M/T Drag Radial Users, Is this normal? #2812562
08/24/20 12:49 PM
08/24/20 12:49 PM
Tennessee
727builder Offline OP
Tennessee
Friend of mine brought me his 72 duster to find his vibration issue. He notices it trying to do burnouts and down track. This new set of MT ET street has 3 races on them since he got them from Jegs. They are balanced. Not the best video, But can see the drive side tire has a pretty good out of round issue to it. Several of us around here run these. But I've never seen one look this out of round.
Normal? Or bad tire?
Video 👇👇👇
https://youtu.be/WzTC4yomxHA
Re: M/T Drag Radial Users, Is this normal? [Re: 727builder] #2812576
08/24/20 01:13 PM
08/24/20 01:13 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Was it sitting a while before taking that vid? They can flat spot a -little- if parked a long time.
I would drive it a bit and try again, assuming it's not wheel/axle.
Also if it's not running rim screws or beadlocks mark the tire and rim. The rim can spin inside the tire which then puts it out of balance.
Re: M/T Drag Radial Users, Is this normal? [Re: 727builder] #2812578
08/24/20 01:31 PM
08/24/20 01:31 PM
They should not be out of round, measure how much they are out and contact M/T to get them to take care of your friend wrench scope
Re: M/T Drag Radial Users, Is this normal? [Re: INTMD8] #2812598
08/24/20 02:08 PM
08/24/20 02:08 PM
Tennessee
Tennessee
He raced it saturday night. The pass side don't look out of round like this one when spinning. What's funny he just texted me and said the guy who balanced them when new, Asked him if they been sitting a long time? He must have noticed it too? He has them marked on inside of wheel. Dont look like they've spun any on the rim. Not a real fast car. 7.70s 1/8 mile with 3.55 gears.
Edit, He's been on hold with Jegs for the last 30 mins. I doubt if they do anything.
Re: M/T Drag Radial Users, Is this normal? [Re: 727builder] #2812711
08/24/20 05:27 PM
08/24/20 05:27 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i had a set of Pro275s a few years ago . Massively out of balance needed like 200grams . Ran them unbalanced initially and thought wheel was coming off , low 11s car . Talked to MT and they were returned and refunded
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: M/T Drag Radial Users, Is this normal? [Re: 727builder] #2812759
08/24/20 07:40 PM
08/24/20 07:40 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The last 2 sets of MT drag radials that I have gotten have been out of round. Egg shaped in fact. I have a pair of 295/65s now that I took off the car because I cannot stand to drive the car above 50mph. They vibrate BAD! I should have called MT, but I waited a few months before I mounted them and figured it was too late.
I have see other sets that were bad on other guys cars, too.
I wished MT would get their act together. rant
Master, again and still
Re: M/T Drag Radial Users, Is this normal? [Re: DaveRS23] #2812773
08/24/20 07:58 PM
08/24/20 07:58 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Man a lot of guys run them locally and they all love them and race every weekend.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: M/T Drag Radial Users, Is this normal? [Re: pittsburghracer] #2812844
08/24/20 10:15 PM
08/24/20 10:15 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
dont get me wrong , i have MT pro brackets on car and used to use et streets . just noting its not totally unusual.
Tex
New best MPH 130.32
Re: M/T Drag Radial Users, Is this normal? [Re: tex013] #2812901
08/25/20 01:02 AM
08/25/20 01:02 AM
Tennessee
Tennessee
Thanks for the replies guys... Was mainly wondering if other Users have had them out of round like this? Several of us who bracket race use them. This is the first bad ones we've run across. . I see m/t are having some problems with them.
After I posted that video I ran it in 3rd gear while on the lift. The vibration at higher tire speed was a lot worse.
The owner sat on phone with jegs 45 mins with no one answering.
He tried M/T customer service and the number was busy all day.
Hoping tomorrow he can get them on the phone.
Anyone have a supplier for them other than summit and Jegs?
Evidently they both are out of them. On back order I guess.
Thanks again for the replies! 👍👍
Re: M/T Drag Radial Users, Is this normal? [Re: 727builder] #2812937
08/25/20 07:20 AM
08/25/20 07:20 AM
PA.
"Little"John
"Little"John
PA.
I tried to look up a price over the weekend for a set of 14-32 M/T slicks and they were also out of stock. Someone on Facebook told me they had a fire at one of their plants and that was causing and issue. Sounds like things will be better soon.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: M/T Drag Radial Users, Is this normal? [Re: pittsburghracer] #2813083
08/25/20 01:57 PM
08/25/20 01:57 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My buddy was going to get a new pair of 14-32 MT's and couldn't find any. We have a friend in common who is pretty well connected in the racing industry and even he couldn't get a pair.
