Page 2 of 3 1 2 3
Re: Locked out distributor [Re: TonyS451] #2818072
09/07/20 08:57 AM
09/07/20 08:57 AM
IL
Dart451 Offline
Dart451  Offline
IL
Yes I have success with the two switch deal. Sometimes when hot it still rolls over slow but once rolling throw the ignition switch. Thought about wrapping the starter to keep it from heat soaking. Stock 90's started can't remember which one..
Re: Locked out distributor [Re: TonyS451] #2818079
09/07/20 09:22 AM
09/07/20 09:22 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Hundreds of millions of engines made with curves since the Model T (manual advance).
Too bad they didn't realize you don't need it.
Whether you believe in it or not, physics is always there.
Boffin Emeritus
Re: Locked out distributor [Re: TonyS451] #2818086
09/07/20 09:44 AM
09/07/20 09:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
All I use to do was to set the timing so it would idle then set it for total timing.. the engine
only had 2 speeds.. idle and WOT.. it would idle at 900rpm and I could drive it in the pits..
as soon as the engine started it was 200 rpm below where the curve would come in.. from there
it was 35*
wave
Re: Locked out distributor [Re: MR_P_BODY] #2818099
09/07/20 10:25 AM
09/07/20 10:25 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
turn off the start retard and you problems will go away. I've been down that path before.
Re: Locked out distributor [Re: Cab_Burge] #2818111
09/07/20 10:48 AM
09/07/20 10:48 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by Cab_Burge
Originally Posted by cudaman1969
My 499 840 hp idled at 650 with instant throttle response in gear, timing all in at idle, but was maybe 10 degrees starting so it wouldn’t kick back.
Forgot to add total was 37, never moved it to see if it was better anywhere else.
How you going to learn if you don't test, especially testing at a good track work grin stirthepot
That was where Kenny said to set it from all the dyno pulls. When I go to the track I concentrate on winning the next round, if I had time I would fiddle with it but the big thing is reaction time and the number. If I felt it needed anything I would look into it. The one thing I learned in all these years is the winners don’t fiddle with the car on race day the ones who do are on the trailer.
Re: Locked out distributor [Re: polyspheric] #2818112
09/07/20 10:52 AM
09/07/20 10:52 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Comparing a custom, modern street/strip performance application to vehicles built for the masses is the most retarded thing I've seen on here. Pun intended.
'63 Dodge 330
11.19 @ 121 mph
Re: Locked out distributor [Re: GY3] #2818117
09/07/20 11:07 AM
09/07/20 11:07 AM
Deep DEEP SOUTH
LAD 524 Online content
LAD 524  Online Content
Deep DEEP SOUTH
Agree, poor comparison using OEM engines needs vs built street/race engines even if the "physics" does'nt change.
Locked out, start retard, crank trigger.
280 @ .050 580 inch Hemi, never an issue.
Re: Locked out distributor [Re: TonyS451] #2818128
09/07/20 11:50 AM
09/07/20 11:50 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I was running a locked-out MSD Pro-billet distributor on my RB. I swapped it out with one of the recently released Progressive Ignition bluetooth programmable distributors. With some guidance from AndyF, I ended up with my own custom ignition table that lets the motor crank at a low timing setting, but as soon as it starts the timing goes to 34* by 750 rpm.
The reason I switched was to add the adjustable vacuum advance to my set-up. Now, at cruising RPM I have 44* total. Attached is an example of one of the tables I tried before settling on what I just described. It's for illustrative purposes only. The numbers in the left colum are MAP readings, which account for atmospheric pressure.
Essentially, it gives me start retard, locked-out timing and vacuum advance. It also lets me see what the timing is doing in real time and make changes on my cell phone. So far everything is working flawlessly.
Re: Locked out distributor [Re: TonyS451] #2818174
09/07/20 02:16 PM
09/07/20 02:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
This could all be resolved by a simple test with an in-cylinder pressure transducer. It's been done, by F1, Ferrari, Mercedes, and every auto manufacturer.
Boffin Emeritus
Re: Locked out distributor [Re: polyspheric] #2818199
09/07/20 03:15 PM
09/07/20 03:15 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I'm not dealing with OEM spec engines much. An engine that operates primarily at part throttle from idle to 3000 RPM is a different animal from a race deal that's either on or off. Or even a race deal with tags that idles around on the street some on a Saturday night.
Big, lumpy cam = >240*-245* @ .050. <10" vacuum. Usually a roller of some type.
An electronic means of retarding timing when starting, high gear retards, pulling timing at the hit on a big power, suck track deal, are all great ideas to be able to do. But some of us are doing the KISS with just a 7AL with a crank trigger and a carb deal. So basically I don't need a curve. Also, race cars should have separate start and ignition switches to be able to spin the engine with the ignition off anyway. Easy to do, even if you're still using a stock ignition switch.
Having the thing fall back 15* or 20* from total timing usually ends up making you open the carb to make it idle. Now you've upset the throttle blade/transfer slot relationship or drilled holes in the blades. Either way, you're doing stuff to the carb you wouldn't have if it had the timing in it. I typically set the throttle/transfer slot relationship by eye, install the carb and keep my fingers off the idle speed screws for all but fine adjustments. If it won't idle, I fix the reason for it. Maybe a little air bleed somewhere.
