'69 Superbee headlight switch #2817661
09/05/20 11:57 PM
09/05/20 11:57 PM
Missouri, U.S.A.
JSSuperbee Offline OP
Missouri, U.S.A.
What is the proper way to remove the headlight rocker switch in a '69 Superbee?
James Stinebaker
Re: '69 Superbee headlight switch [Re: JSSuperbee] #2817666
09/06/20 12:21 AM
09/06/20 12:21 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Remove the cluster is really the best way, I have changed one on an A/C car by removing the side A/C vent, but I got all cut up
