20 08:43 PM
Posts: 15,457 Omaha Ne
TJP
Omaha Ne
The factory gauge isn't all that precise or accurate. they can be if calibrated. A royal PITA BTDT No indication the OP did or had that done though. I didn't say he did or didn't You made a statement that they are not that precise or accurate, I made a statement that said they can be if calibrated.
