Another HVAC question.
#2809532
08/16/20 04:44 PM
08/16/20 04:44 PM
Posts: 12,800 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
I've got a central heater in the basement that services the first floor, and one in a closet on the second floor that goes to the upstairs room. I want to put in AC. Do I connect it to just one system or do I need to get two units, one for each floor?
Trying to enjoy life!
Re: Another HVAC question.
[Re: calmopar]
#2809544
08/16/20 05:58 PM
08/16/20 05:58 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Our house has two floors with one central AC and the 2nd floor is always 5 degrees F hotter in Summer. Our next door neighbor has a nearly identical house, and when his single central AC died four years ago he put in dual AC units serving a floor each and he tells me it works much better. For us, however, we now hear two AC units starting and stopping independently, causing twice as often fan start noise.
[Re: 360view]
#2809567
08/16/20 07:24 PM
08/16/20 07:24 PM
calmopar
East Bay, N. Cal.
Ugh, sorry - never thought about the noise. I've never lived anywhere that needed aircon (still don't, really) so I am not familiar with the sounds.
[Re: calmopar]
#2809568
08/16/20 07:36 PM
08/16/20 07:36 PM
Posts: 1,252 Slidell, LA
Ronnman
Slidell, LA
For better temperature control, 2 units, one for each floor, is best.
Noise wise, if you buy the cheap units, bottom of the line, like Goodman, they cane be more noisy. Units costing a little more will be much quieter. Look for a unit with a slower outdoor fan speed and an insulating wrapper around the compressor. Ron
[Re: Sniper]
#2809765
08/17/20 01:52 PM
08/17/20 01:52 PM
Posts: 8,162 USA
360view
USA
For us, however, we now hear two AC units starting and stopping independently, causing twice as often fan start noise. A few years ago I replaced my old HVAC system. the new one has a soft start on the compressor, the compressor fan and the blower inside. You barely hear it. The old one sounded like someone kicked the compressor housing every time it fired up. Not even sure they sell that style anymore, unless you are buying a super cheap one. The new one wasn't cheap but my electricity bill dropped by about 2/3's in the summer compared to having the old one. I have thought about buying a 1/4 hp 230 volt soft starter for my outdoor unit’s condenser cooling fan. I learned a few years ago that the 5 bladed Dodge pickup’s radiator fan’s uneven blade spacing was for noise reduction. If my fuzzy memory is right that odd bladed fan is 28% quieter than the previous fan design. My outdoor unit has a 4 bladed fan inside a shroud with just bent metal blades instead of “airplane wing” blades. I wish I could buy a quieter fan design, that has the Amana hub design. I am 99% sure a few dB quieter fan could be designed. Your tax $ paid for this quiet AC fan design https://stars.library.ucf.edu/cgi/v...r=1&article=1219&context=patentsScroll down and look at Fig. 17 and Fig. 18 for “funky” fan blades and spacing. I would like to try one of these 5 blade fans with a steeper pitch at a lower speed https://www.ebay.com/itm/60-5611-01...6?hash=item25cae98218:g:YMoAAOSw8G1di8dbMy 4 blade is 27 pitch so the above 5 blade with 33 pitch would probably overload the existing OEM motor
[Re: 360view]
#2810438
08/18/20 09:46 PM
08/18/20 09:46 PM
Posts: 4,149 Canada -- Posts: 4034 -Registe...
5thAve
Our house has two floors with one central AC and the 2nd floor is always 5 degrees F hotter in Summer. Our next door neighbor has a nearly identical house, and when his single central AC died four years ago he put in dual AC units serving a floor each and he tells me it works much better. For us, however, we now hear two AC units starting and stopping independently, causing twice as often fan start noise. Sometimes depending on the house and the system getting it rebalanced will fix that upstairs heat problem. The hotter area gets more cooling and the temperatures end up matching better. Our house is a big L shaped bungalow so our problem was because of exposure one side was always too hot or too cold. So each section ended up with it's own system.
