Page 2 of 3 1 2 3
Re: New best this weekend! [Re: GY3] #2813455
08/26/20 09:34 AM
08/26/20 09:34 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Originally Posted by GY3
Originally Posted by an8sec70cuda
Some food for thought and just my opinion...don't try to go too much faster w/ a heavy car. It gets way more expensive and less fun. It has it's fun times, like when everything goes good at the track, but I think I had more fun w/ the car running mid to low 10s. It was all motor then too, which was a lot less work and aggravation.
No plans to push it too much further. Would like to do a 9.99 once, but the stars would have to align.
it will absolutely not get cut up or lightened up any further!
Just a little more nitrous........
68 Barracuda Formula S 340
Re: New best this weekend! [Re: Bad340fish] #2813464
08/26/20 09:41 AM
08/26/20 09:41 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Bottle bottle bottle!!! laugh2 Nice pass with a full figured gal!
Re: New best this weekend! [Re: Bad340fish] #2813474
08/26/20 09:57 AM
08/26/20 09:57 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
...and an aftermarket block, and better heads... ozbbq
'63 Dodge 330
11.19 @ 121 mph
Re: New best this weekend! [Re: GY3] #2815995
09/01/20 08:37 PM
09/01/20 08:37 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have been 9 teens and 9.20's pretty regularly with a 446 (stock block and crank) indy 440-1s with two stacked plates, @ 3400lbs .......IT can be done LOL
i had a 440 with ported 906's and a .509 cam , went 10.40's with that (STOCK ROCKERS) LOL
....BAD A$$ STREET CAR.....
Re: New best this weekend! [Re: n20mstr] #2815996
09/01/20 08:40 PM
09/01/20 08:40 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Quick and it gets lots of use. Win Win.
Doug
Re: New best this weekend! [Re: GY3] #2816015
09/01/20 09:36 PM
09/01/20 09:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Very nice. Congrats!
Love the pic too.
Re: New best this weekend! [Re: BSB67] #2816067
09/02/20 01:15 AM
09/02/20 01:15 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
n2omstr, I only recently started playing with nitrous and I'm taking baby steps with it.
I wanted to do it right and studied up on it thoroughly prior to pulling the trigger. I just recently installed a bottle heater and have the pressure switch adjusted to keep it exactly where I want it.
'63 Dodge 330
11.19 @ 121 mph
Re: New best this weekend! [Re: GY3] #2816074
09/02/20 01:35 AM
09/02/20 01:35 AM
Not trying to hijack this thread but hearing about bottle pressures on NOS system a lot, how important is that?
Doesn't it need a certain amount of pressure to keep it in liquid form? Doesn't it turn into gas without that pressure?
Re: New best this weekend! [Re: Cab_Burge] #2816112
09/02/20 07:46 AM
09/02/20 07:46 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am not a nitrous expert by any means but more pressure obviously equals more nitrous. You want to be consistent because that is a variable in your tune up. I once broke the spring perches, driveshaft, and sprag because I tried to make a run with a hot bottle knowing it would make my junk faster because it was a little rich lol.
I don't play with nitrous anymore haha.
Re: New best this weekend! [Re: Bad340fish] #2816114
09/02/20 08:03 AM
09/02/20 08:03 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice!
Re: New best this weekend! [Re: Cab_Burge] #2816124
09/02/20 08:44 AM
09/02/20 08:44 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Very important!
Right around 1000 psi or 91*-92* bottle temp is optimum.
'63 Dodge 330
11.19 @ 121 mph
Re: New best this weekend! [Re: GY3] #2816137
09/02/20 09:35 AM
09/02/20 09:35 AM
N
n20mstr Offline
n20mstr  Offline
N
Let it rip ..... lol
Don’t know what heads you have . Just be careful with timing . Most BBM heads are now t nitrous friendly . And your cam probably not tailored for opening exh early to get the heat out . But what your using is not a lot . You doing
Great , baby steps ..... just hurry up and get it in the 9’s .
And I bet that won’t be enough for you .... lmao
We all say X but always want more !
Happy ET hunting !
Re: New best this weekend! [Re: n20mstr] #2816144
09/02/20 09:57 AM
09/02/20 09:57 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Happy ET hunting !
I'm using a Nitrous Express Mainline kit and the next step up, 250hp, is pretty much the limit of the tiny solenoids. As I recall the nitrous jet for that is like a 137, so no jet at all, just straight through. LOL!
We built a custom china rail hold down for the solenoids and make it semi hidden and look a little cleaner.
'63 Dodge 330
11.19 @ 121 mph
Re: New best this weekend! [Re: GY3] #2816181
09/02/20 11:52 AM
09/02/20 11:52 AM
N
n20mstr Offline
n20mstr  Offline
N
What heads are you using on that engine ?
Re: New best this weekend! [Re: GY3] #2816187
09/02/20 11:59 AM
09/02/20 11:59 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I’d get rid of that plastic oil line for the pressure gauge.
Re: New best this weekend! [Re: n20mstr] #2816188
09/02/20 11:59 AM
09/02/20 11:59 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Modern Cylinder Head ported Stealths.
'63 Dodge 330
11.19 @ 121 mph
Re: New best this weekend! [Re: GY3] #2816189
09/02/20 11:59 AM
09/02/20 11:59 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nice!!
Re: New best this weekend! [Re: GY3] #2816204
09/02/20 12:30 PM
09/02/20 12:30 PM
N
n20mstr Offline
n20mstr  Offline
N
Best upgrade you can make , put a -6 feed line , get a larger orifice nitrous solenoid . Whatever you can do to feed the jet you will pick up . Even at the same jet .
Also I noticed you have grounds separate , I would have both solenoid grounds together
Re: New best this weekend! [Re: n20mstr] #2816212
09/02/20 12:45 PM
09/02/20 12:45 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Hmm, good to know. Will only take a minute to change.
'63 Dodge 330
11.19 @ 121 mph
Re: New best this weekend! [Re: justinp61] #2816229
09/02/20 01:19 PM
09/02/20 01:19 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yes, that was supposed to be temporary but here we are a few years later... shruggy
'63 Dodge 330
11.19 @ 121 mph
Page 2 of 3 1 2 3
