Alkaline Dipped VS Bead Blasting #281872
04/08/09 09:01 PM
04/08/09 09:01 PM
Anonymous OP
Anonymous OP
I need a definitive answer on my re-occuring question of. Should I bead blast or Akalne dip the shell of my numbers matching 70 Challenger R/T?
Can anybody help me with the pros and cons? I have finally reached the point that I'm ready to strip the shell and just needs to deciede on which route to go. If I bead blast can I still e-coat?
Re: Alkaline Dipped VS Bead Blasting #281873
04/08/09 11:48 PM
04/08/09 11:48 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
I don't see the point in e-coat if you haven't dipped the car. It's still going to have rust in areas that couldn't be reached. My GTX was dipped and e-coated and, although expensive, I felt it was worth it because there were areas that needed attention that wouldn't have been found with media blast. Also, the e-coat can get in nooks & crannies and give a coating to clean metal once dipped and properly neutralized.
Re: Alkaline Dipped VS Bead Blasting [Re: ryangtogtx] #281874
04/09/09 01:41 AM
04/09/09 01:41 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I had two cars alkaline dipped, and I'm very happy with the results. My 70 Challenger RT SE was done 10 years ago, and there are no issues whatsoever. The dipping is very expensive, but well worth it if you plan to keep the car for a long time. After the dipping you should either get it E-coated or zinc phosphated. One of these is a must, I had mine phosphated, as this is what the local Redi-Strip has available. After that expoy primer inside and out, cover every area. Then while still on the rotessire, pour epoxy primer into every seam, frame rail, boxed in section, etc. until it is seeping out on the other side. If you follow this you will have a nice clean body that won't rust for a long long time.
Re: Alkaline Dipped VS Bead Blasting [Re: Barnabas_Kriss] #281875
04/09/09 01:45 AM
04/09/09 01:45 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Hey Barnabas,
Where in BC can I drag my old Duster hulk for a dip and a phosphate or E-coat? What's the cost for a unibody?
Re: Alkaline Dipped VS Bead Blasting [Re: ScottSmith_Harms] #281876
04/09/09 01:49 AM
04/09/09 01:49 AM
Scott,
There is only one outfit, Redi-Strip in Delta, BC, near Vancouver. They are expensive, but do a nice job. Cost is about $1800 to dip, and another $1600 or so to zinc phosphate. This is in Canadian dollars. They do get some US customers. Turnaround time is pretty good, usually ~2 weeks or so.
Re: Alkaline Dipped VS Bead Blasting [Re: Barnabas_Kriss] #281877
04/09/09 01:53 AM
04/09/09 01:53 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's really not that bad, it costs 1/3 of that for a good media blast and that doesn't include E-coat. Nothing like starting off a restoration with a CLEAN a rust free shell!
Was that just for the uni-body or did it include doors, fenders, hood, deck lid, etc.
Re: Alkaline Dipped VS Bead Blasting [Re: ScottSmith_Harms] #281878
04/09/09 08:55 AM
04/09/09 08:55 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
That's for sure.
NMCA NSS 67 Coronet
Re: Alkaline Dipped VS Bead Blasting [Re: ScottSmith_Harms] #281879
04/09/09 09:19 AM
04/09/09 09:19 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Had mine stripped by carolina chemstrip about 5 years ago. It absolutely looked like new sheet metal afterwards. Cost $1400 for the shell, $100 each for the doors, fenders, and decklid. I stripped the hood by hand. Even the lead was removed from the roof, and cowl seams. They didn't e coat but they put some kind've rust treatment on the shell. Still in primer but no issues so far. I was worried about the inside of the frame rails, rockers, etc. I loaded up a undercoat gun with epoxy primer and shot the hidden areas with that. An undercoat gun will move a LOT of epoxy primer!
Re: Alkaline Dipped VS Bead Blasting [Re: Barry70GTX] #281880
04/09/09 09:55 AM
04/09/09 09:55 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
That's for sure.
Barry, where did you have that done?
Thanks,
Darren
Re: Alkaline Dipped VS Bead Blasting [Re: Ludington1] #281881
04/09/09 12:09 PM
04/09/09 12:09 PM
Anonymous OP
Anonymous OP
Does any body know of a place that will dip in the Northwest Ohio area? I have one place American Metal Cleaning but the cost to dip is $2400. I would be will to tow the car to Indiana. Southern Ohio or Michigan or any destination in a days drive to save some bucks.Canada is just 60 minutes North. I'm talking the Windsor area I would prefer a place that could dip and e-coat/
Do you e-coat and than do the body work or the other way around?
Re: Alkaline Dipped VS Bead Blasting #281882
04/09/09 12:34 PM
04/09/09 12:34 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Redi-Strip in Indianapolis can dip the whole shell if needed. The owner is a Mopar guy too.
Re: Alkaline Dipped VS Bead Blasting #281883
04/09/09 12:36 PM
04/09/09 12:36 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My Challenger is at Best of Show Automotive in Painesville Ohio. My car was sand and bead blasted but last I heard, they are in the process of partnering with a company to have their cars dipped and E-coated. Where that company is located I don't know. Painesville is very close to Cleveland.
I was told by the shop manager that a vehicle would be dipped and then returned to their shop for metalwork. Once the panel replacement was done, the car would be dipped once again for a short time to get rid of the flash rust. Finally the car would be E-coated before any bodywork.
Re: Alkaline Dipped VS Bead Blasting [Re: Ludington1] #281884
04/09/09 01:12 PM
04/09/09 01:12 PM
Barry70GTX Offline
Barry70GTX  Offline
That's for sure.
Thanks,
Darren
Here's the place Darren. Auto Restoration Depot
NMCA NSS 67 Coronet
Re: Alkaline Dipped VS Bead Blasting [Re: burdar] #281885
04/09/09 01:14 PM
04/09/09 01:14 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
I know with our car, after all of the rust was removed from the chem strip, it was dipped in a phosphate solution to inhibit rust. Metal work was performed and then it was e-coated. Most chem strip facilities are not necessarily affiliated with an e-coat facility. I know our car got dipped in the Chicago area and was e-coated in somewhere in Iowa.
Re: Alkaline Dipped VS Bead Blasting [Re: ryangtogtx] #281886
04/09/09 04:43 PM
04/09/09 04:43 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
My shop has a Strip and Ecoat service available! we are in New Castle, In.
email us here: infoatdornautocraft.com
change at to @
I have to go to funeral home now so I will check back tomorrow! prefer emails.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
