My throttle cable tightens before secondaries open #281378
04/08/09 12:27 PM
04/08/09 12:27 PM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
As I'm driving when i press the pedal far enough, right before the secondaries whoosh, there is a bump in the throttle cable travel. Like i'm fighting the engine vacuum to inch the pedal past , and into the power. Is this normal?
On top is a vac secondary holley 600 under it, a 323" w/ headers 3.23 gears.
Re: My throttle cable tightens before secondaries open [Re: mark7171] #281379
04/10/09 01:47 PM
04/10/09 01:47 PM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
antibody?
Re: My throttle cable tightens before secondaries open [Re: mark7171] #281380
04/10/09 02:03 PM
04/10/09 02:03 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
You sure its not the kickdown linkage?
Re: My throttle cable tightens before secondaries open [Re: GTX MATT] #281381
04/10/09 02:26 PM
04/10/09 02:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Are you sure it isn't the KD linkage that is misadjusted??
