what power valve for my 340 sixpack? #2810150
08/18/20 12:18 PM
08/18/20 12:18 PM
Just South of The Motor City
limechallenger Offline OP
So I've got a 70 Challenger T/A with of course a 340 six pack with a 4 speed. I took the carbs off to replace the accelerator pump and while it was apart I thought I'd change the power valve. After inspection of my existing power valve ,All I see on it is E 2 ? based on that information what size power valve do I need to replace it? Thanks in advance!
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: what power valve for my 340 sixpack? [Re: limechallenger] #2810156
08/18/20 12:30 PM
08/18/20 12:30 PM
Ohio
B5TA Offline
B5TA  Offline
Ohio
I believe stock is " 65 " , Kevin
Re: what power valve for my 340 sixpack? [Re: limechallenger] #2810221
08/18/20 03:03 PM
08/18/20 03:03 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Do you happen to know your cruising speed vacuum reading?
For reference, my 340 pulls 17-19hg between 40mph to 70mph at a steady pace. Mine is not a stock rebuild and I run a 10.5pv.
Re: what power valve for my 340 sixpack? [Re: YO7_A66] #2810296
08/18/20 06:20 PM
08/18/20 06:20 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
iagree I run 9.5s and 10.5s in most of my street stuff.
Master, again and still
