E-body Small block clutch adjustment rod #2815185
08/30/20 06:50 PM
08/30/20 06:50 PM
Ashland City, Tennessee
Aar1064 Offline OP
Aar1064  Offline OP
I have a confusing issue with my adjustment rod. I purchased a repop and it’s attached to an original torque shaft and correct fork. The issue is that it’s angled on end and doesn’t last flat on the torque shaft arm like it should.
The adjustment rod for e-body big blocks is straight not angled and would work perfectly with the alignment that I have with the arm and end of fork.
Any pics of small blocks that you can share?
Re: E-body Small block clutch adjustment rod [Re: Aar1064] #2815204
08/30/20 07:31 PM
08/30/20 07:31 PM
Flip it over 180 degrees and see how that works wrench scope
I think that is the correct way to run them on the E body stick cars, it has been over thirty years since I sold my last one confused
I would use that A motor rod in all of my E and B body stick shift cars up
Re: E-body Small block clutch adjustment rod [Re: Cab_Burge] #2815213
08/30/20 07:54 PM
08/30/20 07:54 PM
Aar1064 Offline OP
Aar1064  Offline OP
I tried that and no better. Part number in book is 2534240 for small block. A quick search revealed a NOS one on EBay and it’s straight. All vendors that I’ve checked sell the angled one for small blocks. I figure a straight one will get me on my way but just can’t understand how they all can be wrong.
Thanks for the help.
Re: E-body Small block clutch adjustment rod [Re: Aar1064] #2815241
08/30/20 09:15 PM
08/30/20 09:15 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Angled is correct, and it is flipped the wrong way in the photo.
Do you have the correct length clutch fork?
Re: E-body Small block clutch adjustment rod [Re: Alaskan_TA] #2815272
08/30/20 10:31 PM
08/30/20 10:31 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
rolleyes
I wish all my mechanical problems were this simple to solve:
Pull it off and pound it flat.
You're welcome.
Mo' Farts
Moderated by "tbagger".
Re: E-body Small block clutch adjustment rod [Re: Alaskan_TA] #2815275
08/30/20 10:38 PM
08/30/20 10:38 PM
Aar1064 Offline OP
Aar1064  Offline OP
Flipped 180 is how I originally had it but it threw the clip because it never fit properly. I’ll flip it again for another photo for reference.
Clutch fork is correct. I dropped dust cover today to check that. 10 7/8”.
Thanks for the reply.
Re: E-body Small block clutch adjustment rod [Re: Grizzly] #2815279
08/30/20 10:46 PM
08/30/20 10:46 PM
Aar1064 Offline OP
Aar1064  Offline OP
Originally Posted by Grizzly
rolleyes
You're welcome.
Thought of that but it is hardened steel and I’m afraid of bending the shaft. Trying to understand which is correct for others. I have all the correct components associated with the rod and those being sold for small blocks are angled but isn’t working for me. Why! Why! Why! Lol.
Re: E-body Small block clutch adjustment rod [Re: Grizzly] #2815290
08/30/20 11:09 PM
08/30/20 11:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
rolleyes
You're welcome.
Agreed, had the same issue on the smblk 4spd in my Challenger, put it in a vise and a pipe over the threads and bend it straight, why the factory made it this way is beyond me...friggen Engineers
Re: E-body Small block clutch adjustment rod [Re: Aar1064] #2815328
08/31/20 05:54 AM
08/31/20 05:54 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Pounding it flat would be quite ignorant when it was intended to be this way.
Re: E-body Small block clutch adjustment rod [Re: Alaskan_TA] #2815329
08/31/20 05:56 AM
08/31/20 05:56 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Notice the adjusting nut orientation as well. scope
Re: E-body Small block clutch adjustment rod [Re: Alaskan_TA] #2815338
08/31/20 07:03 AM
08/31/20 07:03 AM
Aar1064 Offline OP
Aar1064  Offline OP
That’s an all together different setup at the adjusting nut end compared to what I’ve seen. This may be the reason why the orientation of nut is different.
Notice too how short the fork appears. This would call for an angled rod eyelet. I have a photo of a TA that validates this.
