REASON? ... for the SRT specific oils and filters ??... #2809000
08/14/20 07:54 PM
08/14/20 07:54 PM
Florida STAYcation
dOOc Offline OP
The village idiot's idiot
dOOc  Offline OP
Florida STAYcation
I know ... it’s THE COST of buying a car like this ... BUT is their a REASON ?
I’ve heard that some place in New Yack charges as much as 190$ for an oil and filter change. eek
Re: REASON? ... for the SRT specific oils and filters ??... [Re: dOOc] #2809064
08/14/20 11:23 PM
08/14/20 11:23 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Manufacturers & their warranties: simple as that. "if you don't do an oil change EXACTLY as documented, your warranty may be void".
Sell "hot rod" cars, knowing "some" will abuse them & you have the "Cover Your A...." policy.
Re: REASON? ... for the SRT specific oils and filters ??... [Re: dOOc] #2809121
08/15/20 06:50 AM
08/15/20 06:50 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Yeah, it's costly. $100 oil change at the dealer for my HC. I can do it for half that and will be since my warranty expired. Lots of owners on Hellcat.org do their own and document it. So however you want to fight it if things go south. twocents
Re: REASON? ... for the SRT specific oils and filters ??... [Re: redraptor] #2809142
08/15/20 09:12 AM
08/15/20 09:12 AM
A727Tflite Offline
A727Tflite  Offline
Read up on the Magnuson-Moss Act.
The manufacturer can’t void your warranty for just any reason. It has to be called out in the written warranty document.
Perform the oil change and keep records and you will be fine.
You don’t even have to use Mopar products during those maintenance events.
Re: REASON? ... for the SRT specific oils and filters ??... [Re: dOOc] #2809156
08/15/20 09:59 AM
08/15/20 09:59 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Do a search here. This was just discussed not too long back and there were some alternatives posted.
Master, again and still
Re: REASON? ... for the SRT specific oils and filters ??... [Re: DaveRS23] #2809181
08/15/20 11:38 AM
08/15/20 11:38 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not only oil, these cars are a problem waiting to happen. I’m on my third ABS sensor, info screen continuously wants to update something and I think the trans is acting up too, at only 19,000 miles for a 2015. I drive in fear every time I take it out of the garage of what’s going to go wrong today
Re: REASON? ... for the SRT specific oils and filters ??... [Re: cudaman1969] #2809236
08/15/20 01:47 PM
08/15/20 01:47 PM
moparx Offline
moparx  Offline
honda got into a deal [many] moons ago by voiding warrentees of owners that did not use "honda oil" when they changed their oil, even with documentation.
the courts struck down the "honda oil" requirement. as long as you use a qualified oil and filter, plus changing it at the required intervals, you will be good. [quit being so ChEaP DoC ! whistling]
beer
Re: REASON? ... for the SRT specific oils and filters ??... [Re: moparx] #2809239
08/15/20 01:59 PM
08/15/20 01:59 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I never knew anyone was quoting that much! But then everything in NY is more expensive. Synthetics are more expensive, that's one reason, and the capacity is higher than the old days of the 5 quarts sumps, but other than that, I don't see why.
When I had my '06 SRT8 Charger, I found it quite easy to do myself. I did have to get a lower profile floor jack, but that was it. The filter was very accessible as was the plug. I just kept the filter/oil receipt in my file for warranty purposes, but never needed it. You have a good car with a strong reliable engine.
Can you change it yourself? Save a lot of money and know it's done right.
Facts are stubborn things.
Re: REASON? ... for the SRT specific oils and filters ??... [Re: A727Tflite] #2809266
08/15/20 03:12 PM
08/15/20 03:12 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
100% correct. I can't tell you how many times I had to bust out a copy of the Magnuson-Moss Warranty Act at work, and stuff it in the faces of service advisors and service managers who would attempt to deny warranty service because a vehicle had been in a previous accident. Worked like a charm.
Earning every penny of that moderator paycheck.
DBAP
Re: REASON? ... for the SRT specific oils and filters ??... [Re: dOOc] #2809320
08/15/20 08:33 PM
08/15/20 08:33 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Some of the Hi Po engines have oil filters that doesn't have an by pass valve.
Re: REASON? ... for the SRT specific oils and filters ??... [Re: 71birdJ68] #2809322
08/15/20 09:14 PM
08/15/20 09:14 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I've been paying attention to quite a few of your posts here as of lately. You really need to stop being so concerned about the minutiae of the car. Enjoy it. Go to advance auto or auto zone or whatever. Buy good oil and their decent filter. You're gonna be OK. As far as what the other individual said about these cars being a ticking bomb and having low miles on a 2015, wake up man. If your car is under warranty, use it if your nervous. Otherwise enjoy it! I have a '14 srt with over 100k, still rips, love it. I do t use the Mopar branded stuff. You guys are thinking way too hard about small stuff.
Re: REASON? ... for the SRT specific oils and filters ??... [Re: moparjim79] #2809376
08/16/20 03:04 AM
08/16/20 03:04 AM
Florida STAYcation
dOOc Offline OP
dOOc  Offline OP
Florida STAYcation
Oh my goooness .... some peeps been busy !
But it’s 3am ... while most of youz gEeZeRs have been passed out for 6 plus hours !
mopJ ... paying attention to MY posts ?
Re: REASON? ... for the SRT specific oils and filters ??... [Re: dOOc] #2809445
08/16/20 11:40 AM
08/16/20 11:40 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Just get yourself a K&N filter (rated good in big study) and some Amsoil (always rated well) and change it yourself. C'mon, are YOU a geezer and can't change your oil and filter?
Re: REASON? ... for the SRT specific oils and filters ??... [Re: larrymopar360] #2809492
08/16/20 02:16 PM
08/16/20 02:16 PM
moparx Offline
moparx  Offline
DoC is OnLy 39 1/2 years oLd. cut him a break !
his tool box contains the remnants of his Fisher-Price plastic tOoL SeT his pappy bought for him on his 25th birthday, and he still isn't sure what a FiLtEr wrench looks like........... laugh2
beer
Re: REASON? ... for the SRT specific oils and filters ??... [Re: moparx] #2809570
08/16/20 07:54 PM
08/16/20 07:54 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Use a quality oil& filter&hammer the car like it was meant to be driven.I've a few srt's &rts,over the years never had a problem,& yes they got heavy use,street&dragstrip use.Enjoy that car,like it was meant to be used.
Re: REASON? ... for the SRT specific oils and filters ??... [Re: GarageDodge] #2810181
08/18/20 01:28 PM
08/18/20 01:28 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Right!
Re: REASON? ... for the SRT specific oils and filters ??... [Re: moparx] #2810182
08/18/20 01:29 PM
08/18/20 01:29 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
beer
PuT aWaY tHe EaSy BaKE OveN DoC (Oh, SOrRy, NoBAlls CrUsAder) And BrEaK oUt ThE MeCHaNiCs ToOls!
Re: REASON? ... for the SRT specific oils and filters ??... [Re: larrymopar360] #2810199
08/18/20 02:00 PM
08/18/20 02:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Profit/strategic partnerships
Rich H.
Esse Quam Videri