Big roller, 800 RPM in gear without having my foot on the gas. Plugs a little hotter than most run, Sit and idle like that all day if I want.
Re: Locked out distributor [Re: polyspheric] #2818208
09/07/20 03:42 PM
09/07/20 03:42 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
So you go from touting OEM "solutions" to that of multi-million dollar race teams?! shruggy
I knew there was a reason I had you on ignore... rolleyes
'63 Dodge 330
11.19 @ 121 mph
Re: Locked out distributor [Re: CMcAllister] #2818228
09/07/20 05:07 PM
09/07/20 05:07 PM
Washington
madscientist Offline
Washington
Thanks for the explanation.
Re: Locked out distributor [Re: madscientist] #2818252
09/07/20 06:14 PM
09/07/20 06:14 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Here’s what I’ve done so far just to try some if the ideas that have been suggested:
I switched the digital 6 setting back to standard (no start retard) and starter kicked back when I tried starting.
Wired ignition on a toggle, spun engine w key switch , then added ignition on and...kick back
Went back to start retard on box, spun engine w key, added ignition on and...it started no kick back
Took car out for a nice spin around town, and parked it for 20 minutes. Tried to restart w spin engine first method and it fired up again. I’ve had similar results w just normal key and ignition on at same time, using start retard. Would still get occasional starter kick back. I don’t want to get too excited about two consecutive starts without kickback. Time will tell if the 2 switch method is the winner.
Has anyone tried a higher torque starter to deal w this issue?
2 kids and a dog
Re: Locked out distributor [Re: GY3] #2818253
09/07/20 06:14 PM
09/07/20 06:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
No, someone I know.
Please continue to make yourself ridiculous.
Boffin Emeritus
Re: Locked out distributor [Re: TonyS451] #2818254
09/07/20 06:17 PM
09/07/20 06:17 PM
AndyF Offline
AndyF  Offline
Removed duplicate post.
Re: Locked out distributor [Re: TonyS451] #2818259
09/07/20 06:31 PM
09/07/20 06:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
There are really 2 very different answers to "locked: Y/N?".
1. is the position of the piston when the spark kernel begins to expand away from the ignition source. In addition to compensating for the time in milliseconds balancing piston accelerating away from TDC to advancing flame front (which dies out after perhaps 3,000 RPM), the remainder is based on the cylinder pressure (combustion, not CCP), A:F mixture, droplet size, fuel chemical characteristics, VE, and how many intermediate stages of combustion take place (before final conversion to water and CO2), and boost.
2. is how many of these are relevant to a maximum effort engine that only needs to start, idle (more or less), stage, launch and WOT. Sometimes this answer is so close to "only 1" that the exceptions are more trouble than they're worth. I've never seen an engine with idle quality exactly the same with 15° and 40° spark; the idle speed may not differ significantly but the spark position can be selected by choosing the LOUDEST position.
Boffin Emeritus
Re: Locked out distributor [Re: TonyS451] #2818304
09/07/20 07:53 PM
09/07/20 07:53 PM
AndyF Offline
AndyF  Offline
Tony, I have a slightly used MSD starter saver sitting in my cabinet that you can have if you want to try it. I don't need it anymore since I went digital. I assume this is the same module that you are currently using? Maybe yours is flaky so swapping in another one might eliminate that variable. No guarantees that this isn't also flaky. I never fully tested it. We used it a few times on the dyno but couldn't confirm that it was really working so we switched over to the method of spinning the engine before hitting the switch. Eventually we just went digital and EFI and built the start retard right into the map. Shoot me a PM if you want this MSD module.
Re: Locked out distributor [Re: jbc426] #2818305
09/07/20 07:56 PM
09/07/20 07:56 PM
AndyF Offline
AndyF  Offline
That looks good to me. That table gives you everything you wanted. The programmable distributor is another option for Tony if he doesn't want to move all the way to EFI at the moment. Glad to hear that solution is working for you.
Re: Locked out distributor [Re: Dragula] #2818332
09/07/20 08:44 PM
09/07/20 08:44 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Friend of mine just did the same and his timing moved from 38* to 42* . Doesn't drag the starter any more and the engine just does everything better now. He has a chevy with a 505. Too many plug ins and things to go wrong. Fires immediately now. Runs on E85.
Re: Locked out distributor [Re: AndyF] #2818335
09/07/20 08:47 PM
09/07/20 08:47 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Thank you Andy, I might take you up on that. I’m currently using the digital 6 which has a built in start retard. I actually sent the box in to msd because I thought it was faulty. They tested the box and said it was fine. Embarrassingly enough, I bought a new digital 6 while that box was being serviced. (I was ancy and wanted get back on the road). The new box did the same thing!!..worked some of the time.
Hit me up anyone who is interested in a good deal on a like new digital 6 box w clean bill of health from MsD. (Can’t make any promises on the start retard function!!)
The 2 switch start seems to be working at the moment , but I’ll keep you posted. Thanks again, Andy
2 kids and a dog
Page 2 of 3 1 2 3