....but post a pic of the low mileage TA and it will contradict this. Well it seems that it does.
What the crap is going on?
Re: E-body Small block clutch adjustment rod [Re: Alaskan_TA] #2815385
08/31/20 10:04 AM
08/31/20 10:04 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Okay, dropping a driveshaft, transmission, exhaust, bellhousing and clutch, wasting time looking for parts and spending money is the "proper" way to go. This from a Guy that uses a dump truck as a commuter.
Pound it flat like anyone with some common $ense would, and move on with your life. twocents
Mo' Farts
Re: E-body Small block clutch adjustment rod [Re: Aar1064] #2815417
08/31/20 10:57 AM
08/31/20 10:57 AM
You need to get the retainer orientated correctly for it to work wrench, They are a pain to install on E body A motor cars properly whiney
Make sure the tranny is installed before installing the rod and retainer twocents
Re: E-body Small block clutch adjustment rod [Re: Cab_Burge] #2815429
08/31/20 11:10 AM
08/31/20 11:10 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Maybe it is just the angle of the pic but it looks like that OP adjusting rod has more of a bend then others I have seen.
Re: E-body Small block clutch adjustment rod [Re: mopars4ever] #2815481
08/31/20 12:37 PM
08/31/20 12:37 PM
Aar1064 Offline OP
Aar1064  Offline OP
Yes it does but is same as repops being made these days.
I have another picture of a well known survivor AAR that shows the rod as straight.
Ok hear me out. What if there were shorter forks mixed in with what we believe is the correct length (or what's being sold as correct 10.88") and assembly just used either the flat or angled rod depending on which fork was installed. That theory may be blown due to the fact of the changing pivot points of the fork.
May be grasping here but it's fun learning about it. I do understand the idea of moving on and do know that it can simply be resolved but would still like to know if possible, Why.
Re: E-body Small block clutch adjustment rod [Re: mopars4ever] #2815487
08/31/20 12:42 PM
08/31/20 12:42 PM
GA
roadrunninMark Offline
GA
It looks like something is not right with your clutch fork. It looks to be sticking out too far or is the too long? Barry's fork does not extend all the way to the mount at the z bar but yours does. Could the throw out bearing not be fully engaged in the fork?
Could the z bar be wrong?
Re: E-body Small block clutch adjustment rod [Re: roadrunninMark] #2815506
08/31/20 01:28 PM
08/31/20 01:28 PM
Aar1064 Offline OP
Aar1064  Offline OP
Measured ZBar and Fork yesterday.Measurement from arm to end was 1 1/2 which is same as your bottom picture. Fork is 10 7/8. Took the dust cover off and measured to doublecheck. Fork end is attached to throw out bearing as it should be.
Thanks for the help
Re: E-body Small block clutch adjustment rod [Re: Aar1064] #2815519
08/31/20 01:50 PM
08/31/20 01:50 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I would pound it flat and get rid of the troublesome stock rubber end adjuster and go with this.
https://www.ebay.com/itm/Mopar-Clutch-Linkage-Upgrade-A833-340-440-Dart-Coronet-GTX-R-T-Cuda-Charger-GTX/324275222079?epid=1923119374&hash=item4b804f363f:g:2JEAAOSwq4ld~9VH&vxp=mtr
That's whats in Barry's picture and it works 100 times better.
Re: E-body Small block clutch adjustment rod [Re: KillerBee] #2815532
08/31/20 02:14 PM
08/31/20 02:14 PM
Aar1064 Offline OP
Aar1064  Offline OP
That's whats in Barry picture and it works 100 times better.
Yes I noticed it was being used in the picture as well. Good to know they work better. I have one of those and may look into that.
Thanks, Chet
Re: E-body Small block clutch adjustment rod [Re: Alaskan_TA] #2815540
08/31/20 02:44 PM
08/31/20 02:44 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Barry, The picture you've shown is NOT OE for 1970 I assure you.
its missing the washer, and the rubber insulator bushing. The nut is supposed to go on the other way thus swedged into the washer to keep it locked in place
My money is on the OP has the wrong Z bar , or at the very least is installed backwards , if thats possible
