Re: REASON? ... for the SRT specific oils and filters ??...
[Re: redraptor]
#2809142
08/15/20 09:12 AM
08/15/20 09:12 AM
Posts: 3,089 Michigan
A727Tflite
Read up on the Magnuson-Moss Act.
The manufacturer can’t void your warranty for just any reason. It has to be called out in the written warranty document. Perform the oil change and keep records and you will be fine. You don’t even have to use Mopar products during those maintenance events.
[Re: dOOc]
#2809156
08/15/20 09:59 AM
08/15/20 09:59 AM
Posts: 12,216 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Do a search here. This was just discussed not too long back and there were some alternatives posted.
Master, again and still
[Re: moparx]
#2809239
08/15/20 01:59 PM
08/15/20 01:59 PM
Posts: 15,911 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I never knew anyone was quoting that much! But then everything in NY is more expensive. Synthetics are more expensive, that's one reason, and the capacity is higher than the old days of the 5 quarts sumps, but other than that, I don't see why.
When I had my '06 SRT8 Charger, I found it quite easy to do myself. I did have to get a lower profile floor jack, but that was it. The filter was very accessible as was the plug. I just kept the filter/oil receipt in my file for warranty purposes, but never needed it. You have a good car with a strong reliable engine.
Can you change it yourself? Save a lot of money and know it's done right.
Facts are stubborn things.
[Re: A727Tflite]
#2809266
08/15/20 03:12 PM
08/15/20 03:12 PM
Posts: 19,968 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
The manufacturer can’t void your warranty for just any reason. It has to be called out in the written warranty document. Perform the oil change and keep records and you will be fine. You don’t even have to use Mopar products during those maintenance events. 100% correct. I can't tell you how many times I had to bust out a copy of the Magnuson-Moss Warranty Act at work, and stuff it in the faces of service advisors and service managers who would attempt to deny warranty service because a vehicle had been in a previous accident. Worked like a charm.
Earning every penny of that moderator paycheck.
DBAP
[Re: dOOc]
#2809445
08/16/20 11:40 AM
08/16/20 11:40 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Just get yourself a K&N filter (rated good in big study) and some Amsoil (always rated well) and change it yourself. C'mon, are YOU a geezer and can't change your oil and filter?
[Re: GarageDodge]
#2810181
08/18/20 01:28 PM
08/18/20 01:28 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Use a quality oil& filter&hammer the car like it was meant to be driven.I've a few srt's &rts,over the years never had a problem,& yes they got heavy use,street&dragstrip use.Enjoy that car,like it was meant to be used. Right!
[Re: moparx]
#2810182
08/18/20 01:29 PM
08/18/20 01:29 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
DoC is OnLy 39 1/2 years oLd. cut him a break ! his tool box contains the remnants of his Fisher-Price plastic tOoL SeT his pappy bought for him on his 25th birthday, and he still isn't sure what a FiLtEr wrench looks like........... PuT aWaY tHe EaSy BaKE OveN DoC (Oh, SOrRy, NoBAlls CrUsAder) And BrEaK oUt ThE MeCHaNiCs ToOls!
[Re: larrymopar360]
#2810199
08/18/20 02:00 PM
08/18/20 02:00 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Profit/strategic partnerships
Rich H.
Esse Quam Videri
