54-56 Truck #280952
04/07/09 09:41 PM
04/07/09 09:41 PM
Iowa
76dodgeboy Offline OP
Iowa
Will a 54-56 nose and fenders fit a 52? There is a cab with front clip for sale locally
Re: 54-56 Truck [Re: 76dodgeboy] #280953
04/08/09 02:48 AM
04/08/09 02:48 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
They should, AFAIK. There's a bit of "license" available to you.
2 Demons...no, not my kids!
Re: 54-56 Truck [Re: 76dodgeboy] #280954
04/08/09 09:03 AM
04/08/09 09:03 AM
Iowa
Iowa
I dont understand what "Licence" means
Re: 54-56 Truck [Re: 76dodgeboy] #280955
04/08/09 11:24 AM
04/08/09 11:24 AM
4speeds4me Offline
4speeds4me  Offline
Like artistic license. Maybe latitude would've been a better choice. What I was getting at is you should be able to swap fairly extensively for a few years there (like 48 or 49-56 or so). AFAIK, until 57 the changes weren't all that radical, so making some swaps requires little to no modification.
Re: 54-56 Truck [Re: 4speeds4me] #280956
04/08/09 03:39 PM
04/08/09 03:39 PM
Iowa
Iowa
Re: 54-56 Truck [Re: 76dodgeboy] #280957
04/08/09 11:02 PM
04/08/09 11:02 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Hate to kill your good time here, but the 54 clip is different then a 52 clip. The hood line is at a different level and the fenders mount differently. I think the fit at the doors will be the most troublesome. A 54 (55 and 56) fender has 3" or 4" wide flanges at the rear of the fender, 90 degrees to the fender surface that run from the top of the fender to the bottom. Those flanges are bolted to extensions welded to the firewall . You open the door to gain access to the fender bolts. (I just know I don't have any pictures here anymore.) This picture is a 54. Notice how high the fender line is on the door and the shape of the nose?
A 52 (48 up to 53) fender bolts to a 6" long angle plate that bolts to horizontal plates in the front fenders. Those angles then bolt into the side of the firewall/cab 90 degrees to the front of the firewall. You access the angle bolts from inside the cab.
All that said, make sure which truck (and clip) you actually have. I think this era truck has the years confused more then any other Dodge trucks ever built. Gene
Re: 54-56 Truck [Re: poorboy] #280958
04/08/09 11:09 PM
04/08/09 11:09 PM
Freeport IL USA
Freeport IL USA
This red primmered one has a 52 cab & clip. Notice the body is lower on the door, the hood is taller, and the nose has a different shape, esspecially at the center. The wheel wells have been modified on the red one, but both have original fender tops, are original along the door edges, and have original hoods. Gene
Re: 54-56 Truck [Re: 76dodgeboy] #280959
04/09/09 02:41 AM
04/09/09 02:41 AM
4speeds4me Offline
4speeds4me  Offline
Thanks for the pics, poorboy. It's strange. I have a 51 here and a 54 and the doors and front fenders were the same on both...Canadian thing, maybe? However, according to the original post, if it's a cab and front clip they should be a match...unless there's a cab for sale in one place and front clip elsewhere? My head hurts...
Re: 54-56 Truck [Re: 4speeds4me] #280960
04/09/09 06:44 AM
04/09/09 06:44 AM
Ontario, Canada
dodge41 Offline
dodge41  Offline
Ontario, Canada
I don't have a link or anything, but I'm sure I read somewhere that the first few 54 models were made from the left over parts from 53 before they changed to the new body style. I'll keep looking and see if I can find where I read that. Maybe it is a Canadian thing?
Matt
Re: 54-56 Truck [Re: dodge41] #280961
04/09/09 06:47 AM
04/09/09 06:47 AM
Ontario, Canada
dodge41 Offline
dodge41  Offline
Ontario, Canada
This is also a good source of info :
http://www.dodgepilothouseclub.org/index.htm
Matt
Re: 54-56 Truck [Re: dodge41] #280962
04/09/09 12:26 PM
04/09/09 12:26 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
I have a 56 if you don't move on those would you mind PMing me the info. Good luck on your project love these trucks.
What was I thinking....
Re: 54-56 Truck [Re: 72blubird] #280963
04/09/09 01:14 PM
04/09/09 01:14 PM
Iowa
Iowa
My truck is a 52. There is a cab and clip together on craigslist thats 54-56. I dont want to swap cabs because mine has a Pontiac dash that is staying. Ill get pics. Its been mildly customized and want to keep it custom. Thanks for the info. sucks but oh well
