Comp dead horse #2805893
08/06/20 07:15 PM
08/06/20 07:15 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
After 1000 miles of breakin and daily clatter for the first few miles (every time), I pulled them. Comp 8921 HD rollers. Of the 16, four lost prime by the time I popped the Sniper intake off. They were still hot. So will try Hughes. Nothing but a street rally RV type build. More to follow. Phish
CALMED THE QUAKE!!!(AGAIN!)
Re: Comp dead horse [Re: Spyphish] #2805904
08/06/20 07:54 PM
08/06/20 07:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Dunno what's up with Comp, they used to be a dependable source. But between their infamous 20 mile fuel pump pushrods and several other experiences I'm beginning to think they are sliding downhill. shruggy
I've got a customers motor with less than 100 miles on it. It ate the # 1 & 3 cylinder lifters. The rest are all picture perfect shruggy I am curious to tear it down and see who's camshaft is in it
whistling beer
Re: Comp dead horse [Re: TJP] #2806163
08/07/20 02:10 PM
08/07/20 02:10 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Yeah, please update this thread when you can. I've got about 5k on my build with a 230@.050 Comp roller kit. It sounds like a damn diesel. At first I thought it was just normal as it's my first aftermarket retrofit roller motor, but after reading these threads and hearing other cars with different brand setups this makes me nervous.
Re: Comp dead horse [Re: MarkZ] #2806254
08/07/20 07:01 PM
08/07/20 07:01 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Will do, I did forget to mention it was a flat tappet motor wink
Re: Comp dead horse [Re: TJP] #2806484
08/08/20 10:15 AM
08/08/20 10:15 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
whistling beer
Friend had a BB Comp XE268 eat TWO EXACT SAME cams and lifter on a run stand within minutes. Summit took back the first and had the 2nd within a few weeks. Took back the 2nd too.
I felt bad and sold him a NOS MP 272 purple cam and lifters I had on the shelf for 20 years.
No problems whatsoever.
He made some calls to industry friends and no one was surprised at all. Seems Comp’s quality has gone really down since they were last bought out
Re: Comp dead horse [Re: autoxcuda] #2806592
08/08/20 03:08 PM
08/08/20 03:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
When was that and who bought them ??? beer
Re: Comp dead horse [Re: TJP] #2806748
08/09/20 07:33 AM
08/09/20 07:33 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
OK, the Hughes lifters arrived and the plunger height is taller but a high quality unit. The oil band is wider as well (good thing) and instructions say to NOT soak in oil. We have taken measurements and will have Smith Bros. make shorter ball cup pushrods Monday. Comp 8.71 pushrods with their lifter, we need 8.34. This was a police motor so high idle time we presume. The comp lifters show some mild scuffing so we are checking the lifter bores. Also thinking of adding a PRW shaft/rocker kit up top as using stock shafts ebay used Isky rockers, no roller tip. Move some money around, keep Ameica great. Be back when we fire it up again. Phish
Re: Comp dead horse [Re: Spyphish] #2806765
08/09/20 09:10 AM
08/09/20 09:10 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I've always felt the two biggest problems with comp cams is their components and the idiots on the phone. I try to avoid them.
Re: Comp dead horse [Re: lewtot184] #2806910
08/09/20 03:43 PM
08/09/20 03:43 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
It appears Comp has changed hands twice in the last 6 years.
Re: Comp dead horse [Re: slantzilla] #2811103
08/20/20 02:50 PM
08/20/20 02:50 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Well, let me get the lifter companys out from under the bus possibly. Tried a set of Howards and it is worse. Was quite for about 10 miles then one must have colapsed. At least Comps eventually got quite. So we are pulling the intake and dizzy. Will prime motor with a drill while we roll the engine and check each one for prime/hold etc. Also mic the lifter bores as well. I am changing the rockers and shafts as they were used. It will now be new pan to carb. Running out of ideas and funds..... good thing Great Race was cancelled. We were to be in San Antonio today. Jake
Re: Comp dead horse [Re: slantzilla] #2811187
08/20/20 05:54 PM
08/20/20 05:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
Since when? confused
I remember them buying Lunati several years ago and I think they sold that company later work
Re: Comp dead horse [Re: Cab_Burge] #2811247
08/20/20 07:29 PM
08/20/20 07:29 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
LINK - edelbrock-owner-acquires-comp-performance-group
Re: Comp dead horse [Re: GomangoCuda] #2811358
08/20/20 11:07 PM
08/20/20 11:07 PM
Thanks for the link up, I did not know of this deal whiney
I have seen a lot of good Hi Po company get bought out by "private equity firms, I fear they are going to end up putting the screws to all of us hot rodders and racers in the name of increased profits in their pockets whiney work
Re: Comp dead horse [Re: lewtot184] #2811401
08/21/20 01:09 AM
08/21/20 01:09 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That seems to cover everything.
Re: Comp dead horse [Re: Cab_Burge] #2811552
08/21/20 12:06 PM
08/21/20 12:06 PM
GomangoCuda Offline
GomangoCuda  Offline
Frankly it startled me to read that they already had Edelbrock. Are these companies cashing out because they know something about the future of aftermarket parts that we don't know yet?
"Private Equity Firm" is that the politically correct name for Corporate Raiders?
Re: Comp dead horse [Re: GomangoCuda] #2811654
08/21/20 03:16 PM
08/21/20 03:16 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
IMO, Performance aftermarket retrofit hyd roller lifters aren’t going to give you the same kind of quiet operation you’d get from an OE HR cam & lifters.
The more aggressive the lobe profile is, along with the higher spring loads usually associated with that type of cam....... the more noise you’re going to get.
This is one of the better HR FAQ pages I’ve seen:
https://www.gatermanproducts.com/faqs.html
Re: Comp dead horse [Re: autoxcuda] #2811814
08/21/20 11:56 PM
08/21/20 11:56 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
Typical in day-age. 40+ year old craftsman hand tools that have gone thru He11 & Highwater better then new stuff today. Same with power tools. Seems older mopar cams
better then "new" stuff today. Sad.
Re: Comp dead horse [Re: PhillyRag] #2811844
08/22/20 08:26 AM
08/22/20 08:26 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Sending 'em back and putting in solid roller set. Set the lash and hopefully go......Just have to play the Blues louder
Re: Comp dead horse [Re: Spyphish] #2811846
08/22/20 08:34 AM
08/22/20 08:34 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Comp has gone to crap. My machinist won't use anything from them anymore. Has just build a Chevy boat motor and the new Comp roller rockers ball and cups totally destroyed after a few hours. 2nd motor this has happened to. Been having problems with their lifters for a while now. I have Comp cam in my 440 That I think is wiping a lobe.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
