Playing with pipes- Updated, more pics #28099
06/15/06 11:11 AM
06/15/06 11:11 AM
Anonymous OP
Anonymous OP
I started working on the headers for my big block Dakota project and made a good amount of progress in a few hours. These are 1 7/8" pipes and it looks like 2" would be OK too. 1 3/4" would be easy.
Re: Playing with pipes #28100
06/15/06 11:26 AM
06/15/06 11:26 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Kool. You're making that look easy!
Re: Playing with pipes [Re: ZIPPY] #28101
06/15/06 01:04 PM
06/15/06 01:04 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
There's nothing to it. The hard part is when you want equal length tubes. Dave
Re: Playing with pipes [Re: quickd100] #28102
06/15/06 01:11 PM
06/15/06 01:11 PM
S.E. Michigan
S.E. Michigan
Re: Playing with pipes #28103
06/15/06 01:18 PM
06/15/06 01:18 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
What are you using for a tubing bender? I am getting tired of waiting for the headers to be built for my car, and I am thinking about doing them myself. Thanks.
Re: Playing with pipes [Re: B1CUDA] #28104
06/15/06 01:24 PM
06/15/06 01:24 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I bought a kit that included a pile of U-bends and J-bends, and straights. Measure twice, cut once....or twice.....or three times. Dave
Re: Playing with pipes [Re: quickd100] #28105
06/15/06 01:28 PM
06/15/06 01:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good
Re: Playing with pipes [Re: MR_P_BODY] #28106
06/15/06 03:13 PM
06/15/06 03:13 PM
Anonymous OP
Anonymous OP
I got box of miscellaneous bends. At first i was trying to plan exactly how i wanted the pipes, then I decided to just start cutting and welding and see what happens. So far it's been a lot easier than I expected. I can up with an idea for how to located the collectors wherer I want them. I'll take pics of that and let you know how it works out. Equal length isn't too critical to me, I just want them to fit and function. I think I might be able to install and remove the driver's side by removing the steering shaft. THe passenger side is going to have to be two piece or R&R with the engine out.
Re: Playing with pipes #28107
06/15/06 06:58 PM
06/15/06 06:58 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Man, you are making it look easy. Why are ya making me rethink the fenderwell headers?!! Nice progression. They don't look too jammed in there. Looks better than I thought it would.
When you decide to quit, THAT is the moment when you would've succeeded..
Post deleted by Defbob [Re: KatFysh] #28108
06/15/06 08:38 PM
06/15/06 08:38 PM
Anonymous OP
Anonymous OP
Re: Playing with pipes #28109
06/15/06 08:43 PM
06/15/06 08:43 PM
Anonymous OP
Anonymous OP
Dave, just wait 'till you see the stupid trick I thought of for bringing the pipes to the collector. It will make things a lot easier - I hope. I should have some time tommorow to try it and I'll snap some pics.
Kevin- maybe do partial fenderwell ?
Post deleted by Defbob #28110
06/15/06 08:50 PM
06/15/06 08:50 PM
Anonymous OP
Anonymous OP
Re: Playing with pipes #28111
06/15/06 09:05 PM
06/15/06 09:05 PM
Anonymous OP
Anonymous OP
I did think of making tri-Y's but i really want to stick with the original idea of the full length headers.
Re: Playing with pipes #28112
06/17/06 04:28 PM
06/17/06 04:28 PM
Anonymous OP
Anonymous OP
I'll have to snap some pics, but what I did was tack weld a piece of flat bar to the bottom of the frame in the spot I wanted all 4 tubes to merge into the collectors. That gave me a target instead of just imagining where the would come together. I tacked 4 scrap pieces of tube together for a visual aid. So far the passenger side has been easier - the side with the tubes "stacked" in the pictures above. I need to get some more bends as it seems I need quite a few that are less than 30 degree bends and there were not too many of those in the assortment
Re: Playing with pipes #28113
06/17/06 11:21 PM
06/17/06 11:21 PM
East Lansing, Michigan
O
OldHippie Offline
super gas
OldHippie  Offline
super gas
O
How about more information on that injection manifold? That is an interesting piece.
The Old Hippie Hisself
Post deleted by Defbob #28114
06/18/06 02:57 AM
06/18/06 02:57 AM
Anonymous OP
Anonymous OP
Re: Playing with pipes #28115
06/18/06 07:11 AM
06/18/06 07:11 AM
Q
Quicktree Offline
Quicktree  Offline
Q
How about putting the collectors where you want them, and securing them in place as your targets?
thats what im gonna do.
Re: Playing with pipes #28116
06/18/06 09:24 AM
06/18/06 09:24 AM
NC
440Jim Offline
440Jim  Offline
NC
Good start and you seem to be having no problems fitting the cut ends together. How are you cutting and dressing the ends before tack welding (fit)? ie what tools are you using? Did the kit come with the center pair of tubes already bent to fit that area? It looks tighter than the typical radius bends available.
Re: Playing with pipes [Re: 440Jim] #28117
06/18/06 02:24 PM
06/18/06 02:24 PM
Anonymous OP
Anonymous OP
the pipe kit was just random bends with multiple bends per tube. I just cut what I need and formed the port end to fit the flange. That part was alot easier than I thought it would be. I'm using a band saw to cut the pipes and clean up the ends with my belt/disc combo sander. Some of the joints are really good, others are not quite so good. Overall I'm pretty happy with how it's workingout.
Dave- I don't have the collectors yet so that why I tacked 4 pieces of scrap together for a target. It ended up that i did not even use it. The flat bar located where I wanted the pipes to land and that worked well. The passenger side is mostly done except for the collector.
Re: Playing with pipes #28118
06/18/06 02:54 PM
06/18/06 02:54 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Are you gonna want to duplicate those headers for a small nominal fee??
