cuda offset rear shackle kit #2812349
08/23/20 07:40 PM
08/23/20 07:40 PM
N.Y.
sixpacksteve Offline OP
N.Y.
looking to find something without cutting the frame in front.
didn't someone make a kit to offset the front of shackle 2"?
Hell Hath No Fury Like Mine
Re: cuda offset rear shackle kit [Re: sixpacksteve] #2812371
08/23/20 08:31 PM
08/23/20 08:31 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I know they did 1" per side so you could bolt a 44" b-body housing in, dr diff now sells that kit, pretty sure 2" per side would be in the frame rail.
Re: cuda offset rear shackle kit [Re: 4406bbl] #2812425
08/23/20 11:15 PM
08/23/20 11:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Be careful I used the offset shackle kit in a car. the rear shackle hits and will leave a dimple in the rear valance during jounce and rebound
Re: cuda offset rear shackle kit [Re: sixpacksteve] #2812565
08/24/20 12:53 PM
08/24/20 12:53 PM
central il.
second 70 Offline
second 70  Offline
central il.
Dr, Diff has an offset kit.
Re: cuda offset rear shackle kit [Re: second 70] #2812688
08/24/20 04:45 PM
08/24/20 04:45 PM
BDW Offline
BDW  Offline
Check with the Dr, had to trim the valance braces on my Challenger with the 1” kit.
Re: cuda offset rear shackle kit [Re: BDW] #2812916
08/25/20 05:17 AM
08/25/20 05:17 AM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
http://www.moparts.org/Tech/Archive/rearsusp/12.html
They only listed front offset spring hangers for E bodies with SS springs when i bought mine (they would be longer and not work with stock springs).
The A body front offset spring hangers had 2 holes and you can flip em upside down side to side etc.... and change ride height
Morroso spring perches have the correct size hole. (The MP ones had too large of a locator hole)
Re: cuda offset rear shackle kit [Re: BDW] #2813439
08/26/20 09:07 AM
08/26/20 09:07 AM
Winnipeg, Manitoba, Canada
71rag Offline
71rag  Offline
I tried to order the 1" shackle kit from Dr Diff for either stock length or Super Stock but not available
Re: cuda offset rear shackle kit [Re: 71rag] #2813486
08/26/20 10:40 AM
08/26/20 10:40 AM
GA
roadrunninMark Offline
GA
Watching Roadkill, the episode with the "vanishing paint" challenger, they turned that car into a road course machine. They mentioned that they welded a plate to the front hanger that went inboard and mounted the shackle mount to that. That allowed them to move the springs in and get more tire clearance. Now, if you are a member of MotorTrend streaming, you can watch the episodes where they actually build the car. That show is called Roadkill Garage. I think there are 2 episodes for the build of that car. I don't subscribe so I haven't seen them. I thought that was an inexpensive way to take care of the front mount.
Or you can do the opposite too, weld a plate to the outer side so you dont have to mess with the mount. Just drill 4 new holes to mount to the frame. I think this is the way they did it, if I remember correctly.
Roadkill S4 Ep. 16
Re: cuda offset rear shackle kit [Re: sixpacksteve] #2813504
08/26/20 11:19 AM
08/26/20 11:19 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have Dr Diff's inboard spring hanger kit and 3200 lbs SS Springs on my 3700 lbs 1970 'Cuda. There were no fitment issues, and they don't hit the rear valance. I used a narrower1967 B-Body Dana 60. I am able to fit 325/50-15 Nitto Drag Radials without rubbing.
Re: cuda offset rear shackle kit [Re: jbc426] #2813532
08/26/20 12:24 PM
08/26/20 12:24 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The dr diff kits had a 1" offset front bracket, with 2 spring height holes and a 3/4 offset rear shackle. I had no issue with the valance on cudas with stock length springs. He used to sell a 1.5" offset kit that some said would hit the valance, it used the same front hanger and more offset at the rear, as e-body springs are in the car at an angle. I would measure the valance now and see how far you can go, then call cass, aka doctor diff. I put the 1.5 kit in for a guy 12 years or so ago and he never said the valance was a problem, but he also was a bodyman so moving the cuda valance bulge over would have been easy for him.
Re: cuda offset rear shackle kit [Re: roadrunninMark] #2813538
08/26/20 12:35 PM
08/26/20 12:35 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Motor trend on demand dropped the price to $1 a month. I missed that but was able to sign up at $2 a month. For that price it was worth it. Not sure if that deal is still good
Re: cuda offset rear shackle kit [Re: MoonshineMattK] #2813902
08/27/20 11:26 AM
08/27/20 11:26 AM
moparx Offline
moparx  Offline
just saw the $2.00 a month add last night.
beer
Re: cuda offset rear shackle kit [Re: moparx] #2813915
08/27/20 12:16 PM
08/27/20 12:16 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My E-body offset hanger/shackle kits move the springs inward 1" per side (front and rear). This allows a stock '65-'70 B-body rearend to bolt into an E-body. For reference, a '65-'67 B-body rearend with a 28/12/15 MT Sportsman SR (street radial), 10" wide wheel and 5" backspacing fits nicely.
I make a shorter shackle to facilitate rear valance clearance for all Barracuda and some Challenger applications.
The kits should be back in stock in about 2 weeks.
