Re: 96 Dakota trans cooler line, remove the check valve?
[Re: poorboy]
#2816228
09/02/20 01:19 PM
09/02/20 01:19 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The check valve prevents the high-mounted cooler from draining back through the converter. I would remove it, lining material from the lockup converter is what normally clogs the check valve. Make a habit of making the first start of the day in Neutral instead of Park or install an aftermarket manual valve in the trans.
[Re: volaredon]
#2816489
09/02/20 09:53 PM
09/02/20 09:53 PM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
OK then, I have a question about that 96 Dakota that you are parting. I also have a 96 4wd Dakota. Are you using the steering column and the intermediate shaft between column and box> The stub shaft with the 2 U joints. I need that part for mine badly. If you arent using that and want to sell, I'd buy it from you. and a far fetched "how's the body"? I posted on your thread. I may have another shaft laying around here, while the 96 was still drivable, I had a column hooked to the cab on Dakota 4x4 frame so I could move it around the yard. The body on the 96 was in much better condition then the frame was, but it was not cherry. Unfortunately, I cut up most of the decent cab, I've removed the firewall and the tunnel from an extended cab that only needed rockers the rest of the cab is still here, but the entire interior is removed. The center of the door bottoms are separated on both doors, but other then that, the doors were pretty straight, I may be cutting the door handles out of the doors to use the latches, handles, and locks, but those parts don't need to come from these doors (except the locks that match my ign key. The box is pretty nice, it would need patches on the top of the wheel tube inside the box, I didn't remove the fender extensions, but the box sides look pretty good. at this point, I'm intending on using the box floor and front panel, but it is still intact right now. The front fenders are junk, there is a rather large hole right through the top of the inner fenders on both sides. Posted are pictures I have of the black Dakota. The last picture, inside the bedliner, you can see the bottom of one of the front fenders. Both look about the same. No one around here is doing anything with this era Dakota. I'm cutting the parts out of this one because it would just go to the scrap other wise, I really do not want it sitting here over the winter if I can help it. If there is anything you can use, let me know, I'll take specific pictures of those parts, I'd rather see them save a truck then be cut up or scrapped. Gene
[Re: poorboy]
#3220704
03/15/24 08:42 PM
03/15/24 08:42 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Hello. I am curious if the check valve is the difference from the 93 and earlier lines? I need lines for my 93 and see that Dorman and Duralast has them for 94-96 only Does anyone know what the other difference is? Fittings is the only thing that I can think of.
Common sense is a flower that does not grow in everybody's garden
[Re: poorboy]
#3220822
03/16/24 02:03 PM
03/16/24 02:03 PM
Ron_M
Connecticut
Thanks Gene, much appreciated. Did you use the Dorman lines? Did you need to purchase any fittings? I see in the first sentence that they matched. I'm leery of getting lines that won't work.
[Re: Ron_M]
#3220948
03/17/24 02:03 AM
03/17/24 02:03 AM
poorboy
Freeport IL USA
Thanks Gene, much appreciated. Did you use the Dorman lines? Did you need to purchase any fittings? I see in the first sentence that they matched. I'm leery of getting lines that won't work. Sorry, all I deal with are factory lines, but the lines from the older Dakota (early 1990) and the lines for the newer Dakota (at least up to 96) all interchange (bolt in, no modifications). Both the trans end fittings and the rad end fittings between the old and the new are the same fittings. Dorman has been making replacement parts for a very long time. I suspect the reason for the limited dates on the trans cooler lines are because of the inline check valve. The earlier trans cooler lines did not have the check valve, so the newer lines are not considered a direct replacement. Doesn't mean they won't fit, just not exactly the same (the newer lines have the check valve, the old lines didn't have them, so they are not exactly the same). The fittings in the radiator are the same and the fittings on the transmission are the same. The transmission fittings are at the same location on the trans, and the fitting location on the radiators are in the same. The relationship between the transmission and the radiator are the same on all the 89-96 Dakotas. I don't see any reason the Dorman lines won't work on your truck, unless there is a difference stated for different motors. If the motor use isn't stated as being different, all motors will use the same lines. I removed the check valve on my cooler line because it was partly plugged up inside when I got the truck. I don't need the check valve in my cooler line on my truck because it gets used every day, and I put it in neutral (out of habit) after the 1st startup every day for about 30 seconds before I go anywhere. That 30 seconds in neutral refills the converter of any fluid that may have drained back into the trans pan while the truck was parked. I've been doing that for years. The purpose of the check valve in the line was to keep the converter from draining the fluid back into the trans pan after sitting for a while. A converter can cause as much as 2 quarts to drain back into the pan and causes fluid leaks (by raising the fluid level in the pan above the pan and low transmission seals) and cause poor cold transmission function because the converter was not full of fluid on first start ups, after sitting for a while. The challenge with the inline check valve is they can get plugged up over time from the small particles from the friction discs that get wore off from normal use, over time. The fluid picks up those fine particles and they collect around the check valve ball in the cooler line and prevents the ball from functioning correctly. Timely fluid changes at factory intervals usually solves the plugging issue, lack of fluid changes cause the problem.
[Re: poorboy]
#3220978
03/17/24 10:09 AM
03/17/24 10:09 AM
Ron_M
Connecticut
Thanks for the explanation, much appreciated. I just ordered the Dorman lines.
