fuel tank sending unit #2815582
08/31/20 03:59 PM
08/31/20 03:59 PM
italy
antonellomopar Offline OP
italy
Hello
what is an accurate sending unit for my 68 Charger RT? The readings are completely off...
Thank you
Re: fuel tank sending unit [Re: antonellomopar] #2815593
08/31/20 04:44 PM
08/31/20 04:44 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
No one's made one yet. Unfortunately, they are all junk. Tons of people make them, but they can't get the little resistive element correct. Sad.
Re: fuel tank sending unit [Re: 375inStroke] #2815612
08/31/20 06:00 PM
08/31/20 06:00 PM
italy
italy
Heve seen prices on ebay from 30 to 140 usd for modern stuff...but can't find a correct one.
Re: fuel tank sending unit [Re: antonellomopar] #2815619
08/31/20 06:15 PM
08/31/20 06:15 PM
md
mopars4ever Offline
mopars4ever  Offline
md
nos 3420848. a few out there but not cheap.
Re: fuel tank sending unit [Re: mopars4ever] #2815622
08/31/20 06:21 PM
08/31/20 06:21 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Bought mine from Kramer Auto 3 years ago and it is still accurate. They check calibration before they ship it out. It might not be on their website so you will have to call.
http://www.kramerauto.com/
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: fuel tank sending unit [Re: antonellomopar] #2815663
08/31/20 08:35 PM
08/31/20 08:35 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Originally Posted by antonellomopar
Hello
Thank you
I used one of these on my '69 Super Bee: https://www.tanksinc.com/index.cfm/...748/category_id=184/mode=prod/prd748.htm
Its a bit of a hassle to set it up, but since I installed it and calibrated it, it has worked flawlessly for me.
Basically, you put this device between the sending unit and the gauge and give it power. You drain the tank and then fill the tank in increments until full, calibrating the device at each step. The device will then read from full to empty and everywhere in between in a true linear sweep.
beer
Paul
'69 Super Bee 383 EFI Turbo
Re: fuel tank sending unit [Re: Black_Bee] #2815671
08/31/20 09:02 PM
08/31/20 09:02 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Hello
Thank you
beer
Just wondering, if the sender in the tank isn't sending a signal to this box, how is it going to work?
Re: fuel tank sending unit [Re: GODSCOUNTRY340] #2815882
09/01/20 02:31 PM
09/01/20 02:31 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Hello
Thank you
beer
It definitely requires a signal from the sending unit. As mentioned previously, "you put this device between the sending unit and the gauge and give it power"
The issue that this device corrects is when the gauge and the sender are calibrated to different values. The sending is on "full" but the gauge reads 1/2 or whatever. This device adjusts the signal so that when the sender reads full (and 1/2 and empty and all points between), the gauge does too.
Paul
Re: fuel tank sending unit [Re: Black_Bee] #2815982
09/01/20 08:15 PM
09/01/20 08:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The sending unit is just a variable resistance ground.
Re: fuel tank sending unit [Re: Black_Bee] #2817518
09/05/20 05:02 PM
09/05/20 05:02 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Hello
Thank you
beer
The resistance profile for pretty much all repro senders are mismatched to the OE rallye gas gauge. The guys website who designed/produced the original Metermatch is here. Helped him verify his latest design, the one sold by tanksinc, works with both OE instrument panel 5v analog regulator and RT-Eng digital regulator. In fact, the Ford preset was very close to the 73-10 ohm calibration needed for the repro senders in my 70RR and daughters 69 RT.
