Hydraulic roller #2813031
08/25/20 11:54 AM
08/25/20 11:54 AM
Maryland
twayne24365 Offline OP
Maryland
Anyone here running hydraulic roller cams for street use?
Thinking of using one on my current build. I lost a love on a solid cam awhile back and would rather not to that again!
Re: Hydraulic roller [Re: twayne24365] #2813040
08/25/20 12:04 PM
08/25/20 12:04 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
My auto correct to English dictionary tells me that you lost a lobe on a solid flat tappet and would rather not do that again.
So much for artificial intelligence.................or it would know that I very rarely type " duck ".
I have not run one........I have a solid roller that sees street miles and has been trouble free.
My understanding is that they are pretty critical of spring pressure and lifter pre load compared to a hyd. flat tappet.
But I think that if they weren't worth a dang , the OEM's wouldn't have them in nearly every motor that leaves the assembly line.
Like anything else , stick with quality parts and you should be fine.
Re: Hydraulic roller [Re: tubtar] #2813046
08/25/20 12:16 PM
08/25/20 12:16 PM
Maryland
Maryland
Yea, auto correct gets me every time!
And that’s what I figure, hydraulic rollers are in all the new stuff and go well over 100k no problem.
Re: Hydraulic roller [Re: twayne24365] #2813157
08/25/20 05:10 PM
08/25/20 05:10 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Take a look at this thread of mine on here about something very similar.
For me this was a move from a hydraulic flat tappet to a hydraulic roller setup. I do not have this build finished yet, so unfortunately no feedback, although I am interested in what otherws will say.
Re: Hydraulic roller [Re: Diplomat360] #2813164
08/25/20 05:29 PM
08/25/20 05:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run a Howards hydraulic roller and absolutely love it!
'63 Dodge 330
11.19 @ 121 mph
Re: Hydraulic roller [Re: GY3] #2813284
08/25/20 09:17 PM
08/25/20 09:17 PM
New York, USA
Chargerfan68 Offline
New York, USA
Just curious, do you run the “street” lifters or the “max effort” lifters. I have them going into a build that should be done in a few weeks. Hoping they perform flawless for a good long time. Fingers crossed.
Re: Hydraulic roller [Re: Chargerfan68] #2813337
08/25/20 11:05 PM
08/25/20 11:05 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Street.
'63 Dodge 330
11.19 @ 121 mph
Re: Hydraulic roller [Re: GY3] #2813363
08/26/20 12:29 AM
08/26/20 12:29 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I have the trickflow cam in a 10 to 1 440 with ported sidewinders. Absolutely love the power it’s making with that cam.
It’s 243/247@050 .600/.600 lift on 108lsa. I had roughly 1000 miles on the motor with a 230@050 .520 roller.
It made 490hp and 553tq with that cam. The new cam feels like 75hp more and likely 30 more torque all the way through.
Lifters are Howard’s if I remember correctly.
Re: Hydraulic roller [Re: viperblue72] #2813506
08/26/20 11:23 AM
08/26/20 11:23 AM
Maryland
Maryland
Sounds like it’s working pretty good!
Re: Hydraulic roller [Re: twayne24365] #2813830
08/27/20 06:43 AM
08/27/20 06:43 AM
Norway
cudaerik Offline
cudaerik  Offline
Norway
six summers now with lots of street miles with Hughes Racing hydraulic roller with Morel 5319 lifters, just make sure your lifter bores are within spec. if oval our out of spec have them bushed.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
